Hi there, i tried to insert valetudo room cleaning according to the webpage: Home Assistant | Valetudo but the configuration for /config/customize.yaml seems to be wrong. When starting home assistant with it, it says:
expected a dictionary for dictionary value @ data['customize']['input_boolean.vacuum_hallway']. Got 'room_id:2'
Same for all other entries in that file. How to fix it?
I tried the original configuration which says:
input_boolean.vacuum_hallway:
room_id: "18"
input_boolean.vacuum_livingroom:
room_id: "16"
input_boolean.vacuum_bedroom:
room_id: "20"
input_boolean.vacuum_kitchen:
room_id: "17"
input_boolean.vacuum_study:
room_id: "19"
after this I tried:
- input_boolean.vacuum_hallway:
room_id: "18"
- input_boolean.vacuum_livingroom:
room_id: "16"
- input_boolean.vacuum_bedroom:
room_id: "20"
- input_boolean.vacuum_kitchen:
room_id: "17"
- input_boolean.vacuum_study:
room_id: "19"
which gets rid of the aforementioned error but home-assistant still runs in safe mode and says:
2021-12-04 20:37:47 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] while scanning a simple key
in “/config/customize.yaml”, line 2, column 3
could not find expected ‘:’
in “/config/customize.yaml”, line 3, column 1
2021-12-04 20:37:47 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: while scanning a simple key
in “/config/customize.yaml”, line 3, column 1. Activating safe mode
