Using CATT
Argh, same issue here. Now my Hub is completely useless. Why do Google keep annoying their customers with these non-configurable devices? I will never buy a Google product again.
Same 30 seconds timeout issue here under Google Hub firmware version 1.52.26.
My one unit with 1.52.25 is working but the one that was on preview 1.52.26 seems to die around the 20 second mark. If i get home assistant to try and refresh sooner then it just seems to make the cast stop sooner. I think when I get these working they will be blocked from the internet. Would never buy them again
Same here – its very irritating!
Same issue here - following this topic.
Same 30s timeout issue here on nest hub (1st gen) on firmware 1.52.260996.
Not experiencing same issue on nest hub max on firmware 1.54.250320.
Such a pain!
How do I stop the hub max from updating! I literally just got it to a place where I’m super happy with my screen for that.
What I don’t understand is what it is about CATT that causes the timeout? Casting sites from other things as usual doesn’t appear to timeout Not even static webpages, so why does this? There must be something that can be done to fix it!
Is it the cast_site option instead of just cast? Or the hub’s web browser?
def cast_site(settings, url):
    cst = setup_cast(
        settings["selected_device"],
        controller="dashcast",
        action="load_url",
        prep="app",
As mentioned above touching the screen keeps it online. Interested if there’s a way to simulate this too.
Is there a way to send controls through dashcast. I know you can send pause commands etc to videos, but if you try that after casting site it says “action not supported by the dashcast controller”
It was also mentioned on the Home Assistant Cast discussion that perhaps there’s a way to set disableIdleTimeout to true when casting webpages?
Or perhaps maxInactivity?
Totally agree with you, previous 10 mins is already annoying, this 30 seconds timeout just make nest hub useless…
is there a way to downgrade the firmware of google hub? or a solution to bypass 30 seconds timeout?
having the same issue on 2 of my 3 nesthubs… guess the 3rd will get there soon also.
Been trying to figure out a resolution, following this
I’ve opened a feature request on GitHub a short time ago for disableIdleTimeout being added to pychromecast.
Unfortunately I can not test things at the moment, but it would be helpful if any of you would join the issue and would give a hand to @emontnemery.
Tagging those people who would be interested in a fix for the 30 seconds timeout:
@Daniel_Cook, @NeilsOnWheels, @mjm8975, @Gergo.io, @ysoudy, @erikkt, @lacko, @sh00t2kill, @jonaseymour
Did anyone find a workaround yet?
If this issue cannot be resolved from the casting apps side, but has to be solved from the Nest Hub side, then it might worth to start a topic on the new Google Nest Community Forum:
https://www.googlenestcommunity.com/
Maybe the developers would pick up the issue to resolve on their side.
Did you create a topic with them? Ive seen topics before about things there, never to be resolved.
I take it back, it was working for 1 hour or 2 and stopped again
1.52.26.
Blockquote
It seems it is working now, photo mode did not kick in after 30 secs…
Blockquote
OS Version of the hub?
I am also struggling to get my Lovelace on my Google hub.
I’ve the following in my config regarding auth profiders:
 auth_providers:
    - type: trusted_networks
      trusted_networks:
        - 192.168.1.249/32
      trusted_users:
        192.168.1.249: fc3575bfb47b4c....
      allow_bypass_login: true
    - type: homeassistant
The ip address is the address of the HUB.
I’ve setup duckdns so I can access my home assistant from outside my network.
If i try to cast to the google hub the following way I get a login screen:
catt -d 192.168.1.249 cast_site https://xxx.duckdns.org:8123/lovelace/default_view
If I try with my internal IP i see the cast loading screen and the shuts down. Home Assistant isn’t shown at all.
catt -d 192.168.1.249 cast_site https://192.168.1.100:8123/lovelace/default_view
If I try to cast it to my TV using the internal IP it freezes on de cast loading screen
What’s the name of the google hub? i.e. “Living Room Display”
Try using that instead of the IP address in the shell command.
re: trusted_networks. Try using 192.168.1.0/24 instead. I don’t use trusted_users so can’t comment on that bit.
I anyone able to help with some shell comment syntax? I currently have the code below (from john2014) to only cast when the hub is not playing anything. But the hub is also linked to an audio group that I would also like to put in the conditional.
if ! catt -d "Kitchen display" status | grep 'PLAYING'; then
    catt -d "Kitchen display" volume 0
    catt -d "Kitchen display" cast_site http://192.168.xx.xx:8123/lovelace/nest_max
    catt -d "Kitchen display" volume 5
fi
How do I change that first line to be if either ‘Kitchen display’ OR ‘Kitchen speakers’ is not ‘PLAYING’, then run the code?
Is your “auth_providers:” configured inside the configuration.yaml? Are you missing the “homeassistant:” part?
homeassistant:
  auth_providers:
      trusted_networks:
        - 192.168.1.249/32
      trusted_users:
