Vacuum Interactive Map Card
You have the same vaccum than me. Are you using Xiaomi Miio for vacuum? If not, use it. And on platform use default. About the map failed to retrieve, good luck
I see this is method to increase resolution of map. However I am not using the extractor as I use custom roborock integration and roborock app. Is there any other option to make the map clearer.
I tried this but didn’t work
type: custom:xiaomi-vacuum-map-card
tiles: []
icons: []
map_transformation:
  scale: 2
  rotate: 180
Hello, i have a Dreame L10S Ultra with Dreame integration that works very well, but i am facing some strange behaviours if i am using a scheduler in HA in order to start at 9:30 from Monday to friday the dusting+washing mode for all the rooms. It seems that everytime i reopen the vacuum card the rooms selected become all unselected and at 9:30 the vacuum starts only with dusting and only in the first room. here below my card configuration and the scheduler:
Vacuum card:
map_source:
  camera: camera.dreamebot_l10s_ultra_map
calibration_source:
  camera: true
entity: vacuum.dreamebot_l10s_ultra
vacuum_platform: Tasshack/dreame-vacuum
map_modes:
  - name: Rooms
    icon: mdi:floor-plan
    run_immediately: false
    coordinates_rounding: true
    coordinates_to_meters_divider: 1000
    selection_type: ROOM
    max_selections: 60
    repeats_type: EXTERNAL
    max_repeats: 3
    service_call_schema:
      service: dreame_vacuum.vacuum_clean_segment
      service_data:
        segments: '[[selection]]'
        repeats: '[[repeats]]'
        entity_id: '[[entity_id]]'
    predefined_selections:
      - id: '1'
        icon:
          x: -2700
          'y': 8800
        label:
          text: Bathroom
          x: -2700
          'y': 8800
          offset_y: 35
        outline:
          - - -4200
            - 7800
          - - -1200
            - 7800
          - - -1200
            - 9700
          - - -4200
            - 9700
      - id: '2'
        icon:
          x: -3300
          'y': 5750
        label:
          text: Primary Bedroom
          x: -3300
          'y': 5750
          offset_y: 35
        outline:
          - - -4200
            - 3600
          - - -1000
            - 3600
          - - -1000
            - 7800
          - - -4200
            - 7800
      - id: '3'
        icon:
          x: 150
          'y': -1050
        label:
          text: Dining Hall
          x: 150
          'y': -1050
          offset_y: 35
        outline:
          - - -4300
            - -3900
          - - 4350
            - -3900
          - - 4350
            - 3600
          - - -4300
            - 3600
    variables: {}
icons:
  - icon: mdi:play
    conditions:
      - entity: vacuum.dreamebot_l10s_ultra
        value_not: cleaning
        value_not: error
        value_not: returning
    tooltip: Start
    tap_action:
      action: call-service
      service: vacuum.start
      service_data:
        entity_id: vacuum.dreamebot_l10s_ultra
  - icon: mdi:pause
    conditions:
        value_not: docked
        value_not: idle
        value_not: error
        value_not: paused
    tooltip: Pause
    tap_action:
      service: vacuum.pause
      service_data:
  - icon: mdi:stop
    conditions:
        value_not: docked
        value_not: idle
        value_not: error
        value_not: paused
    tooltip: Stop
    tap_action:
      service: vacuum.stop
      service_data:
  - icon: mdi:home-map-marker
    conditions:
        value_not: docked
    tooltip: Return to base
    tap_action:
      service: vacuum.return_to_base
      service_data:
  - icon: mdi:map-marker
    tooltip: Locate
    tap_action:
      service: vacuum.locate
      service_data:
  - menu_id: fan_speed
    icon: mdi:fan-remove
    label: Silent
    conditions:
        attribute: fan_speed
        value: Silent
    tooltip: Change fan speed
    tap_action:
      service: vacuum.set_fan_speed
      service_data:
        fan_speed: Silent
    icon: mdi:fan-speed-1
    label: Standard
    conditions:
        value: Standard
    tap_action:
      service_data:
        fan_speed: Standard
    icon: mdi:fan-speed-2
    label: Strong
    conditions:
        value: Strong
    tap_action:
      service_data:
        fan_speed: Strong
    icon: mdi:fan-speed-3
    label: Turbo
    conditions:
        value: Turbo
    tap_action:
      service_data:
        fan_speed: Turbo
  - icon: mdi:fan-alert
    conditions:
        value_not: Silent
        value_not: Standard
        value_not: Strong
        value_not: Turbo
    tap_action:
      service_data:
        fan_speed: Silent
tiles:
  - tile_id: battery_level
    label: Battery
    attribute: battery_level
    icon_source: vacuum.dreamebot_l10s_ultra.attributes.battery_icon
    unit: '%'
  - tile_id: fan_speed
    label: Fan speed
    icon: mdi:fan
    translations:
      silent: Silent
      standard: Standard
      medium: Medium
      turbo: Turbo
      auto: Auto
      gentle: Gentle
  - tile_id: mop_pad_humidity
    attribute: mop_pad_humidity
    label: Mop pad
    icon: mdi:water-percent
    precision: 0
    translations: {}
  - tile_id: cleaned_area
    attribute: cleaned_area
    label: Cleaned area
    icon: mdi:ruler-square
    unit: m²
    precision: 0
    translations: {}
  - tile_id: cleaning_time
    attribute: cleaning_time
    label: Cleaning time
    icon: mdi:timer-sand
    unit: min
    precision: 0
    translations: {}
  - tile_id: cleaning_count
    attribute: cleaning_count
    label: Cleaning count
    icon: mdi:counter
    unit: x
    precision: 0
    translations: {}
  - tile_id: total_cleaned_area
    attribute: total_cleaned_area
    label: Total cleaned area
    icon: mdi:set-square
    unit: m²
    precision: 0
    translations: {}
additional_presets: []
map_locked: true
two_finger_pan: true
Scheduler:
type: custom:scheduler-card
include:
  - vacuum.dreamebot_l10s_ultra
exclude: []
title: Dreame L10S Ultra
discover_existing: false
I don’t think it can be done in other integrations. You can’t change it via the card.
Rooms selected in the map card are not sent anywhere until you click “play” button. What service do you call using the scheduler?
Hi Piotr and thanks for replying! Honestly in the scheduler i just used the UI configuration, setting “Start” at a certain time and days (from Mon to Fri), i didn’t set a call for a speciffic service
Ok, I don’t think I can help you, this seems to be related to the integration you use to add the vacuum to HA. It definitely doesn’t depend on the map card
indeed, i think i misuderstood :slight_smile: thanks for the great card and the whole work done in any case, very helpful!
Hello Piotr,
thanks for this awesome lovelace card!
Is it possible to have some of the rooms preselected when switching to the ‘room cleanup’ mode?
No, it’s not possible at this moment
Hey all,
Is it possible to transform my map?
I want to zoom in a bit and crop the right side.
i use the hacs roborock integration and this is my config:
    - type: custom:xiaomi-vacuum-map-card
      title: Wohnung
      view_layout:
        grid-area: map
      card_mod:
        class: header
        style: |
          ha-card {
            --map-card-primary-color: #FFFFFF10;
            --map-card-secondary-color: none;
            --map-card-secondary-text-color: #9da0a2;
            --map-card-zoomer-background: none;
            --map-card-predefined-rectangle-fill-color: none;
            --map-card-predefined-rectangle-line-color: none;
            --map-card-predefined-rectangle-line-color-selected: rgba(255, 255, 255, 0.5);
            --map-card-predefined-rectangle-fill-color-selected: rgba(42, 124, 194, 0.1);
            --map-card-predefined-rectangle-icon-background-color-selected: rgb(42, 124, 194);
            --map-card-internal-big-radius: 0.6em !important;
          div.map-wrapper, div.controls-wrapper {
            padding: var(--tablet-popup-content-padding);
            padding-top: 0;
            padding-bottom: 0;
            letter-spacing: normal;
          div.tiles-wrapper, div.vacuum-controls, #map-zoomer-overlay {
            display: none;
          div.map-controls-wrapper {
            padding-top: 24px;
          paper-button {
            --mdc-icon-size: 2em;
            color: #9da0a2 !important;
            padding: 0.42em;
      language: de
      entity: vacuum.roborock_s8
      map_source:
        camera: camera.roborock_s8_map
      calibration_source:
        camera: true
      vacuum_platform: humbertogontijo/homeassistant-roborock
      map_locked: true
      map_modes:
        - template: vacuum_clean_zone
        - template: vacuum_clean_zone_predefined
            - zones: [[17616, 24281, 23101, 27450]]
              icon:
                x: 20550
                y: 26620
            - zones: [[11559, 26113, 14718, 29816]]
              icon:
                x: 14148
                y: 27549
            - zones: [[11453, 23603, 17511, 25998]]
              icon:
                x: 15301
                y: 25468
            - zones: [[23089, 24984, 28190, 28281]]
              icon:
                x: 25703
                y: 26620
            - zones: [[19152, 27417, 23325, 29434]]
              icon:
                x: 20678
                y: 28413
            - zones: [[15448, 26395, 18183, 29356]]
              icon:
                x: 17093
                y: 28189
        - template: vacuum_goto
        - template: vacuum_follow_path
Could you share the entire code of this window?
