@BeastHouse I’m from Poland, it’s not so bad. You can check out this thread:
Thanks @3_14 - Managed to add my current floor, however I am guessing the map will change like the Live Map. Are you required to have an image as map_source instead of a camera?
Here is what I have so far:
And the code:
cards:
- type: custom:xiaomi-vacuum-map-card
title: Xiaomi Vacuum Map Card
preset_name: Live map
entity: vacuum.roborock_s6_maxv
map_source:
camera: camera.xiaomi_cloud_map_extractor
calibration_source:
camera: true
map_modes:
- template: vacuum_clean_zone
- template: vacuum_clean_zone_predefined
predefined_selections:
- zones:
- - 29218
- 25397
- 32728
- 28231
label:
text: Kitchen
x: 30990
'y': 26699
offset_y: 35
icon:
x: 30990
'y': 26699
- zones:
- - 24417
- 25414
- 29258
- 28044
- - 24450
- 28062
- 26301
- 29375
label:
text: Kitchen 2
x: 27230
'y': 26511
offset_y: 35
icon:
x: 27230
'y': 26511
- zones:
- - 29048
- 28386
- 33668
- 33202
label:
text: Dining
x: 32887
'y': 30100
offset_y: 35
icon:
x: 32887
'y': 30100
- zones:
- - 29203
- 33308
- 31925
- 34928
- - 29271
- 34846
- 30215
- 37816
label:
text: Hallway
x: 31280
'y': 33929
offset_y: 35
icon:
x: 31280
'y': 33929
- zones:
- - 30244
- 35102
- 32761
- 35919
label:
text: Powder Room
x: 32596
'y': 35279
offset_y: 35
icon:
x: 32596
'y': 35279
- zones:
- - 24534
- 35445
- 29018
- 37937
- - 26908
- 33104
- 29051
- 35408
label:
text: Master Bedroom
x: 28016
'y': 36133
offset_y: 35
icon:
x: 28016
'y': 36133
- zones:
- - 24584
- 33634
- 26795
- 35289
label:
text: Ensuite
x: 26495
'y': 34014
offset_y: 35
icon:
x: 26495
'y': 34014
- template: vacuum_goto
- template: vacuum_follow_path
additional_presets:
- preset_name: Family Room
map_source:
calibration_source:
camera: true
append_icons: true
icons:
- icon: mdi:home-floor-1
tooltip: Family Room
tap_action:
action: call-service
service: vacuum.send_command
service_data:
entity_id: vacuum.roborock_s6_maxv
command: load_multi_map
params: 0
map_modes:
- zones:
- - 27500
- 27500
- 28500
- 28500
card_mod:
style: |
ha-card {
background-color: var(--primary-background-color);
background: rgb(0, 49, 83, 0.4);
box-shadow: none;
The map extractor should automatically switch to current floor.
Hi, @3_14 !
Can you please elaborate on how do I fill the “outside” part of the map please? I couldn’t find the CSS command that does change this.
Kudos for the good works and thanks!
That’s because it is not a functionality of map card (and therefore not CSS as well), but map extractor:
Thanks, I have 4 ‘levels’ in my house, am I able to add that many? Kinda struggling with this one.
this card is awesome and is very usefull, great work.
I can almost ditch the app the only thing missing:
- Resetting the filters/brushes when they have been replaced by long pressing the info tab for example
- When I haven’t open the lid for a while and that i have to empty the bin. I could have a binary sensor set to 1. I could than automate a notificaion
Are these functions something that could be added?
You can do as many as you want to
- It’s possible to do it, but you have to override default tiles
- As far I understand this functionality has to be provided by the integration…?
Thanks a lot for your fast answer! So, “color_scan” did the job
Thanx I was able to figure this out, just sharing in case this may help someone:
hold_action:
service_data:
command: reset_consumable
params: filter_work_time
It most probably should be part of the integration, I am unable to figure out if there is something showing if the bin is full, will continue searching.
You can’t
So it is designed by HA latest versions
I recreated the look of the card which i like but with the hold-action to reset the filters. Here is the complete code I wrote. (might help sommeone).
Is there a way to have a dynamic icon for the battery like it’s the case in the default setup?
tiles:
- label: Status
attribute: status
icon: mdi:robot-vacuum
- label: Battery
attribute: battery_level
unit: '%'
icon: mdi:battery
- label: Fan speed
attribute: fan_speed
icon: mdi:fan
- label: Sensor left
entity: sensor.roborock_s6_maxv_sensor_dirty_left
multiplier: 0.0002777777777777778
unit: h
icon: mdi:eye-outline
precision: 1
hold_action:
service_data:
params: sensor_dirty_time
- label: Filter left
entity: sensor.roborock_s6_maxv_filter_left
unit: h
icon: mdi:air-filter
precision: 1
hold_action:
service_data:
- label: Main brush left
entity: sensor.roborock_s6_maxv_main_brush_left
unit: h
icon: mdi:brush
precision: 1
hold_action:
service_data:
params: main_brush_work_time
- label: Side brush left
entity: sensor.roborock_s6_maxv_side_brush_left
unit: h
icon: mdi:brush
precision: 1
hold_action:
service_data:
params: side_brush_work_time
Nicely done
You can also double-click “play” button to retrieve autogenerated config, it will be printed in browser’s console (it is almost exactly the same as your, the only thing that is missing are translations, but they are not required for English
Currently it’s not possible to have a dynamic icon, but I plan to add this feature
I like your approach
What’s the best way to have this card display the map of a valetudo robot?
Still ICantBelieveItsNotValetudo?
Yup, I don’t really want to parse raw map data…
You can check out this issue:
