3_14
(Piotr Machowski)
November 23, 2023, 1:53pm
1717
It’s here
I think you have mixed something up…
The play button that is right below the map (white one on your screenshot) should call vacuum.send_command
service.
The second one (black one on your screenshot) should call vacuum.start
service to start full cleaning.
Yup, exactly.
mackbeth
(Maciej)
November 23, 2023, 4:16pm
1719
Ok, thanks a lot.
So I didn;t read, that this black “play” button always start full cleaning, where the blue one starts what is selected (zone, room, path, goto)… so I just aste your time ehh… sorry
So now is clear for me, but stil in docs maybe it is little confusing descrition as they don’t execute same asction…
Hi!
Thank you one million for the Card. Just started with HA yesterday.
I’m trying to integrate it with the excellent as well Roborock integration from humbertogontijo; however, I have no entity for the camera available.
Im using a S7MAXV and under the device there are 31 entities, but none are a camera or similar.
Has anyone else encountered this? I would guess I would need to ask in the Roborock integration but just in case.
Thanks in advance!
3_14
(Piotr Machowski)
November 29, 2023, 8:43pm
1722
Yes, but keep in mind that you have to use a custom Roborock integration, not official one.
Thanks! Yes, I think I have it ok, just the camera entity not showing up.
I’ve put a discussion on github, hopefully someone can assist
Hi, First of all, thank you for the work on the integration, it's an incredible achievement. I started HA yesterdy, and everything has worked correctly, except that when integrating Piotr Wachowski...
DataBitz
(Data Bitz)
December 8, 2023, 3:09am
1725
With the native Roborock integration providing a map now in 2023.12, is there a way to display this on the card?
The map shows an image-type entity .e.g. image.roborock_s6_maxv_ground_floor
3_14
(Piotr Machowski)
December 8, 2023, 4:52am
1726
You can just use it instead of camera entity, but it won’t work with anything displayed on the map.
I installed this great integration.
Now I have some questions:
How can I change the language to german?
I dont see the menu “zone-cleanup” what make I wrong?
And how can I add more entities (for example brush live)?
Sirmike2
(Sirmike2)
December 9, 2023, 7:00pm
1728
I have the problem that room/segment cleaning is not working. I have a Roborock S7 MaxV, HA core 2023.12.1 and Lovelace Vacuum Map card Version 2.2.2
So when I select the room and try to start, the vacuum won’t start.
I tried it with platform default, homeassistant-roborock and send_command.
So the debug’s :
"domain": "vacuum",
"service": "send_command",
"serviceData": {
"command": "app_segment_clean",
"entity_id": "vacuum.roborock_s7_maxv_michael",
"params": [
"segments": [
17
"repeat": 1
"domain": "roborock",
"service": "vacuum_clean_segment",
"serviceData": {
"segments": [
"17"
"repeats": 1
"domain": "vacuum",
"serviceData": {
"params": [
"17"
But when I start the service via HA Development
service: vacuum.send_command
entity_id: vacuum.roborock_s7_maxv_michael
command: app_segment_clean
params: 17
or
service: roborock.vacuum_clean_segment
segments: 17
the vacuum will start cleaning.
Hopefully someone can help.
3_14
(Piotr Machowski)
December 11, 2023, 11:19am
1729
language: de
Using tiles
config and setting append_tiles: true
3_14
(Piotr Machowski)
December 11, 2023, 11:20am
1730
Which integration do you use in HA to add your vacuum?
hallo and thanks.
the Langueage now working.
But I have a question fot the seeting up room cleaning.
In the example code
camera:
- platform: xiaomi_cloud_map_extractor
host: !secret xiaomi_vacuum_host
token: !secret xiaomi_vacuum_token
username: !secret xiaomi_cloud_username
password: !secret xiaomi_cloud_password
draw: ['all']
attributes:
- calibration_points
- rooms
is the xiaomi vacuum, but I have an ecovacs vaccuum.
Must I also right the full code? And where I get the token?
And must i put this code in the normal config.yaml?
