Using MQTT messages as triggers
Ok, I think I got the idea of blueprints.
I have several automations that are almost identical that link a Aqara Zigbee button to a group of lights. When I do a single click on it, the light toggles state, like this:
- id: '1607725222698'
  alias: Quarto do Murilo -- mudar o estado do lustre
  description: ''
  - platform: mqtt
    topic: zigbee2mqtt/BTQuartoMurilo/action
    payload: single
  - service: light.toggle
    entity_id: light.lustre_do_quarto_do_murilo
  mode: single
I believe that the input elements will be the MQTT topic and the light entity, right?
How can I do a bluprint for this? I think in something like this:
blueprint:
  name: Muda estado de luzes com botao Aqara
  domain: automation
  input:
    botao:
    lustre:
  platform: mqtt
  topic: zigbee2mqtt/{{!input botao}}/action
  payload: single
  entity_id: !input lustre
What is the right way of using a MQTT topic as a trigger for a blueprint?
Thanks!
Why several automations and not just one that toggles the appropriate light based on the received payload?
The payload is the same (single). What varies is the mqtt topic
    topic: zigbee2mqtt/+/action
For more information, see Wildcards.
The action can determine which topic was responsible for the trigger by parsing trigger.topic.
EDIT
Let me know if you want help creating the all-in-one automation.
Thanks! I did not think about using wildcards. I will rewrite the automations to use wildcard. :slight_smile:
But my doubt remains: how can I use a Mqtt topic as input for a blueprint?
If you create the all-in-one automation I am proposing, you don’t need a blueprint.
EDIT
For what I have in mind, I would need more examples of the association between the topic and the entity. For example, if the topic contains BTQuartoMurilo it is associated with the light called lustre_do_quarto_do_murilo. I need more associations like that to create the automation.
I would have thought that with Z2M exposing native entities in homeassistant it would be more logical to use a state trigger for your blueprint.
Users can then feed the entity_ids of their buttons into the automations that use your blueprint.
Regardless of whether you SHOULD do this, the reason it’s not working is several things.
  1. I don’t believe mqtt triggers support templates in the topic
  2. if it does allow templates in the topic, you’d need quotes around it
  3. templates don’t support inputs, so you need to convert it to a variable.
So, you can entire the FULL topic as the input and use topic: !input botao in your MQTT trigger. Or… you can use conditions and variables, like this:
blueprint:
  description: MQTT Test
  domain: automation
  input:
    topic_piece:
mode: restart
max_exceeded: silent
variables:
  topic_piece: !input topic_piece
  platform: mqtt
  topic: "test/+"
  - condition: template
    value_template: "{{ trigger.topic == 'test/' + topic_piece }}"
  - service: input_text.set_value
      entity_id: input_text.test_1
      value: "{{ trigger.payload }}"
Got it. Thanks!
If I have a MQTT topic structure like
RFBridge/remote1/key1
RFBridge/remote1/key8
which I want to control several devices (which aren’t named the same as the latter part of the trigger topic, just to be awkward!), how would I do it. I have this so far, and it’s showing the correct device name when I press the corresponding button on the RF remote (which triggers the MQTT message sent) … I just can’t seem to work out how to make the leap to toggling the device state…
alias: Downstairs Lights - Toggle
description: ''
  - platform: mqtt
    topic: 'RFBridge/remote1/#'
    payload: 'ON'
condition: []
  - service: system_log.write
      message: >-
        {% set key_pressed = trigger.topic.split("/")[-1] %} {% if key_pressed
        ==  "key1" %} switch.downstairs_lights {% elif key_pressed == "key2" %}
        light.light4 {% elif key_pressed == "key3" %} light.light1 {% elif
        key_pressed == "key4" %} light.light5 {% elif key_pressed == "key5"
        %}light.light2 {% elif key_pressed == "key7" %} light.light3 {%  endif
      level: warning
mode: single
Any suggestions or subtle whacks on the side of the head for not doing the bleeding obvious would be appreciated. There’s a coffee in your future if you can make sense of my ramblings and point me in the right direction :wink:
I would do it like this:
description: ''
  - platform: mqtt
    payload: 'ON'
condition: []
  - service: homeassistant.toggle
      entity_id: >-
        {% set i = trigger.topic[-1] | int %}
        {% set lights = { 1: 'switch.downstairs_lights', 2: 'light.light4',
                          3: 'light.light1', 4: 'light.light5',
                          5: 'light.light2', 6: 'light.light0',
                          7: 'light.light3', 8: 'light.light0' } %}
        {{ lights[i] if i in lights.keys() else 'none' }}
mode: single
In your example, it doesn’t specify a light if the topic contains key6 or key8. In my example, I set those two to light.light0. You will need to change that to the actual lights controlled by key6 and key8.
The template works like this:
  • It sets a variable named i to the last character in the topic and converts it to an integer value.
  • It creates a dictionary that lists keys, from 1 to 8, and their corresponding values representing the light (or switch) to be controlled.
  • The final line checks if i exists in the dictionary. If it exists, it reports its corresponding value (retrieved by lights[i]). If it does not exist, then it reports none which means nothing will be toggled.
