Upgrade Issues - 106.5
Hey all,
Went to upgrade home assistant today and ran into some issues.
Has anyone else seen anything like this?
what were the commands that you used to do the update? those aren’t in the screenshot.
sudo hassbian-config upgrade homeassistant
Generating system information…
Home Assistant: 0.106.1
Home Assistant Python: 3.7.3
hassbian-config: 0.13.1
Same problem here trying to upgrade from 0.105.4 -> 0.106.5
First thing I tried was hassbian-config upgrade homeassistant
Output:
Generating system information...
  Home Assistant:        0.105.4
  Linux hassbian 4.19.75-v7+ #1270 SMP Tue Sep 24 18:45:11 BST 2019 armv7l GNU/Linux
Suite:     Home Assistant
Installed: true
Contributed to the project by Lindqvist <https://github.com/Landrash>
Installs the base homeassistant package onto this system.
Checking current version
Setting correct permissions
Upgrading Home Assistant
Changing to homeassistant user...
Changing to Home Assistant venv...
Updating Python dependencies...
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already up-to-date: pip in /srv/homeassistant/lib/python3.7/site-packages (20.0.2)
Requirement already up-to-date: setuptools in /srv/homeassistant/lib/python3.7/site-packages (46.0.0)
Requirement already up-to-date: wheel in /srv/homeassistant/lib/python3.7/site-packages (0.34.2)
Installing Python packages...
ERROR: Could not find a version that satisfies the requirement homeassistant== (from versions: 0.7.0rc1, 0.7.0, 0.7.0.1, 0.7.1, 0.7.2, 0.7.3, 0.7.4, 0.7.5, 0.7.6, 0.7.7, 0.8.0, 0.9.0, 0.9.1, 0.10.0, 0.10.1, 0.11.0, 0.11.1, 0.12.0, 0.13.0, 0.13.1, 0.14.0, 0.14.1, 0.14.2, 0.15.0, 0.16.0, 0.16.1, 0.17.0, 0.17.1, 0.17.2, 0.17.3, 0.18.2, 0.19, 0.19.1, 0.19.2, 0.19.3, 0.19.4, 0.20.0, 0.20.1, 0.20.2, 0.20.3, 0.21.0, 0.21.1, 0.21.2, 0.22.0, 0.22.1, 0.23.0, 0.23.1, 0.24.0, 0.24.1, 0.25.0, 0.25.1, 0.25.2, 0.26.0, 0.26.1, 0.26.2, 0.26.3, 0.27.0, 0.27.1, 0.27.2, 0.28.0, 0.28.1, 0.28.2, 0.29.0, 0.29.1, 0.29.2, 0.29.3, 0.29.4, 0.29.5, 0.29.6, 0.29.7, 0.30.0, 0.30.1, 0.30.2, 0.31.0, 0.31.1, 0.32.0, 0.32.1, 0.32.2, 0.32.3, 0.32.4, 0.33.0, 0.33.1, 0.33.2, 0.33.3, 0.33.4, 0.34.0, 0.34.1, 0.34.2, 0.34.3, 0.34.4, 0.34.5, 0.35.0, 0.35.1, 0.35.2, 0.35.3, 0.36.0, 0.36.1, 0.37.0, 0.37.1, 0.38.0, 0.38.1, 0.38.2, 0.38.3, 0.38.4, 0.39.0, 0.39.1, 0.39.2, 0.39.3, 0.40.0, 