Home Assistant OS 15.0 - no need to skip
tl;dr - only very few users are affected by regressions. The fail safe update system makes updating Home Assistant OS generally a very safe operation.
Last week we released Home Assistant Operating System 15.0, which was a larger release after several weeks in the making, bringing major updates to some building blocks our OS stands on - especially the Linux kernel and the U-Boot bootloader, that inevitably brought a couple of regressions that affected some of our users. A few hours after the release, issues with this latest update were posted on various channels in our community, at which point some of you might have started to believe something was seriously wrong with this release. Immediately we started to investigate these reports to find out how serious the problems were, and in the end distilled several root causes out of the incoming reports. At this point we have a good overview of the issues, and we can safely say that for most users the 15.0 update is just fine! If you are still worried, here is an overview of the issues in OS 15.0.
What didn’t work?
Let’s take a look at what issues the release had that caused all the commotion. Although the following list may look scary at first, the bugs affected only a subset of the users. While some people started to report problems, the majority couldn’t see anything unusual even when running similar hardware. The reasons for this are explained below, as well as the individual issues we found.
Raspberry Pi 5 stuck on reboot or boots back to the old version
A mixed bag of reports, and probably the most visible one, was coming from users of Raspberry Pi 5. We already received some reports of intermittent update failures after previous releases, which eventually went away after several retries. The same we saw here but with a few more cases. Finally, some of you posted the boot logs where we noticed the problems were caused by missing firmware support for new features added to the Linux kernel. This was a known problem that was later fixed in a development branch of the Raspberry Pi kernel, and an update of the bootloader reportedly resolved all these issues. Unfortunately, it’s a bit trickier, as Home Assistant OS doesn’t have the tools to update or even check the version of the bootloader. However, the upcoming version contains backported patches that should even cope with the old bootloader. Needless to say, there was one more bug on the Home Assistant OS side with Raspberry Pi 5 reboots that we only fixed in 15.0, that may have caused lockup in the bootloader when you restarted the Pi from the software without performing an update.
The known issues have been fixed, but the recommendation of updating the bootloader sticks, as there were some errors in the bootloader that we can’t affect. We also got in touch with the Raspberry Pi folks to understand if these breakages are something we should be worried about, and although it was rather a bug on their side, we decided that we should take measures on Home Assistant OS as well. More about that later.
AMD-based thin clients (e.g HP t620) stuck after update
These were also among the first reports to come in, which shows how popular these repurposed devices from corporate offices are. Immediately after the update, the device became unavailable, requiring a few reboots or manual boot slot selection to get back to the working state.
The cause of this bug was a change in the Linux amdgpu driver. While it wasn’t in effect in the old Linux version because support for integrated GPU in these AMD SoCs wasn’t enabled, changes introduced in the new kernel made it fail badly if options enabling its support were missing. Once we got logs from some of you, the root cause was shortly identified and reported as a bug to driver maintainers. The latest builds now have the options for supporting this hardware enabled, and future Linux versions should fail gracefully if amdgpu driver isn’t compiled without those (currently “experimental”) options.
Generic x86-64 with certain SATA disks boots back to the previous version
There was another regression coming from upstream Linux kernel changes. The common denominator is an x86 machine running from a SATA drive (note that some M.2 drives are also using the SATA interface) failing to come back after the upgrade or falling back to the old version after being restarted.
Since 6.11 Linux uses a more efficient power-saving policy for SATA devices. However, not all devices that report support for it work well when it’s in effect. The fix is to add libata.force=nolpm to the kernel command line options, which can be done either temporarily through the GRUB menu or to the cmdline.txt file in the boot partition. For a proper fix, gathering the information about the exact hardware is needed, so the workaround can be hardcoded in the Linux kernel. However, so far these reports were mostly related to drives from no-name vendors that are usually included out of the box in cheap NUC-like mini PCs. When using hardware from reputable manufacturers there’s a much smaller chance of breakage.
