Using the new "camera_view: live" in my current configuration
Home Assistant v0.92.0 adds support to Lovelace to show camera streams as part of cards. It only supports the following card types though.
  • picture glance
  • picture entity
  • picture element
My Home Assistant camera.yaml configuration is this:
- platform: generic
  stream_source: !secret camera_camera1_stream_source
  still_image_url: !secret camera_camera1_still_image_url
- platform: generic
  stream_source: !secret camera_camera2_stream_source
  still_image_url: !secret camera_camera2_still_image_url
- platform: generic
  stream_source: !secret camera_camera3_stream_source
  still_image_url: !secret camera_camera3_still_image_url
- platform: generic
  stream_source: !secret camera_camera4_stream_source
  still_image_url: !secret camera_camera4_still_image_url
When configuring camera.yaml this way, the cameras simply appear in Home Assistant, which is perfect. I tried adding camera_view: live to camera.yaml, but it doesn’t work.
Does this mean that I have to create a picture entity (or glance or element) for each camera, in order to enable the camera_view: live option?
I’ve read this, but how do I configure this card using the information in camera.yaml?
Just add your camera as the entity.
          - type: picture-entity
            entity: camera.ip_outdoor
            camera_view: live
Excuse my ignorance, as I’m still learning. I tried it like this in camera.yaml:
- platform: generic
  entity: camera.camera1
  camera_view: live
It passes yaml check, but after restarting Home Assistant I get this error in the notification area.
1
The camera_view: live is for the lovelace card, not for the camera config.
Are you using Lovelace?
Yes, but I’ve never touched the UI. All my configuration is in the yaml files.
Hmm, not sure, but there should be a menu where you can ā€˜Take control’ over Lovelace.
But then new devices will not automaticaly appear in the UI.
working code for picture-entity card looks like this:
  entity: camera.office_cam
  camera_view: live
PLease clarify, in which yaml file do I add this? Thanks
Does this product the live stream for this cam? I get a snapshot view.
If you are using Lovelace then it goes in your ui-lovelace.yaml. The same way you would add any other card.
Not sure about Blink. I am using WZYE cam via RTSP. If stream: is enabled and you set the generic component up per the docs, then I would dig deeper into the Blink supported types.
Aha!
I’ll try the Wyze RTSP firmware.
ā€œstream:ā€ would that be added in the configuration.yaml Blink sensor?
What i did was just created a new card for my camera.
Card type is picture-entity
ā€œtype: picture-entity
entity: camera.camera_name
camera_view: liveā€
the config of the card
If you are using blue iris you will need the below in your configuation.yaml
camera:
  - platform: generic
    still_image_url: http://192.168.1.x:81/image/camera_name?q=100&s=25
    stream_source: http://192.168.1.x:81/h264/camera_name/temp.m3u8
Also, first check to make sure the stream is working, here: image
and you should have a more_info box pop out with live stream playing
I am using lovelace, but I don’t have a ui-lovelace.yaml in my config folder.
then you are using the built-in editor, which I use the old method and write /edit my own code. You are going to have to dig in a bit on that method and I am not much help there, but plenty others can. https://www.home-assistant.io/lovelace/
You don’t need it if you go to the top right where the 3 dots are. Click configure UI and do the steps above i mentioned then restart to apply settings
when you say I’m using the build in editor, do you mean the UI? Because I never touched that. Whatever I do, I always edit yaml files. This is why I am looking for a way to do this without touching the UI.
another way as a picture-glance:
            - type: picture-glance
              entities: []
              camera_image: camera.front_door
              camera_view: live
Fairly simply, you can’t. If you want this feature you have to edit your lovelace cards either in the GUI or in yaml, so you either need to ā€œtake control of lovelace UIā€ or Switch it to yaml mode. There is no magic button for this yet and it’s not automatically added for you.
