Update notifications (Core, OS, Addons, HACS, etc)
For some time now the ā€˜Updateā€™ button in the notification only starts updating the addon, but the notification doesnā€™t disappear and thereā€™s no notification saying ā€˜Updatingā€™. Then if I hit update again log says ā€˜no update for Updateā€™ since itā€™s already updated. Ideas? The Update entities Iā€™ve specified is ā€˜Home Assistant Core Updateā€™, ā€˜Home Assistant Operating System Updateā€™ and ā€˜Home Assistant Supervisor Updateā€™.
I cannot select my device in the drop down, here is nothing listed. (but my phone is the only device with the app anyway).
With other automations, I am able to select my phone in the ā€œdeviceā€ drop down.
Any idea what I could check?
Nice! Looks good and now implemented.
One question and Iā€™m sorry if I missed that somewhere, but is it correct that it doesnā€™t see section updates under Hacs?
Thanks autor for this project!!!
A little bit correcting the yaml file of this project
Add a switch, now possible send notification to telegram (telegram must be added to home assistant configuration file)
On telegram looks great:
link on github
Hey @CentralCommand
I am still experiencing the above issue, just wondering if you are too (see the reply)
This is my configuration:
alias: Update notifications
description: ""
use_blueprint:
  path: mdegat01/update_notifications.yaml
  input:
    reminder_hours: "6"
    mobile_app_device: c3be379f5150396ba4631fa0ba3991ab
    only_after: "00:00:00"
    only_before: "00:00:00"
    update_entities:
      - update.home_assistant_core_update
      - update.home_assistant_supervisor_update
      - update.appdaemon_update
      - update.home_assistant_google_drive_backup_update
      - update.influxdb_update
      - update.log_viewer_update
      - update.mariadb_update
      - update.mosquitto_broker_update
      - update.node_red_update
      - update.ring_mqtt_with_video_streaming_update
      - update.studio_code_server_update
      - update.tasmoadmin_update
      - update.zigbee2mqtt_update
    status_bar_icon: mdi:home-assistant
    changelog_urls:
      update.appdaemon_update: https://github.com/hassio-addons/addon-appdaemon/releases
      update.home_assistant_google_drive_backup_update: https://github.com/sabeechen/hassio-google-drive-backup/releases
      update.influxdb_update: https://github.com/hassio-addons/addon-influxdb/releases
      update.log_viewer_update: https://github.com/hassio-addons/addon-log-viewer/releases
      update.mariadb_update: >-
        https://github.com/home-assistant/addons/blob/7dab96512c6fca69a33004f75838a90a51efa25c/mariadb/CHANGELOG.md
      update.mosquitto_broker_update: >-
        https://github.com/home-assistant/addons/blob/7dab96512c6fca69a33004f75838a90a51efa25c/mosquitto/CHANGELOG.md
      update.node_red_update: https://github.com/hassio-addons/addon-node-red/releases
      update.ring_mqtt_with_video_streaming_update: https://github.com/tsightler/ring-mqtt-ha-addon/blob/bf780e608d7ffcf9f3f14e3ba4e644a3467bd352/CHANGELOG.md
      update.studio_code_server_update: https://github.com/hassio-addons/addon-vscode/releases
      update.tasmoadmin_update: https://github.com/hassio-addons/addon-tasmoadmin/releases
      update.zigbee2mqtt_update: >-
        https://github.com/zigbee2mqtt/hassio-zigbee2mqtt/blob/1c1dba19f59c7a760198e866a893db21215e5db4/zigbee2mqtt/CHANGELOG.md
    notification_channel: Updates
Any thoughts?
Rob
This project looks amazing! I installed it and I got an update around 10 minutes later! :rofl:
I also installed the scheduled updates blueprint. I added a toggle to pause the scheduled updates. When your blueprint notifies me I can now choose to install the update or I can hit the toggle and the updates should install early the next morning. Now I just have to figure out how to interact with the toggle from the notification. When combine the two blueprints create an awesome automation team!
My automation isnā€™t sending notices. Getting this error in the automation trace:
UndefinedError: No first item, sequence was empty.
It seemed like that was related to the global check every X hours, so I disabled that. It was failing on my Unifi AP that has an update entity.
Now the trace just falls through to the bottom with no actions taken.
There is a pending update that I confirmed is in the monitored list. I went and made it the only item in the list, but no change.
auto_update: false
installed_version: v2.3.1
in_progress: false
latest_version: v2.4.0
release_summary: null
release_url: https://github.com/artem-sedykh/mini-climate-card/releases/v2.4.0
skipped_version: null
title: null
friendly_name: mini climate card update
supported_features: 21
@Quacked I am having this same issue.
