Urmet intercom signalling
I used to have a simple one-wire intercom which I automated with a ESP32 and a relay to remotely open the door.
It was changed to a modern intercom that does the same thing, but more complicated :slight_smile: Namely the Urmet MIOR 2Voice 1183/7
This device does not simply shorts the wire anymore, it probably sends a signal (or shorts a pin) and I was wondering if someone has ever deal with it. I saw other posts that are not that far away, but did not get responses:
Since the buttons are physical, I could ultimately look at making the “press” close to the button but if someone has had any more lunch I would be delighted to learn from your successes :slight_smile:
Would be much easier to connect to door unit.
Would you mind to elaborate? I am not sure I understand
outdoor phone/bell unit. They have analog contacts to door lock.
Ah, this is not possible. This is an apartment and the door is too far away (not to mention that I do not have access to it)
Then you need to physically connect to button contacts/wires.
Looking at the PDF… GT XI and Y1 are your connections for the buttons and CP is for the intercom at the entrance side whist S- and S+ are the ringer leaving Line for circuit:
Thanks. I will have to measure that because I am not sure that shorting CP is enough to trigger the opening of the door (I have a bad feeling that this will be a composite signal, not just a shorting)
It’s for doorbell.
Can’t you open the device and have a look at the button?
Most likely it’s just a PCB type button
Did you find a solution here?
Unfortunately not.
I am considering either trying to dismantle the box to get to the buttons as @Hellis81 suggested, or to build a mechanical contraption that will press the buttons.
I would prefer solution 1 but I need to take some time to carefully unscrew the device and even more carefully solder around with the bix hanging on the wall
Any updates on this?? I have the same 2voice system but with a screen, will try mess about with it this weekend.
I did not have the time yet to do that - I would be glad to know what you found out when opening the device. Would you mind taking a picture once it is opened? (I do not have the screen but I gues that just an extra signal and the opening is managed the same for all systems)
Finally had a look at this. Not good news. PCB button pad wiring is the only hope, unless we reverse engineer the whole 2voice system and tap into the BUS lines.
Ah. You opened it? Would you happen to have taken a photo of the PCB?
I will try this summer to make the remote work (probably a web app and a HA connector)
Hello everyone,
I have a Urmet 1702 with video and I would like to integrate this in my Home Assistant server, I never used a ESP module, but I have done many other nice things, however, does anyone know if this can be done and what kind of ESP I have to buy?
The problem with this device is that it uses a specific modulated signal to do stuff (in my case opening the door). It is not a matter to just short cables (as it was the case in my previous system).
So either you have to measure these signals and replay them (this is out of my league but should be doable for someone knowledgeable - there is no rotation of codes or anyhing like that), or go the dumb way like me and design a mechanical “presser” that will both react to Home Assistant and have mechanical buttons that will trigger the mechanism. This is WIP, I restarted it literally yesterday after an idea of my father about how to design the mechanical part. I will opensource it once it is done (the 3dprinting models, the hw and the sw)
Thank you very much for your info.
What do you mean for send the right signals?
Do you mean in volts? Like 3v or 5v?
No, I mean that the “open the door” message is not simply a shortcut on the active wire(*) but it is a true code sent from client intercom to the manager via a bus. If you shortcut the wires the whole system crashes and will reboot (don’t do it :)).
It means that you need to measure the signal when you press the “open door” button and extract the code if you want to replay it to the manager.
In the case of my intercom it is even worse: I need to first click on the “spek” button, then on the “open door” one, and again on the “speak” button. This means that I simply cannot just open the door by pressing the relevant button. Worse: I cannot press speak, door, speak without someone first initiating the service by calling my apparemment. This is a piece of crap.
(*) which is typically the case for simple intercoms, and you usually get a bunch of wires out of which only 2 or 3 are actually used – but this depends on plenty of things