Sure.
action: fire-dom-event
browser_mod:
  service: browser_mod.popup
    title: Rocky v2
    timeout: 300000
    style: |
      --popup-max-width: calc(385px + 550px);
      --primary-color: transparent; /* hide timeout progress */
    card_mod:
      style:
        # card divider border
        layout-card$grid-layout$: |
          hui-vertical-stack-card {
            border-right: 1.5px solid rgba(0, 0, 0, 0.2);
            border-radius: 0;
            transition: none;
          /* phone */
          @media screen and (max-width: 800px) {
              border-right: none;
              border-bottom: 1.5px solid rgba(0, 0, 0, 0.2);
    content:
      type: custom:layout-card
      layout_type: custom:grid-layout
      layout:
        margin: 0
        grid-template-columns: 385px 495px
        grid-template-rows: 1fr
        grid-template-areas: |
          "info map"
        mediaquery:
          #phone
          "(max-width: 800px)":
            grid-template-columns: 1fr
            grid-template-rows: repeat(2, 1fr)
              "info"
              "map"
      cards:
        ### Übersicht
        - type: vertical-stack
          view_layout:
            grid-area: info
          cards:
          - type: entities
            title: Übersicht
            card_mod:
              class: header
              style: |
                .card-content {
                  padding-bottom: 0;
            entities:
            - entity: sensor.roborock_s8_letzte_reinigung_ende
            - entity: input_boolean.heute_gesaugt
            - entity: counter.anzahl_reinigungen
              name: Reinigungen bis Leerung
            - type: custom:bar-card
              width: 55%
              height: 2em
              decimal: 0
              unit_of_measurement: '%'
              positions:
                icon: outside
                indicator: 'off'
              severity:
                - color: '#303435'
                  to: 999
                - color: '#6d2525'
                  to: 10
              entity_row: true
              entities:
                - entity: vacuum.roborock_s8
                  icon: mdi:battery
                - entity: sensor.template_vacuum_filter
                - entity: sensor.template_vacuum_mainbrush
                - entity: sensor.template_vacuum_sidebrush
                - entity: sensor.template_vacuum_sensors
#            - type: custom:more-info-card
#              entity: vacuum.roborock_s8
#              card_mod:
#                style:
#                  # hide everything but ha-select
#                    h1 {
#                      display: none !important;
#                    h1, state-card-content {
#                    .card-content {
#                      padding: 1.5em 0 0 0.7em;
#                  more-info-vacuum$:
#                      div.flex-horizontal>div, div:nth-child(2), ha-attributes {
#                        display: none;
#                      ha-select {
#                        display: contents;
#                    ha-select:
#                        # no icon so remove label inset
#                          .mdc-floating-label {
#                            inset-inline-start: 0 !important;
#                        # fix transparent menu background color
#                        mwc-menu$: |
#                          mwc-list {
#                            background: var(--card-background-color);
          - type: custom:mod-card
            card_mod:
              style:
                # horizontal bottom buttons
                hui-horizontal-stack-card$: |
                  #root {
                    justify-content: space-evenly !important;
                    padding: var(--tablet-popup-button-padding);
            card:
              type: horizontal-stack
              cards:
                - type: custom:button-card
                  icon: mdi:play-pause
                  tap_action:
                    service: >
                        return `[[[
                          return entity.state === 'docked' || entity.state === 'paused'
                            ? 'vacuum.start'
                            : 'vacuum.pause';
                    service_data:
                      entity_id: vacuum.roborock_s8
                  template: icon_only
                  icon: mdi:battery-charging
                  tap_action:
                    service_data:
                  template: icon_only
                  icon: mdi:delete-empty
                  tap_action:
                    service: vacuum.send_command
                    service_data:
                      command: app_goto_target
                      params: [19560, 25632]
                  template: icon_only
        ### Karte Wohnung
          title: Wohnung
          view_layout:
            grid-area: map
          card_mod:
            class: header
            style: |
              ha-card {
                padding-top: 0;
                padding-bottom: 0;
                display: none;
                padding-top: 24px;
              paper-button {
                padding: 0.42em;
          language: de
          map_source:
          calibration_source:
            camera: true
          map_locked: true
          map_modes:
                  icon:
                    x: 20550
                    y: 26620
                  icon:
                    x: 14148
                    y: 27549
                  icon:
                    x: 15301
                    y: 25468
                  icon:
                    x: 25703
                    y: 26620
                  icon:
                    x: 20678
                    y: 28413
                  icon:
                    x: 17093
                    y: 28189
you have to modify the camera template
Hello Piotr, hello community,
is there a way to evaluate whether a room has been already cleaned on the current day (e.g. with help of the vacuums position)?
In the integration no - you’ll have to build it yourself. Probably a series of boolean helpers you store on/off states for each room.
I didnt use the xiaomi cloud extractor.
But I found a way:
          map_source:
            crop:
              top: 0
              left: 50
              right: 125
              botton: 50
You can check if vacuum is in a specific room using data from vacuum_room attribute (only if you use Map Extractor). Based on this data you can extrapolate if specific room was cleaned
The Ecovacs integration release.
I already integrated. Nice