For my vaccum I use this Hacs intergration:
3_14
(Piotr Machowski)
December 11, 2023, 6:59pm
1732
Ok, the link I have posted doesn’t apply to your integration.
You have to create rooms config manually. Rooms will be cleaned using room IDs, you have to find out which id corresponds to which room (this info should be in rooms
attribute of vacuum entity). To get values for outline follow these instructions .
Example:
map_modes:
- template: vacuum_clean_segment
predefined_selections:
- id: 14
outline: [[ 214, 321 ], [ 242, 321 ], [ 241, 274 ], [ 231, 274 ]]
label:
text: "Bedroom"
x: 229
y: 303
offset_y: 35
icon:
x: 229
y: 303
- id: 19
outline: [[ 214, 272 ], [ 230, 272 ], [ 230, 256 ], [ 214, 256 ]]
label:
text: "Bathroom"
x: 222
y: 264
offset_y: 35
icon:
x: 22282
y: 26496
Thanks for the new info.
I test it with the first room.
If I klick on the + se the roomlines und klick then on play for 1 secound I see this:
But now I don´t know how to set the outline correct, because I need two numbers per point. But in the screenshot I online see ones.
Edit:
Now I got it with try an error
DataBitz
(Data Bitz)
December 11, 2023, 9:49pm
1734
Thanks for the updated integration, I can add the new Roborock map image now.
For anyone else trying this, you need to upgrade to 2.8.0 of the integration.
add image entities as map entities (15353d3)
Sirmike2
(Sirmike2)
December 11, 2023, 11:15pm
1735
I m using the Roborock Integration for HomeAssistant from humbertogontijo version 1.0.13
3_14
(Piotr Machowski)
December 12, 2023, 4:51am
1736
Can you post your card config?
Sirmike2
(Sirmike2)
December 12, 2023, 11:48am
1737
That is my config at the moment:
type: custom:xiaomi-vacuum-map-card
debug: true
title: ''
preset_name: Wohnung Michael
entity: vacuum.roborock_s7_maxv_michael
map_source:
camera: camera.roborock_s7_maxv_michael_map
calibration_source:
camera: true
vacuum_platform: humbertogontijo/homeassistant-roborock
map_modes:
- template: vacuum_clean_zone
- template: vacuum_goto
- id: '16'
icon:
x: 32550
'y': 24000
label:
text: Room 16
x: 32550
'y': 24000
offset_y: 35
outline:
- - 29800
- 21800
- - 35300
- 21800
- - 35300
- 26200
- - 29800
- 26200
- id: '17'
icon:
x: 27150
'y': 24500
label:
text: Room 17
x: 27150
'y': 24500
offset_y: 35
outline:
- - 24500
- 22150
- - 29800
- 22150
- - 29800
- 26850
- - 24500
- 26850
- id: '18'
icon:
x: 26225
'y': 30600
label:
text: Room 18
x: 26225
'y': 30600
offset_y: 35
outline:
- - 25100
- 30200
- - 27350
- 30200
- - 27350
- 31000
- - 25100
- 31000
- id: '19'
icon:
x: 26900
'y': 32400
label:
text: Room 19
x: 26900
'y': 32400
offset_y: 35
outline:
- - 25550
- 31400
- - 28250
- 31400
- - 28250
- 33400
- - 25550
- 33400
- id: '20'
icon:
x: 27450
'y': 35100
label:
text: Room 20
x: 27450
'y': 35100
offset_y: 35
outline:
- - 24650
- 33750
- - 30250
- 33750
- - 30250
- 36450
- - 24650
- 36450
- id: '21'
icon:
x: 29300
'y': 30300
label:
text: Room 21
x: 29300
'y': 30300
offset_y: 35
outline:
- - 27400
- 26900
- - 31200
- 26900
- - 31200
- 33700
- - 27400
- 33700
- id: '22'
icon:
x: 32725
'y': 34925
label:
text: Room 22
x: 32725
'y': 34925
offset_y: 35
outline:
- - 30250
