Good morning,
i remotely upgraded from 0.83 to 0.83.1 an hour ago, and i couldn´t access the web UI with the following error
“Unable to connect to Home Assistant” retry
When accessing over the IP, it asks for my Local Hassio Credentials, but there is nmo response when entering them.
I then went into the SSH console and done a reboot, but get the same errors, plus SSH connection is no more possible
For now, I can´t do a power cycle until afternoon, but maybe someone can see the cause of the problem?
Here is the log file
2018-11-30 09:26:59 WARNING (SyncWorker_15) [homeassistant.components.tahoma] Unsupported type internal:TSKAlarmComponent for Tahoma device Alarm
2018-11-30 09:26:59 WARNING (SyncWorker_15) [homeassistant.components.tahoma] Unsupported type internal:PodV2Component for Tahoma device Sensitive Taste
2018-11-30 09:27:09 WARNING (MainThread) [homeassistant.components.light] Setup of platform flux_led is taking over 10 seconds.
2018-11-30 09:27:10 WARNING (SyncWorker_12) [homeassistant.components.light.flux_led] Failed to connect to bulb 192.168.1.29, LED-TV
2018-11-30 09:27:20 WARNING (SyncWorker_14) [homeassistant.components.light.flux_led] Failed to connect to bulb 192.168.1.30, LED-TISCH
2018-11-30 09:27:20 ERROR (MainThread) [homeassistant.setup] Error during setup of component hassio
File "/usr/local/lib/python3.6/site-packages/homeassistant/setup.py", line 145, in _async_setup_component
hass, processed_config)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/hassio/__init__.py", line 178, in async_setup
user = await hass.auth.async_get_user(data['hassio_user'])
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 118, in async_get_user
return await self._store.async_get_user(user_id)
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 56, in async_get_user
await self._async_load()
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 247, in _async_load
name=group_dict['name'],
KeyError: 'name'
2018-11-30 09:28:12 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_protocol.py", line 390, in start
resp = await self._request_handler(request)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_app.py", line 366, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.6/site-packages/aiohttp/web_middlewares.py", line 106, in impl
return await handler(request)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/static.py", line 66, in staticresource_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/real_ip.py", line 34, in real_ip_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 66, in ban_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/auth.py", line 97, in auth_middleware
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/view.py", line 113, in handle
result = await result
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/http/ban.py", line 76, in handle_req
resp = await func(view, request, *args, **kwargs)
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/auth/__init__.py", line 258, in post
hass, data, str(request[KEY_REAL_IP]))
File "/usr/local/lib/python3.6/site-packages/homeassistant/components/auth/__init__.py", line 346, in _async_handle_refresh_token
refresh_token = await hass.auth.async_get_refresh_token_by_token(token)
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/__init__.py", line 330, in async_get_refresh_token_by_token
return await self._store.async_get_refresh_token_by_token(token)
File "/usr/local/lib/python3.6/site-packages/homeassistant/auth/auth_store.py", line 204, in async_get_refresh_token_by_token
KeyError: 'name'
