when i put the key and cert in the ssl dir and tell home assistant about it the core wont load. errors on cant read key. any suggestions would be appricaited. I have added ips to the cert as well .
When I have the wrong file names as directly copied from the lets encrypt doc the check config errors. when I have this which is correct I get the green light for restarting.
Recovery Mode Activated.
is what I get when I restart the server.
Per the logs
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 425, in _create_ssl_context
context.load_cert_chain(self.ssl_certificate, self.ssl_key)
ssl.SSLError: [SSL] PEM lib (_ssl.c:3896)
File "/usr/src/homeassistant/homeassistant/setup.py", line 333, in _async_setup_component
result = await task
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 202, in async_setup
await server.async_initialize(
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 342, in async_initialize
self.context = await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.12/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/http/__init__.py", line 428, in _create_ssl_context
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Could not use SSL certificate from /ssl/hassio.pem: [SSL] PEM lib (_ssl.c:3896)
Does /ssl/hassio.pem contain the full chain of trust?
You have to put in here your signed certificate + the certificates of the CA and intermediate CA’s in reverse order (ie certificate / intermediate / CA)
probably not as I took that pem straight from the signing. in my case the root ca for freeipa was the one that signed so I would need to append that to the end of the pem file if I understand you corretly?
To combine these into a single file that EFT Server supports, use the following commands in OpenSSL:
c:\> openssl x509 -inform PEM -in "hassio.crt" -text > hassio.pem
c:\> openssl x509 -inform PEM -in "Domain.crt" -text >> hassio.pem
It’s quite rare that a “leaf” certificate is directly signed by the CA, though (usually, there are intermediate CAs as well), but it’s technically valid.
The CA surely documents that extremely common process somewhere.
is FreeIPA’s method. one of my browsers is being stupid but thats a whole other story. I had to remove all extra bits for openssl but thats a freeipa thing no HA