0.40.1, 0.40.2, 0.41.0, 0.42.0, 0.42.1, 0.42.2, 0.42.3, 0.42.4, 0.43.0, 0.43.1, 0.43.2, 0.44.0, 0.44.1, 0.45.0, 0.45.1, 0.46.0, 0.46.1, 0.47.0, 0.47.1, 0.48.0, 0.48.1, 0.49.0, 0.49.1, 0.50.1, 0.50.2, 0.51.0, 0.51.1, 0.51.2, 0.52.0, 0.52.1, 0.53.0, 0.53.1, 0.54.0, 0.55.0, 0.55.1, 0.56.0, 0.56.1, 0.56.2, 0.57.0, 0.57.1, 0.57.2, 0.57.3, 0.58.0, 0.58.1, 0.59.0, 0.59.1, 0.59.2, 0.60.0, 0.60.1, 0.61.0, 0.61.1, 0.62.0, 0.62.1, 0.63.0, 0.63.1, 0.63.2, 0.63.3, 0.64.0, 0.64.1, 0.64.2, 0.64.3, 0.64.4b0, 0.65.0, 0.65.1, 0.65.2, 0.65.3, 0.65.4, 0.65.5, 0.65.6, 0.66.0b0, 0.66.0b1, 0.66.0b2, 0.66.0b3, 0.66.0, 0.66.1b0, 0.66.1, 0.67.0b0, 0.67.0b1, 0.67.0, 0.67.1, 0.68.0b0, 0.68.0b1, 0.68.0b2, 0.68.0, 0.68.1, 0.69.0b0, 0.69.0b1, 0.69.0b2, 0.69.0b3, 0.69.0, 0.69.1, 0.70.0b0, 0.70.0b1, 0.70.0b2, 0.70.0b3, 0.70.0b4, 0.70.0b5, 0.70.0b6, 0.70.0b7, 0.70.0, 0.70.1, 0.71.0b0, 0.71.0, 0.72.0b0, 0.72.0b1, 0.72.0b2, 0.72.0b4, 0.72.0b5, 0.72.0b6, 0.72.0b7, 0.72.0b8, 0.72.0b9, 0.72.0, 0.72.1, 0.73.0b0, 0.73.0b1, 0.73.0b2, 0.73.0b3, 0.73.0b4, 0.73.0b5, 0.73.0b6, 0.73.0, 0.73.1, 0.73.2, 0.74.0b0, 0.74.0b2, 0.74.0b3, 0.74.0b4, 0.74.0, 0.74.1, 0.74.2, 0.75.0b0, 0.75.0b1, 0.75.0, 0.75.1, 0.75.2, 0.75.3, 0.76.0b0, 0.76.0b1, 0.76.0b2, 0.76.0b3, 0.76.0b4, 0.76.0b5, 0.76.0, 0.76.1, 0.76.2, 0.77.0b0, 0.77.0b1, 0.77.0b2, 0.77.0b3, 0.77.0b4, 0.77.0, 0.77.1, 0.77.2, 0.77.3, 0.78.0b0, 0.78.0b1, 0.78.0b2, 0.78.0b3, 0.78.0, 0.78.1, 0.78.2, 0.78.3, 0.79.0b0, 0.79.0b1, 0.79.0b2, 0.79.0b3, 0.79.0, 0.79.1, 0.79.2, 0.79.3, 0.80.0b0, 0.80.0b1, 0.80.0b2, 0.80.0b3, 0.80.0b4, 0.80.0b5, 0.80.0, 0.80.1, 0.80.2, 0.80.3, 0.81.0b0, 0.81.0b1, 0.81.0b2, 0.81.0, 0.81.1, 0.81.2, 0.81.3, 0.81.4, 0.81.5, 0.81.6, 0.82.0b0, 0.82.0b1, 0.82.0b2, 0.82.0b3, 0.82.0b4, 0.82.0, 0.82.1, 0.83.0b0, 0.83.0b1, 0.83.0b3, 0.83.0, 0.83.1, 0.83.2, 0.83.3, 0.84.0b0, 0.84.0b1, 0.84.0b2, 0.84.0b3, 0.84.0b4, 0.84.0, 0.84.1, 0.84.2, 0.84.3, 0.84.4, 0.84.5, 0.84.6, 0.85.0b0, 0.85.0b1, 0.85.0, 0.85.1, 0.86.0b0, 0.86.0b1, 0.86.0b2, 0.86.0b3, 0.86.0, 0.86.1, 0.86.2, 0.86.3, 0.86.4, 0.87.0b0, 0.87.0b1, 0.87.0b2, 0.87.0b3, 0.87.0b4, 0.87.0b5, 0.87.0b6, 0.87.0, 0.87.1, 0.88.0b0, 0.88.0b1, 0.88.0b2, 0.88.0b3, 0.88.0b4, 0.88.0, 0.88.1, 0.88.2, 0.89.0b0, 0.89.0b1, 0.89.0b2, 0.89.0b3, 0.89.0, 0.89.1, 0.89.2, 0.90.0b0, 0.90.0b1, 0.90.0b2, 0.90.0b3, 0.90.0b4, 0.90.0b5, 0.90.0b6, 