- 33850
- - 35200
- 33850
- - 35200
- 36000
- - 30250
- 36000
- id: '23'
icon:
x: 32825
'y': 29225
label:
text: Room 23
x: 32825
'y': 29225
offset_y: 35
outline:
- - 30500
- 28150
- - 35150
- 28150
- - 35150
- 30300
- - 30500
- 30300
- id: '24'
icon:
x: 32875
'y': 26875
label:
text: Room 24
x: 32875
'y': 26875
offset_y: 35
outline:
- - 30400
- 25850
- - 35350
- 25850
- - 35350
- 27900
- - 30400
- 27900
append_icons: false
icons:
- icon: mdi:play
conditions:
- entity: vacuum.roborock_s7_maxv_michael
value_not: cleaning
value_not: error
value_not: returning
tooltip: Start
tap_action:
action: call-service
service: vacuum.start
service_data:
- icon: mdi:pause
conditions:
value_not: docked
value_not: idle
value_not: error
value_not: paused
tooltip: Pause
tap_action:
service: vacuum.pause
service_data:
- icon: mdi:stop
conditions:
value_not: docked
value_not: idle
value_not: error
value_not: paused
tooltip: Stop
tap_action:
service: vacuum.stop
service_data:
- icon: mdi:home-map-marker
conditions:
value_not: docked
tooltip: Zurück zur Station
tap_action:
service: vacuum.return_to_base
service_data:
- icon: mdi:target-variant
conditions:
value_not: docked
value_not: error
value_not: cleaning
tooltip: Punktreinigung
tap_action:
service: vacuum.clean_spot
service_data:
- icon: mdi:map-marker
tooltip: Lokalisieren
tap_action:
service: vacuum.locate
service_data:
- icon: fapro:water-fan
tooltip: Kombiniert
tap_action:
service: script.roborock_programm_kombiniert
- icon: mdi:fan-alert
tooltip: Saugen
tap_action:
service: script.roborock_programm_saugen
- icon: mdi:water-alert
tooltip: Wischen
tap_action:
service: script.roborock_programm_wischen
- icon: mdi:alpha-c-circle
tooltip: Individuel
tap_action:
service: script.roborock_programm_custom
- type: menu
menu_id: fan_speed
icon_id: fan_speed
entity: select.fanspeed
available_values_attribute: options
icon: mdi:fan
icon_mapping:
'off': mdi:fan-off
quiet: mdi:fan-speed-1
balanced: mdi:fan-speed-1
turbo: mdi:fan-speed-2
max: mdi:fan-speed-3
custom: mdi:fan-auto
max_plus: mdi:fan-plus
tap_action:
service: select.select_option
service_data:
option: '[[value]]'
entity_id: '[[entity_id]]'
- type: menu
menu_id: water_box_mode
icon_id: water_box_mode
entity: select.roborock_s7_maxv_michael_wischmopp_intensiat
icon: mdi:water
icon_mapping:
'off': mdi:water-remove
mild: mdi:water-minus
moderate: mdi:water
intense: mdi:water-plus
custom: mdi:water-sync
tap_action:
service_data:
option: '[[value]]'
- type: menu
menu_id: mop_mode
icon_id: mop_mode
entity: select.roborock_s7_maxv_michael_route
icon: mdi:view-grid-outline
icon_mapping:
standard: mdi:view-grid-outline
deep: mdi:view-grid
deep_plus: mdi:view-grid-plus
custom: mdi:view-dashboard-edit-outline
tap_action:
service_data:
option: '[[value]]'
- icon: mdi:remote
tooltip: Individuel
tap_action:
action: fire-dom-event
browser_mod:
service: browser_mod.sequence
sequence:
- service: browser_mod.popup
deviceID: this
title: Roborock
content:
square: false
type: grid
columns: 1
cards:
- type: custom:webrtc-camera
url: Roborock_Michael2
- square: false
type: horizontal-stack
colums: 4
cards:
