Hi
I’m curious to buy Aqara Smart Lock U200 and I have read it have support for Matter.
The problem is that I have never work with Matter before and this maybe going to be the first matter device I going to use.
My question is, can I use the “Home-Assistant-Matter-Hub” to connect to this device or do I need to buy some Matter Hub hardware and connect that to my Home Assistant?
I maybe later buy some other Matter device but right now I all my device is Wifi or Zigbee (I also have Z-wave JS but have no device connect to it).
Matter is an application layer protocol, so no you don’t need a Matter hub. What you do need is a Thread border router, which is the hardware layer protocol this lock uses.
I have SONOFF Zigbee 3.0 USB Dongle Plus V2 for my zigbee so what I understand with a flashing it can use that as Thread border router.
When I look in the add-ons in the HA I have see I have Matter Server installed.
I guess it have install with the “Home Assistant-Matter-Hub” so not so sure what to do.
Assuming you don’t already use the dongle with Zigbee, then yes you can reflash the dongle to speak Thread instead. But don’t reflash it with the combined Zigbee+Thread firmware, when I last read anything about that was very much not recommended (yet, at least).
The chipset in the dongle is not powerful enough to fully handle both protocols simultaneously. In the combined mode, the dongle only deals with radio communication, with the rest of the protocol intricacies offloaded to the driver on the computer – and that seems to not quite work reliably yet, and may not for a long time (or never).
Also suggest you read up on some other threads on how well the lock works or not with Home Assistant before making any purchase, as well as some hints about how to set it up. If you want to use Apple HomeKey for example it cannot be connected directly to HASS, it must be connected to a HomeKit Hub (Apple TV or HomePod) which will act as the Thread border router and then make the lock available to HASS over Matter.
Well yes I did read that and also it does use Zigbee now that I don’t want to have problem with. Did read that I have to repare all my devices and that is not fun
So maybe is better that I buy a new router to add to my HA.
Maybe buy a Home Assistant Connect ZBT-1.
or maybe buy Nest Hub (Have thinking maybe buy one and have it show HA and even use it with Google Assistant)
Well that I was looking to get in the HA is the status of the battery and if the door is lock or unlock. That basic stuff have to work what I have see.
I also did read this
He is using the homekit integration to send HA devices to Homekit
Personally I use it different, connected it with Matter to Homekit and then make it a shared device for Home Assistent… this way I can remove either from the mix and everything still keeps working (I’m using this method for all matter devices, Homekit works way better this way than using the homekit integration with HA)
Been using it for 2 months now and I’m not even using Home key… fingerprint is freaking faster and easier
Guys i also want to go this route of skyconnect and u200. but worried about the range for this dongle as the HA machine is in one room and the lock …well its in the home door. can anyone have ideas how to extend the range if needed ?
(BTW the HA room is concrete bomb shelter , so radio is quite hard to get in there)
