I have integrated my KNX installation into HA via a (growing) knx.yaml.
I have my KNX thermostates controlled via the “climate” tag. My KNX temperature sensors have group addresses mentioned there:
- name: bathroom
temperature_address: 8/3/152
target_temperature_state_address: 8/1/106
operation_mode_address: 8/4/116
operation_mode_state_address: 8/4/106
active_state_address: 8/7/106
Can I use the temperature sensor made available here via temperature_address separately as an entity?
Or do I need to configure a “sensor” section with the same group address in parallel again? Like
- name: bathroom temperature
state_address: 8/3/152
state_class: measurement
type: temperature
device_class: temperature
sync_state: expire 240
I would like to avoid double configuration if not necessary.
Thanks.