0.90.0b7, 0.90.0, 0.90.1, 0.90.2, 0.91.0b0, 0.91.0b1, 0.91.0b2, 0.91.0b3, 0.91.0b4, 0.91.0b5, 0.91.0, 0.91.1, 0.91.2, 0.91.3, 0.91.4, 0.92.0b0, 0.92.0b1, 0.92.0b2, 0.92.0b3, 0.92.0, 0.92.1, 0.92.2, 0.93.0b0, 0.93.0b1, 0.93.0b2, 0.93.0b4, 0.93.0, 0.93.1, 0.93.2, 0.94.0b0, 0.94.0b1, 0.94.0b2, 0.94.0b3, 0.94.0b4, 0.94.0b5, 0.94.0b6, 0.94.0b7, 0.94.0b8, 0.94.0, 0.94.1, 0.94.2, 0.94.3, 0.94.4, 0.95.0b0, 0.95.0b1, 0.95.0b2, 0.95.0b3, 0.95.0b4, 0.95.0, 0.95.1, 0.95.2, 0.95.3, 0.95.4, 0.96.0b0, 0.96.0b1, 0.96.0b2, 0.96.0b3, 0.96.0b4, 0.96.0, 0.96.1, 0.96.2, 0.96.3, 0.96.4, 0.96.5, 0.97.0b0, 0.97.0b1, 0.97.0b2, 0.97.0b3, 0.97.0, 0.97.1, 0.97.2, 0.98.0b0, 0.98.0b1, 0.98.0b2, 0.98.0, 0.98.1, 0.98.2, 0.98.3, 0.98.4, 0.98.5, 0.99.0b0, 0.99.0b1, 0.99.0b2, 0.99.0b3, 0.99.0b4, 0.99.0, 0.99.1, 0.99.2, 0.99.3, 0.100.0b0, 0.100.0b1, 0.100.0b2, 0.100.0b3, 0.100.0, 0.100.1, 0.100.2, 0.100.3, 0.101.0b0, 0.101.0b1, 0.101.0b2, 0.101.0b3, 0.101.0b4, 0.101.0, 0.101.1, 0.101.2, 0.101.3, 0.102.0b0, 0.102.0b1, 0.102.0b2, 0.102.0b3, 0.102.0, 0.102.1, 0.102.2, 0.102.3, 0.103.0b0, 0.103.0b1, 0.103.0, 0.103.1, 0.103.2, 0.103.3, 0.103.4, 0.103.5, 0.103.6, 0.104.0b0, 0.104.0b1, 0.104.0b2, 0.104.0b3, 0.104.0b4, 0.104.0b5, 0.104.0, 0.104.1, 0.104.2, 0.104.3, 0.105.0b0, 0.105.0b1, 0.105.0b2, 0.105.0b3, 0.105.0b4, 0.105.0b5, 0.105.0b6, 0.105.0b7, 0.105.0, 0.105.1, 0.105.2, 0.105.3, 0.105.4, 0.105.5, 0.106.0b0, 0.106.0b1, 0.106.0b2, 0.106.0b4, 0.106.0b5, 0.106.0, 0.106.1, 0.106.2, 0.106.3, 0.106.4, 0.106.5)
ERROR: No matching distribution found for homeassistant==
Deactivating virtualenv...
Restarting Home Assistant
Checking the installation...
Operation completed...
Note that it may take some time to start up after an upgrade.
Now I’m trying upgrading via pip (seems to be taking a very long time)
homeassistant@hassbian:~ $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@hassbian:~ $ pip3 install --upgrade homeassistant
Sorry forgot to report back last night. As mentioned above the hassbian-config upgrade ... failed.
However upgrading using pip worked:
since Hassbian has been deprecated the scripts are no longer being maintained so you will likely start to see that more of the scripts no longer work.
But as you found out you can still update your Hassbian using the manual commands and that should continue to always work.
