I will using a picture element on 2 devices, when iam adding it on one, the other device gives a grey picture.
Whats wrong
Whats wrong
Is this with the Xbox integration?
No, iam using HA on 2 devices tablet and laptop, problem is when I create a picture card on one of them, and set it up. the card on the other device is gray. and vice versa too.
Hello
Thanks for your response
Then added picture elements with add cards.
Then adjusted the path
Check again your options.
I usually keep images in “/config/www/images” and use it as “/local/images/some_image.jpg”.
Try using www folder as I described earlier.
Create an “image” folder in “www” and place images there.
Soory, but where should I create the www folder?
In my case the “www” folder was created automatically when I installed HACS and then installed some frontend custom cards.
It was created with “community” subfolder; all frontend plugins (installed by HACS) appeared in that subfolder.
Later I added manually “images” & other subfolders into “www”.
Now it looks like
The “www” folder is located in “/config”.
It is addressed as “/local” in configuration.
I can’t find this, will continue another time.
Thanks for your information
good night