ODROID-N2 fails to boot (from certain eMMC modules)
This one was not as common but maybe the most worrisome. As we updated to the latest U-Boot bootloader version, some of the patches dropped out of the list of patches that should be applied. One of these is a workaround for eMMC initialization errors that is needed to make eMMC reading in U-Boot stable on some eMMC modules, including those that were shipped with the original Home Assistant Blue. Once we identified the mistake, we pulled back the release for this board so it won’t be offered to more users. The issue only appeared intermittently, so after several reboots the devices usually came back. Downgrading to the previous version was then required, as swapping the boot slots doesn’t replace the bootloader in this case due to technical limitations.
Should you skip 15.0?
Unless you are using one of the above mentioned hardware combinations the answer is no. At the time of writing about one third of all Home Assistant OS installs are already running 15.0. With every update, there’s a chance that something will get wrong in the jungle of different configurations, and even a dozen people out of hundreds of thousands can give you a feeling that the issue is serious. However, as you could see, almost all of the bugs reported in OS 15 were affecting only some specific devices and configurations, meaning the majority of users didn’t experience anything unusual.
Don’t you test your releases?
Yes, we got this question a couple of times (not only) after this release. The short answer is: yes, we do. The longer question is a bit more complicated. We obviously do test all the changes before they are committed to the development branch. These changes then land in the daily builds that you get if you have configured your update channel to the development one. Not many users have it enabled, which is a good thing, but it’s still being regularly tested on most of the boards and configurations that Home Assistant OS is built for. However, with the modularity of various platforms, there can be edge cases that we can’t test. For example, the popular Raspberry Pis can be running from a plethora of SD cards, USB drives or NVMe disks. The situation is even worse with the generic x86-64 target - people are using anything from 15 year old PCs to setups with the latest top-of-the-line processors. This is something that we can’t test and we can only rely on the Linux kernel being working on these properly. Even then, some more exotic configurations need some tweaks first before our OS can run on them. On the other hand, simple platforms with lower modularity can be tested more thoroughly, so if you want plug and play experience, there’s a strong argument for using well-constrained platforms, like the Home Assistant Green.
Moreover, approximately 1% of users usually update to beta (release candidate) before a stable release is made. Even though this doesn’t seem like a lot, there are currently over 3000 users who are helping all of us to make sure the stable update won’t cause any trouble. Ideally we would love to motivate more people to participate in beta testing, as we can be better focused on fixing the edge-cases than when hundreds of thousands people update and start running into sometimes unrelated issues.
How can you help?
First of all, if an OS update doesn’t go as planned, don’t panic. Most of the time you will be able to get exactly the same system as before the update thanks to the A/B boot mechanism. If an issue occurs, check our issue tracker first to see if it has already been reported. If it is, be patient and try to be helpful with gathering more details about the bug. Usually, posting “me too” to the issue isn’t helpful. It creates unnecessary noise for the people tracking the issue and doesn’t provide any new information. Also keep in mind that most of the bugs (with a few rare occasions) are specific to different builds - if a Raspberry Pi fails to boot, it’s pointless to report problems with your Proxmox VM to the same issue. The bug report template asks you to pull out some information from your installation that is necessary for better identification of the bug.
Also, the general recommendation of making regular backups applies. The new backup system makes it much easier to create off-site backups using some of the backup integrations.
What’s next?
We are releasing 15.1.rc1 today which addresses all the major issues that you reported for 15.0. You can help testing this pre-release without going all-in and joining the beta channel by updating to it directly using ha os update --version 15.1.rc1. Create a GitHub issue if anything still doesn’t work for you.
For future releases, we’ll focus on making troubleshooting easier, as we realize that Linux knowledge shouldn’t be a must if you want to run Home Assistant OS. Raspberry Pi models that are using the EEPROM bootloader will get a native Home Assistant OS tooling for updating it, so you won’t need to fiddle with spare SD cards or boot Raspberry Pi OS to get latest updates anymore. And of course, we’ll be investing more effort into automated testing to minimize breakages, but as it’s been already said, in many cases your patience and cooperation is very important too.
