Updating Hassos via USB
Can someone explain to me how to update Hassos through USB? I named my USB drive CONFIG following these instructions and copied hassos_ova-1.8.raucb into the drive, clicked on Import from USB and restarted my pi but nothing happens.
NB, I was able to configure my network through USB though
NB2. My logs: 18-07-29 18:10:15 INFO (MainThread) [hassio.hassos] Sync config from USB on HassOS. 18-07-29 18:10:15 INFO (MainThread) [hassio.host.services] Restart local service hassos-config.service 18-07-29 18:10:15 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.RestartUnit on /org/freedesktop/systemd1
Why did you restart the Pi? I’m 90% sure the Pi will update itself and then restart HA without user intervention. I think you might have rebooted it before it updated. (HassOS is slow too)
I also tried the same steps but without rebooting and leaving it overnight but still no update.
Did you ever fix this issue? I also need to update a machine with no internet access so a USB update would be great.
I was only able to update the supervisor by usb then I let go. Now that I think of it, you can just download the docker image and update it manually.
I know it’s an old thread, but anyone looking for how to update using an USB, should look at this page:
