According to the instructions the card should be registered right away - it was not.
Also acc. to the instructions the path for manual registering should be
According to your information I was finally able to fix it !!!
I had to add a new card explicitly to the dashboard.
The above shown card was added automatically once the robot was detected the first time.
But I had to adjust the lovelace config slightly (due to different valetudo firmware ?):
Sorry to dig this up but I have the same problem. Installed HACS and the valetudo map, latest versions of course. HA is current.
The .js ended up in /config/www/community/lovelace-valetudo-map-card/.
There is no /local/… path on my system. Do I have to create it? (that would be no problem)
Hey everyone, so recently I am the proud owner of a Dreame L10 Pro. I have rooted it with Valetudo and all is well.
The only issue i’m experiencing is that I can’t seem to get the map card working for lovelace.
It is showing the Valetudo image alright. But it keeps saying I need to install the map card.
I have installed it through HACS, also inspected the MQTT package from the vacuum and I see map data being sent. But somehow, no matter what I do it is not showing.
Also tried clearing my cache, makes no difference.
Hopefully someone can help me since it’s such a cool feature.
Hi
I have the same problem as my pioneer, I’ve already searched the internet and haven’t found a solution. I just can’t get the card to work, hopefully someone else reading here can help.
For who is looking for a really easy way to do integrate the maps from Valetudo… the Valetudo Vacuum Camera is configurable with few simple steps, download, install, setup without a line of code written.
