It doesn’t really mean that it ain’t working, do you see data when you hit ‘logs’? A common reason it doesn’t become ‘available’ is due to mDNS issues in your router (using a fixed IP solves it in mist cases) as Nickrout said, did it compile and upload?
If you do see logs, the esp unit probably popped up under ‘integrations’
