Using Surveillance Station action rule to set Hass presence?
OK, Hass is pretty much setup now. So I’m ready for my first automation :slight_smile: (if this even is an automation)
Running Hass as docker image on my Synology NAS.
I have a cam on surveillance station and DS Cam on my mobile detecting whether I’m home or not. I don’t want to add another location tracking app (Own Tracks) on my phone for Hass. In Surveillance Station I can set up an action rule that triggers a webhook (REST API) when arriving/leaving home. I want to use that to also set home/not_home state for persons in Hass.
How should I do this?
OK, I decided to turn this around for 2 reasons:
  • Synology Surveillance STation does not keep track of individual user home/not_home state, only the resulting state
  • DS Cam as a location tracker is draining my battery
So now I use Own Tracks only reporting when in certain zones and have it trigger a Surveillance Station action rule webhook to Enter/Leave home. Still need to figure out how to create a persons group in Home Assistant yet, to make the automation less complex.
I know you no longer want to use DS Cam as a trigger.
But if you want an example on the API I have an example on how to trigger a manual camera recording here Trigger a manual Synology Surveillance Station recording with an RF Door Sensor if it’s any help in the future.
