Brilliant work! I’ll be testing it out soon.
Edit 1:
Okay, so far it seems to work okay… Except I’m now unable to configure colours. If I configure just the colours without transparency, I get an “Unknown error”, with the following logs:
Logger: aiohttp.server
Source: /usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py:421
First occurred: 11:57:19 (3 occurrences)
Last logged: 11:57:36
Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_protocol.py", line 452, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 543, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 114, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 233, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 31, in headers_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 149, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 63, in with_admin
return await func(self, request, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 234, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 293, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 389, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/valetudo_vacuum_camera/config_flow.py", line 554, in async_step_base_colours
return await self.async_step_opt_save()
File "/config/custom_components/valetudo_vacuum_camera/config_flow.py", line 700, in async_step_opt_save
opt_update = await update_options(self.bk_options, self.options)
File "/config/custom_components/valetudo_vacuum_camera/common.py", line 104, in update_options
updated_options[key] = bk_options[key]
KeyError: 'enable_www_snapshots'
If I try to set transparency, it jumps back to the colour config panel, without saving any info.
I re-created the integration entry from scratch so the old config should not be an issue.
