Use Nabu Casa URL to use HA API?
Ok… So I managed to get this working both locally and via the Nabu Casa URL.
It would be useful if this was more integrated with the API and/or Logger(?) so you could define the URL.
This method works great but as you can probably tell - I’m not too familiar with ESP … yet.
Use:
To send data to Home Assistant via Nabu Casa’s remote access (or other alterative) from any ESP device that has a WiFi connection.
This means you can connect to any WiFi network and send updates remotely.
Requirements:
-You must have remote connection on your Home Assistant (e.g. Nabu Casa)
Example: https://YOUR_NABU_CASA_URL_HERE.ui.nabu.casa
-Generate a Long-Lived Access Token
– This is stored in the secrets.yaml as bearer_token
Substitutions / basic config
Firstly I checked everything was working good with the local IP.
I then changed the code (as-is now) to work with the Nabu Casa IP.
I’ve also included some basic config for the espnodemcu.
substitutions:
  hostname: AnyTestName
  BearerLocalIP: http://YOUR_LOCAL_IP_HERE:8123
  NabuCasaAddress: https://YOUR_NABU_CASA_URL_HERE.ui.nabu.casa
  BearerSensorName: sensor.YOUR_SENSOR_NAME_HERE
esphome:
  platform: ESP8266
  board: nodemcuv2
logger:
api:
ota:
web_server:
  port: 80
wifi:
  ssid: !secret wifi_ssid
captive_portal:
Adding a test sensor
I added the Uptime Sensor on the ESP as a test to send the data over the HTTP command.
This uses the ID ‘uptime_sensor’ which is used in the HTTP command but this can be changed to which ever ID you like.
  - platform: uptime
    name: $hostname Uptime Sensor
    update_interval: 60s
    on_raw_value:
      then:
        - text_sensor.template.publish:
            state: !lambda |-
              int seconds = round(id(uptime_sensor).raw_state);
              int days = seconds / (24 * 3600);
              seconds = seconds % (24 * 3600);
              int hours = seconds / 3600;
              seconds = seconds % 3600;
              int minutes = seconds /  60;
              seconds = seconds % 60;
              return (
                (days ? to_string(days) + "d " : "") +
                (hours ? to_string(hours) + "h " : "") +
                (minutes ? to_string(minutes) + "m " : "") +
                (to_string(seconds) + "s")
              ).c_str();
Adding a Button to call the HTTP command
I then added a test Button which would call the HTTP on press.
button:
  # Button on press calls the http command
    on_press:
        then:
        - http_request.post:
              method: POST
              ## Change IP and Sensor name within the substitutions
              ## You can use the local or remote IP
              ## Remember the URL has /api/states/ hard coded
              url: $NabuCasaAddress/api/states/$BearerSensorName
              headers:
                Authorization: !secret bearer_token
                Content-Type: application/json
              verify_ssl: false
              json:
              ## You can customize this part but remember to include 'state'
               root["state"] = id(uptime_human).state;
               ## Add more data / attributes here
               ## Refer to Home Assistant API Docs
               ## https://developers.home-assistant.io/docs/api/rest/
