Using Google Home for setting up a radio alarm
I have set up Google Assistant (https://home-assistant.io/components/google_assistant/) and Chromecast Radio project (Chromecast Radio with station and player selection) successfully but I don’t know how I could combine them to tell one of my Google Home Mini “Hey Google, set radio alarm at 7am” or something similar which will play a radio stream on every Google Home (Mini) device at 7am the next morning.
Is that possible and if yes, how?
Thanks in advance!
Yes that’s possible.
For setting your alarm time you could IFTTT with a http post command per webhook as “that”.
Here’s an example of my current wakeuplight radio:
Thanks, but I don’t need any input selectors in the frontend nor do I need different radio stations.
I just want to use voice input for setting up the alarm.
Here is my first approach but that one is missing a few things: Set up a radio alarm timer with IFTTT
How can I accomplish it?
Hope this helps. https://support.google.com/googlehome/answer/7071598?hl=en
Thanks, but that doesn’t help in Germany because the feature is not yet activated here…
