ok , seems zone control, the drawing is now fixed ! thnx for that @3_14
one question tough, i am using now that new camera feature, on my chrome browser it looks fine
but on my mobile phone, its not scaling , the width is too big, its falling of my screen
any idea how i can resolve that ? i have scale in camera set to 1
3_14
(Piotr Machowski)
October 11, 2020, 5:14pm
530
Where do you have this issue (browser/app/system)? It works fine on my phone
i am using the HA android app
3_14
(Piotr Machowski)
October 11, 2020, 5:37pm
532
It still works fine in my caseā¦ Can you check if it is ok in Chrome?
chrome is the same, also tried incognito be be sure
here is how it looks like : https://www.dropbox.com/s/49nfjvn62zczfcf/vacuum1.jpg?dl=0
EDIT : fixed, seems i had bad trimmings
ottelo
October 13, 2020, 10:27am
535
I want to install the custom card. But instead of add it via old fashioned way (ui-lovelace.yaml) I added the ressource via Configuration -> Loveace Dashboards -> Ressources. But I canāt find the āxiaomi_vacuum_map_cardā via uir Card Viewer or via add manual card:
type: ācustom: xiaomi_vacuum_map_cardā
=> Error: Custom element not found: xiaomi_vacuum_map_card
3_14
(Piotr Machowski)
October 13, 2020, 11:25am
536
Are you sure you used a correct URL?
ottelo
October 13, 2020, 11:28am
537
/local/custom_lovelace/xiaomi_vacuum_map_card/xiaomi-vacuum-map-card.js
the file is in config\www\custom_lovelace\xiaomi_vacuum_map_card\
3_14
(Piotr Machowski)
October 13, 2020, 12:39pm
538
Have you restarted HA after creating www folder?
ottelo
October 13, 2020, 12:59pm
539
Yes, I restarted HA few times. I had already created the folder a few months ago.
EDIT:
I changed the path to:
/config/www/custom_lovelace/xiaomi_vacuum_map_card/xiaomi-vacuum-map-card.js
Now I can setup a card with the example from here Example Code .
I dont know why, but inside the card config I have to use /local/ instead of /config/www/ā¦?
ciB
October 15, 2020, 4:48pm
540
I cant add this via HACS? I am a little confused, HACS says the repository is already in the store, but I cannot find it there??
3_14
(Piotr Machowski)
October 15, 2020, 5:09pm
541
You donāt have to add card to HACS, it is already there in āFrontendā section
ciB
October 15, 2020, 7:48pm
542
Yeah, but it was not there for me. When I searched for it it would not show. I restarted Home Assistant and now itās thereā¦
r33b
October 16, 2020, 8:05am
543
Hi Piotr,
first of all: Your card is GREAT work!!!
second I have a question because Iāve read that there were some troubles in the last days. Do this troubles are connected to my problem. When I go to the lovelace Tab for my vacuum, the dropdown list is not working properly anymore. It is only a list of the 3 available options. Clicking on them does not change anything.
When I switch to other Tabs and then back to this one, it looks as before again.
Here is how it looks like:
3_14
(Piotr Machowski)
October 16, 2020, 8:22am
544
this problem should be solved in v1.1.12 , do you have it?
r33b
October 16, 2020, 8:42am
545
I have downloaded the files manually which are linked here, I donāt use HACS. Is this a problem? Where can I display the Version?
3_14
(Piotr Machowski)
October 16, 2020, 8:46am
546
This version was created 5 days ago, if you have following part in xiaomi-vacuum-map-card.js
then you have a correct version:
if (typeof loadCardHelpers !== "undefined") {
loadCardHelpers().then(helpers => {
if (typeof helpers.importMoreInfoControl !== "undefined") {
helpers.importMoreInfoControl("light");
djtail
(Djtail)
October 16, 2020, 11:12am
547
Im very new on this with home assistant
i have installed ur card using āHACSā
installed the roborock s5 with token and can see it.
Then i used ur guide to take out the map cordinates and the different zones and put them in the card, using this code:
type: 'custom:xiaomi-vacuum-map-card'
entity: vacuum.xiaomi_vacuum
map_image: /local/images/dammsugare/damkarta.png
language: se
calibration_points:
- vacuum:
x: 17002
'y': 28300
map:
x: 13
'y': 18
- vacuum:
x: 17002
'y': 17000
map:
x: 209
'y': 957
- vacuum:
x: 17002
'y': 17000
map:
x: 828
'y': 884
zones:
- - - 19343
- 17156
- 21493
- 20856
- - - 23003
- 21656
- 26553
- 24806
- - - 17084
- 24887
- 20084
- 28137
- - 22743
- 25075
- 26543
- 28175
- - - 20437
- 21460
- 21637
- 25810
- - 18709
- 21027
- 20759
- 22427
- - 21505
- 17231
- 26655
- 21481
- - 24831
- 18128
- 26531
- 19878
i can see the map in the card, but the preedefined zones donāt show up when clicking zone cleaning.
And there is no reaction on the vacuum when i use goto and press start, och making my own zone to clean.
i guess that im missing something, but what?
please help
3_14
(Piotr Machowski)
October 16, 2020, 11:16am
548
Try adding debug: true
and check again
