Awesome! This card is amazing btw… can’t wait to get it fully working for my wife
Why do I have to enter “calibration_points” if I use the “map_camera” ( Xiaomi Cloud Map Extractor)?
Will automated map calibration be supported for rotated maps anytime soon?
I hope so
Is now soon enough? (support added, please update extractor)
It seems like you don’t have the latest version or you have caching problem
Ok you’re right. I always use the wget command without “-N” parameter. So after each update the system created a new filename .1 .2 Now it works! Thanks
I have same problems with map scaling. If I change scale from 1 to 2 nothing changes (after HA restart). Do I have to use the trim parameter, too?? I’m using the Cloud-Map-Extractor camera.
Size of a card will not be changed, this change is only visible when you open popup for a camera
Do i need to Screenshot the map, or does the map extractor, download a png of the map ? thanks for ur work this looks awesome
ok got it, sry
Extractor is can be used instead of an image using map_camera
property
There is a way to take automatically the zones from Xiaomi-Cloud-Map-Extractor?
is there a way to get the current position of the vac, or via the map the coordinates of a specific position ?
@avol-io
there will be
@seboo30
Both options are possible:
- You just have to add appropriate attribute: documentation
- You have to add
debug: true
in card’s config, coordinates will shown in a popup instead of being sent to the vacuum