15.1.rc1 on a Generic-x86 install updated from v14.x without issue.
Update Home Assistant Blue - no issues, so far.
Yes works here on the HP T620.
[core-ssh ~]$ ha os update --version 15.1.rc1
Processing... Done.
Error: Unknown error, see supervisor
[core-ssh ~]$
This is the same log output I had with 15.1:
2025-04-01 15:51:16.512 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2025-04-01 15:51:16.513 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2025-04-01 15:51:16.513 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2025-04-01 15:51:16.517 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2025-04-01 15:51:16.643 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2025-04-01 15:51:16.643 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2025-04-01 15:51:16.644 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2025-04-01 15:51:16.644 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2025-04-01 15:51:16.645 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2025-04-01 15:51:16.645 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2025-04-01 15:51:16.645 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2025-04-01 15:51:16.646 INFO (MainThread) [supervisor.resolution.check] System checks complete
2025-04-01 15:51:16.646 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2025-04-01 15:51:16.734 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2025-04-01 15:51:16.734 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2025-04-01 15:51:16.734 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2025-04-01 15:52:36.774 INFO (MainThread) [supervisor.host.info] Updating local host information
2025-04-01 15:52:37.096 INFO (MainThread) [supervisor.host.services] Updating service information
2025-04-01 15:52:37.098 INFO (MainThread) [supervisor.host.network] Updating local network information
2025-04-01 15:52:37.154 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2025-04-01 15:52:37.159 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2025-04-01 15:52:38.387 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-04-01 16:22:38.561 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2025-04-01 16:33:42.038 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
2025-04-01 16:33:42.040 INFO (MainThread) [supervisor.api.middleware.security] /network/info access from core_ssh
2025-04-01 16:33:42.043 INFO (MainThread) [supervisor.api.middleware.security] /host/info access from core_ssh
2025-04-01 16:33:42.046 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from core_ssh
2025-04-01 16:33:44.350 INFO (MainThread) [supervisor.api.middleware.security] /os/update access from core_ssh
2025-04-01 16:33:44.484 INFO (MainThread) [supervisor.os.manager] Fetch OTA update from https://os-artifacts.home-assistant.io/15.1.rc1/haos_generic-x86-64-15.1.rc1.raucb
2025-04-01 16:33:51.397 INFO (MainThread) [supervisor.os.manager] Completed download of OTA update file /data/tmp/hassos-15.1.rc1.raucb
2025-04-01 16:33:51.433 ERROR (MainThread) [supervisor.os.manager] Home Assistant Operating System update failed with: Installation error: Failed marking slot kernel.1 non-bootable: Failed marking slot kernel.1 as bad:  grub backend: Failed to run grub-editenv: Child process exited with code 1
OS Info:
[core-ssh ~]$ ha os info
board: generic-x86-64
boot: A
boot_slots:
  A:
    state: booted
    status: bad
    version: "14.2"
  B:
    state: inactive
    status: bad
    version: null
data_disk: SAMSUNG-MZNTY128HDHP-000L1-S2YRNB0H927859
update_available: true
version: "14.2"
version_latest: "15.1"
Will post on GitHub also :+1:
Grok to the rescue - corrupted grubenv:
rm /mnt/boot/EFI/BOOT/grubenv
grub-editenv /mnt/boot/EFI/BOOT/grubenv create
 // Set variables:
grub-editenv /mnt/boot/EFI/BOOT/grubenv set ORDER="A B"
grub-editenv /mnt/boot/EFI/BOOT/grubenv set A_OK=1
grub-editenv /mnt/boot/EFI/BOOT/grubenv set A_TRY=1
grub-editenv /mnt/boot/EFI/BOOT/grubenv set B_OK=0
grub-editenv /mnt/boot/EFI/BOOT/grubenv set B_TRY=0
Dell Wyse works well!
