Currently a user can define a time format only:
![image](https://community-assets.home-assistant.io/original/4X/1/b/e/1beccab8b344e2d21f2cacd7c06a30d1a12b11eb.png)
When language is set to “English”, we get the “MM / DD / YYYY” presentation of date:
![image](https://community-assets.home-assistant.io/original/4X/e/a/7/ea70eba72ecf0d16b12c9db4985a064a88f91e50.png)
When language is set to “Russian”, we get the “DD.MM.YYYY” presentation of date:
![image](https://community-assets.home-assistant.io/original/4X/4/d/b/4dbeeb5009e9f74c9363229c938f3ea85f7c99f9.png)
Unfortunately, I cannot use English and “DD.MM.YYYY” simultaneously.
I propose to add a “Date format” selection field.
EdwardTFN
(Edward Firmo)
2
Have you tried English (GB)
as a language? This is what I use and I never noticed a date in MM/DD/YYYY.
Thanks a lot for the advice!
It works.
English:
![image](https://community-assets.home-assistant.io/original/4X/7/b/5/7b54c62143f032a72b7932267a04aa64875f5eba.png)
English (GB):
![image](https://community-assets.home-assistant.io/original/4X/b/a/1/ba13a12b09dca0a572ccd4267332f14dd51748d9.png)
But anyway - assume someone wants to see the “DD.MM.YYYY” format - then the “Date format” settings will be useful…
EdwardTFN
(Edward Firmo)
4
Indeed, user’s should be able to select date format. I’ve voted already! ![:slight_smile: :slight_smile:](https://community.home-assistant.io/images/emoji/twitter/slight_smile.png?v=10)
tom_l
6
Closing as a duplicate of the post linked above. Please vote and comment there.
