Yes. That’s right. Are there other statuses that can be reported? It’s been a while since I developed this. At the time i thought there were only on and off statuses reported by UptimeKuma.
Ok, neat. Right now the integration only exposes a binary sensor, so it’s just on and off, but contributions are definitely welcome!
I’ll take it as is, I have nothing to offer, pure noob, thanks for sharing.
could you share the code? thanks
type: logbook
title: History Stats
hours_to_show: 12
entities:
- sensor1
- sensor2
- etc...
I’ve added the custom integration via HACS but don’t really see any information on how to set it up.
So, something went wrong earlier this morning, and not all monitors were being reported to HA, they all came back after reloading the integration, nothing in logs as well.
Go to, Configuration > Devices and Service > Add Integration (bottom right), then search for uptime kuma.
All outlined in the repo GitHub - meichthys/uptime_kuma: Uptime Kuma HACS integration
Hmm, it’s not there.
I already tried to re-install the HACS integration itself.
Of course I have rebooted after the installation. It’s showing no errors.
Something must be missing.
Yet another re-install and the update to 2022.6.6 (the update took care of the reboot) suddenly made the integration appear.
Very weird.
For unknown reasons I do not see any entities, though. Yes, I know they are not shown directly. But even when searching for them in the developers section, I do not find any.
hmm …
Dieser Fehler wurde von einer benutzerdefinierten Integration verursacht
Logger: aiohttp.server
Source: custom_components/uptime_kuma/config_flow.py:55
Integration: Uptime Kuma
First occurred: 13:19:59 (2 occurrences)
Last logged: 13:20:12
Error handling request
File "/usr/local/lib/python3.9/site-packages/uptime_kuma_monitor.py", line 30, in update
response = requests.get(
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 75, in get
return request('get', url, params=params, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
return session.request(method=method, url=url, **kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 529, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 639, in send
adapter = self.get_adapter(url=request.url)
File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 732, in get_adapter
raise InvalidSchema("No connection adapters were found for {!r}".format(url))
requests.exceptions.InvalidSchema: No connection adapters were found for '192.168.178.63:3001/metrics'
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 435, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 79, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 220, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 137, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 205, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 109, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 260, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 335, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/uptime_kuma/config_flow.py", line 55, in async_step_user
utkm = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
File "/usr/local/lib/python3.9/site-packages/uptime_kuma_monitor.py", line 26, in __init__
self.update()
File "/usr/local/lib/python3.9/site-packages/uptime_kuma_monitor.py", line 41, in update
raise UptimeKumaError(
uptime_kuma_monitor.UptimeKumaError: Could not fetch Uptime Kuma metrics: No connection adapters were found for '192.168.178.63:3001/metrics'
Did you enter the above as the url?
No, I entered http://192.168.178.63 and port 3001 in the configuration.
When I open http://192.168.178.63/metrics manually, I get usable data, though.
Hi meichthys,
I’m really struggling getting this installed. I’ve tried adding the custom repo to HACS as usual and nothing happens. I’ve also tried manually downloading the code into the custom components folder - it is listed in the HA log file at startup, but I can’t add the integration.
Any ideas what might be preventing this from being installed?
Try using an older HACS version. I’m not familiar with the newest changes since they were merged in from a recent pull request.
Can someone help me to use this data into sensors?
monitor_status{monitor_name="qBittorrent VPN",monitor_type="ping",monitor_url="https://",monitor_hostname="qbittorrent_vpn",monitor_port="null"} 1
monitor_status{monitor_name="Bazarr",monitor_type="ping",monitor_url="https://",monitor_hostname="bazarr",monitor_port="null"} 1
hello is there a way to link uptime kuma to the uptime custom card from hacs please ?
How to monitor servers in Home Assistant - Share your Projects! - Home Assistant Community (home-assistant.io)
would be great to have a simple full tutorial
for une sensor from kuma to uptime custom card for beginners like me, please
hello impossible to add uptime kuma integration to hacs, because archived repo ?
when i click add in HACS nothing happens, then when i try to add integration
there is no uptime kuma in the list
uptime kuma is installed and i have some monitored servers,
but impossible to add sensors into HA