15.1 doesn’t work on my HP T620
Huge pain, because it is in a separate room with headless setup, now had to transfer to another room to check any error messages. There is none, but always stops right after kernel messages about the AMD GPU:
14.2 works fine, so that was it for 15.x from me, no OS update.
As this is an isolated case and absolute majority of other reports from t620 are good (with one exception so far where the LAN port was damaged and USB ethernet was used for connection - still waiting for more information to identify the cause), it has to be something specific about your setup. Are there any USB peripherals plugged, or anything else that could be considered non-standard?
Dear all,
I just updated my Odroid N2+ (HA Blue) to HA OS 15.2 and, although my WiFi adaptor is still recognized and visible under Sytem > Network > Configure network interfaces, there are available Networks. Rolling back to 14.2 solves the problem. Any ideas as to what the cause can be? The kernel version?
This is my WiFi dongle, it uses the Realtek RTL8811AU chip Amazon.com: WiFi Nation® WiFi Dongle Mini 802.11ac AC600 USB WiFi Adapter, chipset: Realtek RTL8811AU, Dual Band 2.4GHz or 5GHz, Windows, MacOS, Linux Supported - White : Electronics
Thanks!
Not that I know of. Normally there is UPS connected to a USB port, but when it became unresponsive after upgrading to 15.1, I took the machine to another room, attached just a monitor, a keyboard and ethernet cable. That’s when I took that picture when it froze again during boot, with nothing else connected to it.
Maybe some settings in the BIOS, IDK… I don’t remember anything special, only setting VGA frame to the minimum, I believe 32M. And that this HP T620 has no VGA connector but 2 Displayports instead, but I think thats fairly normal for this model (though I’ve seen a version which had a VGA connector instead of the serial port)
As it is a headless machine, I’ll probably only experiment with it again with 16.x, 14.2 is fine by me now.
I had some issues with my sata drive + HP thinclient T620. In the end the 3rd or so attempt booting to v15.1 was sucessful. tl;dr: keep trying and make backups.
hyperv here update to 2025.4.0 finished. then 15.1 froze waited 2 hours. lost connectivity. rebooted no ping no web. booted to A vs B shows 15.0 but cant ping cant get to web. 1 week in and this is crappy.
No, I have the same issue on my T620 machine. Hardware is fine.
I just upgraded my ODROID N2+ (HA Blue equivalent) from 14.2 to 15.1. Reboot took a couple of minutes longer than usual, but the system booted successfully the first time.
Thank you @sairon for such a great response to this issue. :grinning:
Das anybody knowes if the update on a hp thinclient like the t630 works now? Or shall I wait a little longer?
Also for me Wifi Connection gets broken after update to HA OS 15.X .
I am using the WiFi Connection via USB WLAN Adapter to connect against my Solar Inverter with Huawei Solar Integration.
Reverting to HA OS=14.2 fixes the issue. So I assume this could be a regression within the latest Version.
I am using following WLAN USB Stick within my Proxmox Server:
https://amzn.eu/d/60FDSRR
TP-Link Archer T2U Nano AC600 USB WLAN Stick Adapter(433MBit/s 5GHz, 200MBit/s 2,4GHz, WPA und WPA2-VerschlĂĽsselungs-Standard, Windows 11/10/8.1/8/7/XP, Mac OS 10.15 und frĂĽher) schwarz/gold
Thanks,
Toni
15.2 finally works fine on my HP T620, thanks!
Hi there. I am intrigued as I had problems loading 15.0 on to the t630 - HAOS started to load and then stopped and went black screen. I have loaded 15.2 and have the same issue albeit appears to get further into the loading process, the screen below shows were it stops. Would you be amenable outside of this forum perhaps to compare configs/ setup etc to see any differences as to why my system is not loading correctly?
Any other observations, assistance my anybody will be much appreciated
