Updated to 0.91.2 - Client error on WebSocket API (node red) in sys log
When updating to 0.91.2 I got a series of errors in the sys log.
I run hassio on Rpi 3 b+ with the node-red add-on.
Client error on WebSocket API request initialize. It all seems related to node red. Once up and running I have no problems with node red. (The full log is provided below).
My settings for the Node-red add-on are:
  "credential_secret": "redacted",
  "dark_mode": false,
  "http_node": {
    "username": "",
    "password": ""
  "http_static": {
    "username": "",
    "password": ""
  "port": 1880,
  "ssl": true,
  "certfile": "fullchain.pem",
  "keyfile": "privkey.pem",
  "require_ssl": true,
  "system_packages": [],
  "npm_packages": [],
  "init_commands": [],
  "log_level": "info"
In configuration.yaml I have:
  nodered:
    title: Node-Red
    icon: mdi:arrow-expand-right
    url: !secret nodered_url
The bordered_url is:
nodered_url: https://redacted.duckdns.org:1880
Port 1880 is open.
I experience no problems with node-red once home assistant is up and running. However restarting after an update takes a very long time.
What can be the problem?
Sys log
The problem has been going on a number of minutes before this.
19-04-09 08:40:40 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:40:40 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:40:40 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:40:44 INFO (SyncWorker_7) [hassio.docker.interface] Clean homeassistant application
19-04-09 08:40:44 INFO (SyncWorker_7) [hassio.docker.interface] Cleanup images: [‘homeassistant/raspberrypi3-homeassistant:0.91.1’]
19-04-09 08:40:45 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:40:45 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:40:45 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:40:50 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:40:50 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:40:50 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:40:55 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:40:55 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:40:55 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:00 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:00 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:00 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:05 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:05 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:05 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:10 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:10 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:10 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:12 INFO (SyncWorker_3) [hassio.docker.homeassistant] Start homeassistant homeassistant/raspberrypi3-homeassistant with version 0.91.2
19-04-09 08:41:15 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:15 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:15 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:20 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:20 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:20 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:25 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:25 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:25 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:30 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:30 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:30 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:35 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:35 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:35 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:40 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:40 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:40 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:45 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:45 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:45 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:50 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:50 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:50 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-04-09 08:41:55 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:56 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-04-09 08:41:56 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-04-09 08:41:56 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-04-09 08:41:57 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-04-09 08:41:57 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.91.2
Got the same issue, figured it out?
No not yet
Figured it out for me.
Im using Node red 3.0.1 and Home Assistant 91.4.
If you are using a domain like xxxx.duckdns.org or yourdomain.com.
  1. Go directly to your internal IP 192.168.xx.xx:8123
  2. Go to the addon and click open in UI
  3. Node Red will open in home assistant
I have access to Node red but I still get errors upon restart. Let us see what happens when 0.92 comes. I believe it is related to the change to ingress.
Me too. I still get these errors with 0.97.2 version of HA and can access Node Red. Any update?
I also get this error and only for node-red even after disabling SSL (not sure how it is erroring).
Same here, any update?
I have linux server + Hassio with docker. I configured SSL access to integrate with the Google assistant. After that, I can’t open the NodeRed ui. Error 502 after a short period of time. Even disabling ssl, the error continues.
I was getting this error, the details in this post fixed it for me: https://community.home-assistant.io/t/node-red-and-172-30-32-1/142390/4?u=eoin
