Have you used the final version of the python script? It is available here.
I think so.
What do you mean by āItās not workingā?
I donāt know if app_segment_clean
supports multiple cleanups by repeating zones number.
It supports in form of [18, 18, 18]
What exactly is not working? Is there anything in logs?
hello friends can someone help a newbie? I would like to get the robotās coordinates to start my automation but the FloleVac app doesnāt look like the map to me what do I do?
gente estou com erro na coluna 19
title: FamĆlia Sauer
- path: default_view
title: Home
icon: āmdi:homeā
badges:- entity: binary_sensor.updater
- entity: person.rodrigo
- entity: sun.sun
cards: - type: entities
entities:- sensor.hp_deskjet_2600_series_black_ink
- sensor.hp_deskjet_2600_series_tri_color_ink
title: Sala TV
- type: entities
entities:- !include vacuum_card.yaml
- vacuum.xiaomi_vacuum_cleaner
title: vacuum
- type: weather-forecast
entity: weather.familia_sauer
Iāve tried the https://github.com/PiotrMachowski/Home-Assistant-custom-components-Xiaomi-Vacuum-Map-Camera integration. But it only shows the map, the vacuum is not present in the image. Is there a fix to this?
Just like I have mentioned in an issue on GitHub:
Its purpose is to be used via map lovelace card. The path will be drawn by card itself which should look much better than drawing it in a camera entity.
To summarize, everything is working as designed, but lovelace card is not ready yet.
@3_14, thanks for the contribution there, I am thinking to buy a xiaomi vaccum, but there are many models from xiaomi. I want to know what model does this map card support? Does it support the viomi pro2? Here is the link: https://www.mi-store.com.au/xiaomi-viomi-v2-pro-robot-vacuum-cleaner.
Thanks in advance.
I was following the how-to on getting coordinates but since I have Valetudo already installed on my Xiaomi S5 is there a way to calibrate it? The only way mentioned in the how-to is to use the official Xiaomi app or Floevac. But since neither work with Valetudo how can I calibrate the interactive map?
Thanks for any info.
@sylarsunny
This card should support all xiaomi vacuums supported by Home Assistant, but I am not certain. The vacuum must support commands for going to point and zoned cleanup for this card to work.
@liamp
Coordinates from valetudo should work, if they donāt try recalculating Y coordinates: ynew = 51200 - yold
Thanks for the hard work on this card. Just something for the roadmapā¦ it would be nice if the card could be expanded to pull in both map_image and map_camera, each with its own opacity level config option. I think similar was suggested in the past, but I havenāt come across a practical method of overlaying a root-based live vacuum path on top of a static floorplan image.
Does anyone know what the theme attribute for the buttons on the bottom left and right of this card, shown here in Orange?
My theme makes these impossible to read as well as many other buttons like thisā¦
Where exactly should I put my map?
Iāve got it in the same directory as configuration.yaml and Iām trying to configure card with:
map_image: /config/mieszkanie.png
But card doesnāt show it. Tried also /root/config/mieszkanie.png or just mieszkanie.png and it also doesnāt work. I couldnāt find any logs with info where exactly does HA look for this file.
NVM. Found it. In case of HACS it needs to go to www directory and then itās available as /local/filename.png.
Iām having trouble with this card.
I have this message
Information
Not loaded in Lovelace
You have 1 Lovelace elements that are not loaded properly in Lovelace.
Indeed, It does not load.
It used to work for months but now it doenāt anymore.
Where can I find information about this ?
Thanks.
I had this problem with two other hacs integration, just stopped working, i reinstalled them, after that they worked. Not saying this would work, just maybe
Thank you for your answer, but I already tried it and nothing has changed.
Is there anything in browsers console?