The update is actually performing but it is not clearing the notification.
Having a quick look, I could not find the issue.
I am running HA Container, so this is only really for HACS updates.
Did you find a solution?
Or has anyone else had the same problem?
Havenā€™t found a solution, no. :confused:
If it helps, I see the following error messages in my log:
2022-11-10 03:00:00.015 WARNING (MainThread) [homeassistant.helpers.template] Template variable warning: No first item, sequence was empty. when rendering '{{ device_attr(entity_id, 'identifiers') | first }}'
2022-11-10 03:00:00.018 ERROR (MainThread) [homeassistant.components.automation.notification_for_updates] notification_for_updates: Choose at step 1: Send reminders if enabled: Loop over updates and send reminder: Error executing script. Error rendering template for variables at pos 2: UndefinedError: No first item, sequence was empty.
2022-11-10 03:00:00.019 ERROR (MainThread) [homeassistant.components.automation.notification_for_updates] notification_for_updates: Choose at step 1: Send reminders if enabled: Error executing script. Error rendering template for repeat at pos 2: UndefinedError: No first item, sequence was empty.
2022-11-10 03:00:00.021 ERROR (MainThread) [homeassistant.components.automation.notification_for_updates] notification_for_updates: Error executing script. Error rendering template for choose at pos 1: UndefinedError: No first item, sequence was empty.
2022-11-10 03:00:00.022 ERROR (MainThread) [homeassistant.components.automation.notification_for_updates] Error while executing automation automation.notification_for_updates: UndefinedError: No first item, sequence was empty.
Finally had a chance to look in to it a bit moreā€¦
I noticed it only auto-clears the notification for the update entities that are explicitly listed, not any of them.
Iā€™ve just listed them all and seems to work ok now.
I have the following error in my system logs:
2022-11-17 08:45:34.258 ERROR (MainThread) [homeassistant.components.automation] Blueprint Update notifications generated invalid automation with inputs OrderedDict([('reminder_hours', '6'), ('update_entities', ['update.access_point_garage', 'update.access_point_living', 'update.access_point_slaapkamer', 'update.afvalbeheer_update', 'update.anniversaries_update', 'update.auto_backup_update', 'update.daikin_residential_controller_update', 'update.garmin_connect_update', 'update.hacs_update', 'update.mini_media_player_update', 'update.soers_network', 'update.sonos_cloud_update', 'update.switch_24_garage', 'update.switch_8_garage', 'update.switch_8_garage_camnet', 'update.switch_8_living', 'update.thuis_nas01_dsm_update', 'update.toon_smart_meter_update', 'update.tesla_update', 'update.mister_t_software_update', 'update']), ('mobile_app_device', 'f1e469f41a3ad819a0b437bcb88b7d9d'), ('take_backup', False), ('run_config_check', True), ('only_after', '08:00:00'), ('only_before', '20:00:00')]): Entity update is neither a valid entity ID nor a valid UUID for dictionary value @ data['entity_id']. Got None
@CentralCommand
The blueprint doesnā€™t change the notification to ā€œupdatingā€¦ā€ for HACS updates.
This is because the in_progress attribute changes to a number (% done), rather than true. A simple fix is done by making the following changes under the ā€˜startedā€™ trigger:
To confirm, I have tested this and it works.
Let me know if this was already considered and I have tried to enhance a conscious decision.
@joshward9182 Whatā€™s the easiest way to implement this fix? Fork it and use your own fork as blueprint?
@CentralCommand any reason the fix isnā€™t used in your BP?
The easiest way is probably to install the blueprint as it is and manually edit the yaml file in your config folder.
Itā€™s in /config/blueprints/automation/jcwillox/automatic_backups.yaml
Tnx, Iā€™ve forked it and added ā€œmy versionā€ / the updated one as a BP. Will test it!
@CentralCommand . Thank you for the great blueprint. I have a question. I receive the update notification in HA under notification panel but I never receive push notification on my phone.
I am using the companion app on IOS 16. I also checked my device id and its correct.
any ideas why I am not getting push notification to my phone even though I am connected locally.
I also dont have any errors under the automation trace
Think you might be hitting this:
Is it just the update notifications you arenā€™t receiving or all of them?
Feature Request: Be able to schedule an update for a time in the future. I would like to update my stuff over night when Iā€™m sleeping.
Youā€™re on the wrong thread, you want this blueprint:
This blueprint is for people that want to manually update after they read the release notes and review the breaking changes. Since thereā€™s some in every release.
