Update HASS 14.2 to 15.1 fails on x86 (HP T620) machine
Dear all,
I just returned from a two weeks holiay and performed a number of updates available. All worked fine until the point I upgraded the operating system from 14.2 to 15.1.
The system became unavailable. I did three hardware reboots until the system became available again. I am still offered the HASS 15.1 update again.
Please help. I found the issues here which indicated a problem on T620 with HASS 15.0, but the issue reported there should be resolved on 15.1, if I’m right.
How can I support the clarification? Which logs would you need and how can I prepare them for you?
There are some solutions listed in this topic by one of the OS devs: Home Assistant OS 15.0 - no need to skip
Expand the relevant section
is the 15.1 update now good for the HP thinclients? like the T620?
i have one in use , i have proxmox and home assistant installed , would realy like to know if it save to update :slight_smile:
Can let all know I have updated and everything is working :smile:
Updated 14.1 to 15.2 without issues :slight_smile:
