Whenever there is an update to HA I seem to have the following issue.
I click on the update, but after a bit of spinning nothing seems to happen.
Checking the logs for the Supervisor I can see.
22-09-15 14:21:53 INFO (MainThread) [supervisor.backups.manager] Creating new partial backup with slug 3a8a8bf1
22-09-15 14:21:53 INFO (MainThread) [supervisor.homeassistant.module] Backing up Home Assistant Core config folder
22-09-15 14:21:56 INFO (MainThread) [supervisor.homeassistant.module] Backup Home Assistant Core config folder done
22-09-15 14:21:56 INFO (MainThread) [supervisor.backups.manager] Creating partial backup with slug 3a8a8bf1 completed
22-09-15 14:21:56 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2022.9.4
22-09-15 14:21:56 INFO (SyncWorker_2) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.2 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.4
22-09-15 14:21:56 INFO (SyncWorker_2) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2022.9.4.
22-09-15 14:22:02 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-09-15 14:22:02 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-09-15 14:22:02 INFO (MainThread) [supervisor.api.middleware.security] /backups/3a8a8bf1/info access from cebe7a76_hassio_google_drive_backup
22-09-15 14:22:59 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.4: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.4/json: Not Found ("no such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.4: No such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2022.9.4")
22-09-15 14:22:59 WARNING (MainThread) [supervisor.homeassistant.core] Updating Home Assistant image failed
However if I go to ghcr.io/home-assistant/raspberrypi4-64-homeassistant there does seem to be a file with the tag 2022.9.4.
This will happen for a few days as I occasionally try to update, until suddenly it will complete for no apparent reason.
Does anyone have any idea why this would be?
Iām on a Raspberry Pi 4 2Gb, booting from an external USB SSD which has Home Assistant OS installed.
Checking the forums for this issue I saw a few topics which were related to being on a different subnet, but I have nothing clever setup with my networking.