Coffee sent :wink:
Thank you very much, especially for the explanation of how the code works… that makes perfect sense. Now, if you would like cake with that coffee … :laughing:
My intention for those remaining two buttons was for them to control brightness. i.e. key6 would be increasing brightness, and key8 would be decreasing. Lets say for light.light_0, as I have yet to incorporate the global brightness for this rig into HA. Is it practical to including this in the same automation, or just do another one. And it’s if not practical, what’s the best way of ignoring those two buttons here, if only so it doesn’t spew log warnings? As it probably comes to no surprise to you, neither ā€˜none’ or ā€˜null’ gave me any satisfaction…
Downstairs Lights - Toggle Lights: Error executing script. Invalid data for call_service at pos 1: Entity ID is an invalid entity id for dictionary value @ data['entity_id']
Edit: Am I trying to be too clever here, using the wildcard? Perhaps better to use trigger for each key to eliminate the two not interested in?
I had to change the name for the entity ids name slightly (my mistake) and it seemed to be looking for light, not lights. But this is now working, except for the log warnings on the remaining two keys. I’m not set on the button order, I can re-map that in node-red if changing the sequence makes anything easier.
alias: Downstairs Lights - Toggle Lights
description: ''
  - platform: mqtt
    payload: 'ON'
condition: []
      entity_id: >-
        {% set lights = { 1: 'switch.downstairs_lights', 2: 'light.light_4',
                          3: 'light.light_1', 4: 'light.light_5',
                          5: 'light.light_2', 6: 'none',
                          7: 'light.light_3', 8: 'none' } %}
mode: single
Actually, on second thought… I’ll keep hammering away at it, as I now have the remote automation doing what I want, up to the point that I need to implement the global brightness stuff on the light controller, before I can do the last bit for brightness…
I’ve ended up with three automation… one for the individual lights, one for the master on/off, and a third will be for the brightness. I’ll do a separate post a little later to explain it all, and edit this one to cross-link to it. Plus I’ll ask any further questions there as to not take this one off tangent. Thanks again!
Thanks for the coffee!
I’ll look into the issue concerning the warning message.
It appears that homeassistant.toggle does not accept none for entity_id.
That seems like an oversight to me because light.toggle and switch.toggle accept none without complaint (as they also do for turn_on and turn_off services). The value none was adopted several versions ago as a way of instructing the service to ā€œdo nothing quietlyā€.
I’ve modified the automation so that it doesn’t rely on the use of none and only accepts buttons 1, 2, 3, 4, 5, and 7.
description: ''
  - platform: mqtt
    payload: 'ON'
condition: []
  - variables:
      i: '{{ trigger.topic[-1] | int }}'
    value_template: "{{ i in [1, 2, 3, 4, 5, 7] }}"
      entity_id: >-
        {{ { 1: 'switch.downstairs_lights', 2: 'light.light_4',
             5: 'light.light_2', 7: 'light.light_3' }[i] }}
mode: single
EDIT
If you want the ability to increase one or more predefined light’s brightness with key6 and decrease it with key8 here’s a way to do it:
description: ''
  - platform: mqtt
    payload: 'ON'
condition: []
  - variables:
  - choose:
    - conditions: '{{ i in [1, 2, 3, 4, 5, 7] }}'
      sequence:
          entity_id: >-
    - conditions: '{{ i in [6, 8] }}'
      sequence:
      - service: light.turn_on
          entity_id:
          - light.light_1
          - light.light_2
          brightness_step_pct: '{{ 10 if i == 6 else -10 }}'
mode: queued
Oh my… that is nice! :slight_smile: Makes my current solution look like what it is… crude (but effective?) :laughing: And I still haven’t done that post, have I… I’ll do that right now to put this into context, and link back to this thread. Think I owe you another coffee now too! :wink:
EDIT: Start of waffle on what this was all about
Yeah, since light.toggle and switch.toggle both accept none, you’d expect homeassistant.toggle to also accept it, wouldn’t you… Suppose should ask it be added via feature requests?
Automation Kludge
description: ''
  - platform: mqtt
    topic: RFBridge/remote1/key2
    payload: 'ON'
  - platform: mqtt
    topic: RFBridge/remote1/key3
    payload: 'ON'
  - platform: mqtt
    topic: RFBridge/remote1/key4
    payload: 'ON'
  - platform: mqtt
    topic: RFBridge/remote1/key5
    payload: 'ON'
  - platform: mqtt
    topic: RFBridge/remote1/key7
    payload: 'ON'
condition: []
      entity_id: >-
        == "key3" %} light.light_1 {% elif key_pressed == "key5" %}
        light.light_2 {% elif key_pressed == "key7" %} light.light_3 {% elif
        key_pressed == "key2" %} light.light_4 {% elif key_pressed == "key4" %}
        light.light_5 {% endif %}
mode: single
alias: Downstairs Lights - Brightness
description: ''
  - platform: mqtt
    topic: RFBridge/remote1/key6
    payload: 'ON'
  - platform: mqtt
    topic: RFBridge/remote1/key8
    payload: 'ON'
condition: []
    data_template:
      entity_id: light.light_master
      brightness: >-
        {% if trigger.topic.split("/")[-1] == "key6" %} {{
        states.light.light_master.attributes.brightness | int + 50 }} {% else %}
        {{ states.light.light_master.attributes.brightness | int - 50 }} {%
        endif %}
mode: single
