I updated the supervisor to supervisor-2022.06.2 on my otherwise up to date HA supervised setup on Debian bullseye (which is btw up to date) and got the “unsupported installation” info.
The “LEARN MORE” button led to Docker Configuration - Home Assistant which listed changes I had to do. The changes to docker were already in the system so I changed the grub setting of GRUB_CMDLINE_LINUX_DEFAULT to “systemd.unified_cgroup_hierarchy=false”
An update showed up and on trying to update the Terminal & SSH add-on I got the error message “Can’t install homeassistant/amd64-addon-ssh:9.5.0: 404 Client Error for http+docker://localhost/v1.41/images/create?tag=9.5.0&fromImage=homeassistant%2Famd64-addon-ssh&platform=linux%2Famd64: Not Found (“manifest for homeassistant/amd64-addon-ssh:9.5.0 not found: manifest unknown: manifest unknown”)”. This means likely that I have to solve the issue with the supervisor to be able to update the add-ons, right?
I did a restart of HA and a reboot but nothing changed. The message "You are running an unsupported installation " is still showing up.
Anyone out the able to help? TIA!!!
Here the system info:
System Health
version: core-2022.6.7
installation_type: Home Assistant Supervised
dev: false
hassio: true
docker: true
user: root
virtualenv: false
python_version: 3.9.12
os_name: Linux
os_version: 5.10.0-15-amd64
arch: x86_64
timezone: Europe/Berlin
GitHub API: ok
GitHub Content: ok
GitHub Web: ok
GitHub API Calls Remaining: 3326
Installed Version: 1.25.5
Stage: running
Available Repositories: 1070
Downloaded Repositories: 90
can_reach_server: ok
remaining_requests: 15
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Debian GNU/Linux 11 (bullseye)
update_channel: stable
supervisor_version: supervisor-2022.06.2
agent_version: 1.2.2
docker_version: 20.10.17
disk_total: 115.9 GB
disk_used: 24.1 GB
healthy: true
supported: failed to load: Unsupported
supervisor_api: ok
version_api: ok
installed_addons: ESPHome (2022.6.2), Home Assistant Google Drive Backup (0.108.2), Studio Code Server (5.1.2), MariaDB (2.4.0), Terminal & SSH (9.4.0), Mosquitto broker (6.1.2), Tor (4.0.0), Uptime Kuma (0.1.0), InfluxDB (4.5.0), Grafana (7.6.0)
dashboards: 5
resources: 10
mode: yaml
oldest_recorder_run: June 6, 2022 at 10:02
current_recorder_run: July 6, 2022 at 12:31
estimated_db_size: 1663.42 MiB
database_engine: mysql
database_version: 10.4.19
