I recently started getting username password errors in my tuya integration. I’ve reset my password, but for the life of me cannot figure out how to change the password in the integration. Any suggestions?
Logger: homeassistant.components.tuya
Source: components/tuya/init.py:120
Integration: Tuya (documentation, issues)
First occurred: 4:22:29 PM (1 occurrences)
Last logged: 4:22:29 PM
Connection error during integration setup. Error: Get accesstoken failed. Username or password error!
I got it to accept the username and pass - it wasn’t saving, but I managed to get it to save now. I cant control the light. I removed and re-added the integration, it found my light, but I still can’t control it. No errors, nothing in the logs. Thoughts? The entity just shows as unavailable.
I have had the same issue. It all started as I tried to experiment with the Beta version of the Tuya supported integration with HA and had to reset my password. When i did this the prior Tuya integration stopped working as password changed. I dont see a /config/.storage file in File Editor and there is no way in the UI to update the password
you have to enable access to the .storage folder, I found instructions via google, can’t remember how.
still can’t get this light to work, although it did previously. The integration finds the light no problem, but it just shows unavailable. I can control it via the smartlife app
thanks for the response - i managed to find my old password and changed it back and it has been behaving since. I am also playing with the Tuya v2 integration now managed by HA which is in beta, requires alot more fiddling around with Tuya IoT account and linking it to a Tuya or Smartlife app account but has proven to be useful - now have RGB control of some wifi lights that i previously didnt have via this one.
Great to hear - Do you have to link some stuff in the tuya iot account to get this working? It was working one day, and then it was not… I have no idea what broke.
Ugh!! I just ran into this issue too. I followed the instructions about editing
config/.storage/core.config_entries
I did have to correct my password in this file. I’d be interested in what tool people used to edit the file. I first opened terminal and copied the file to ./config so that I could access it via Samba and edit is in VisualStudio, then opened terminal again and copied it back to config/.storage. I can confirm that the new date/time on the file is consistent with the date/time I copied it back.
But I still get the following error:
Logger: homeassistant.config_entries
Source: components/tuya/__init__.py:71
First occurred: 17:01:04 (1 occurrences)
Last logged: 17:01:04
Error setting up entry <my_email> for tuya
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 304, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/tuya/__init__.py", line 59, in async_setup_entry
success = await _init_tuya_sdk(hass, entry)
File "/usr/src/homeassistant/homeassistant/components/tuya/__init__.py", line 71, in _init_tuya_sdk
auth_type = AuthType(entry.data[CONF_AUTH_TYPE])
KeyError: 'auth_type'
I can see all the devices in the Tuya app, and can interact with them. But not from HA.
*** SOLVED ***
I was using the country I used for the iot.tuya.com registration rather than the registration location of the Tuya SmartLife app.
*** SOLVED ***
Thanks @francisp. In the end I deleted the Tuya integration, and now I am struggling to reinstall it.
I continue to have issues with home assistant which baffle me, so so much.
I’ve been using HA for several years and frequently things break which make no sense to me at all.
I’ve 100% been using the Tuya integration for at least 12 months, maybe more.
It stopped working 2 days ago.
Reading the instructions here.
It seems to CLEARLY mention, I need a “tuya iot account” which is seperate from the Tuya app account.
I can without question, say I’ve never had one of these and in fact my password manager isn’t coming up with a login for this site. I can’t log in to iot.tuya.com.
Is this a new change? How have I controlled my 5 genio bulbs for 12 to 18 months, without ever having this supposedly required account?