- entity: input_boolean.roborock_move_up
icon: mdi:arrow-up-bold
type: custom:button-card
hold_action:
service: roborock.vacuum_remote_control_move
velocity: 0.29
duration: 600
rotation: 0
repeat: 600
- entity: input_boolean.roborock_move_down
icon: mdi:arrow-down-bold
hold_action:
velocity: -0.29
duration: 600
rotation: 0
repeat: 600
- entity: input_boolean.roborock_move_left
icon: mdi:arrow-left-bold
hold_action:
velocity: 0.03
rotation: 10
duration: 600
repeat: 600
- entity: input_boolean.roborock_move_right
icon: mdi:arrow-right-bold
hold_action:
velocity: 0.03
rotation: -10
duration: 600
repeat: 600
- square: false
colums: 2
cards:
icon: mdi:play
tap_action:
service: roborock.vacuum_remote_control_start
icon: mdi:stop
tap_action:
service: roborock.vacuum_remote_control_stop
append_tiles: true
tiles:
attribute: mop_intensity
label: Aktuelle Intensität
icon: mdi:water
attribute: mop_mode
label: Aktuelle Strecke
- entity: sensor.roborock_s7_maxv_michael_aktuelle_reinigung_dauer
label: Aktuelle Zeit
icon: mdi:timer-sand
- entity: sensor.roborock_s7_maxv_michael_aktuelle_reinigung_flache
label: Aktuelle Fläche
icon: mdi:texture-box
- entity: sensor.roborock_s7_maxv_michael_aktueller_raum
label: Aktueller Raum
icon: mdi:floor-plan
3_14
(Piotr Machowski)
December 12, 2023, 3:57pm
1738
Use following config:
debug: true
title: ''
map_source:
calibration_source:
camera: true
map_modes:
id_type: "number"
I tested my room layout today.
Here is part of the folder:
You can see that I clicked on the bedroom. Then I clicked on the play button at the bottom right. My vacuum robot moved out of the charging station, about 1/2 m, then it stopped there and cleaned on the spot until I stopped it.
This is my card code:
entity: vacuum.anneliese
title: ''
vacuum_platform: DeebotUniverse/Deebot-4-Home-Assistant
map_locked: true
map_source:
camera: image.anneliese_karte
two_finger_pan: false
language: de
map_modes:
- id: 1
outline:
- - 3400
- -20000
- - -6400
- -20000
- - -6400
- -6000
- - 3500
- -6000
label:
text: Schlafzimmer
x: -1500
'y': -13000
offset_y: 35
icon:
x: -1500
'y': -13000
- id: 2
outline:
- - -15000
- -20000
- - -6400
- -20000
- - -6400
- -9000
- - -15000
- -9000
label:
text: Küche
x: -9500
'y': -17000
offset_y: 35
icon:
x: -9500
'y': -17000
- id: 3
outline:
- - -19800
- -18500
- - -15000
- -18500
- - -15000
- -11500
- - -19800
- -11500
label:
text: Bad
x: -17500
'y': -16000
offset_y: 35
icon:
x: -17500
'y': -16000
- id: 4
outline:
- - -13000
- -9000
- - -6400
- -9000
- - -6400
- -1700
- - -13000
- -1700
label:
text: Flur
x: -9500
'y': -6000
offset_y: 35
icon:
x: -9500
'y': -6000
- id: 5
outline:
- - -20000
- -1700
- - -6400
- -1700
- - -6400
- 10000
- - -19800
- 10000
label:
text: Wohnzimmer
x: -12500
'y': 5000
offset_y: 35
icon:
x: -12500
'y': 5000
- id: 6
outline:
- - 3400
- -6000
- - -6400
- -6000
- - -6400
- 8500
- - 3500
- 8500
label:
text: Büro
x: -1500
'y': 2000
offset_y: 35
icon:
x: -1500
'y': 2000
Do I have to add anything else so that when I click on the room it goes to it and vacuums it?
Maybe I misunderstood something here with the room IDs. I have now simply numbered the rooms in my card.
