Hi Roberto,
Thank you very much for trying Velair, for signing up to share this, and for such a detailed explanation. I really appreciate it.
If I understand correctly, you are looking for something beyond climate scheduling: a local assistant that could learn how each room reacts to the climate device, fan speed, outdoor conditions, doors, windows, sun and wind, and then suggest actions such as opening or closing a window at the most appropriate time.
Velair already provides some of the building blocks, but it does not currently support that complete use case.
Adaptive Preconditioning learns how long a room takes to approach a scheduled target. It keeps heating and cooling observations separate and can optionally use the current outdoor temperature to select similar historical observations. However, it does not currently include weather forecasts, humidity, fan speed, door/window states, wind direction or solar exposure in its learning model.
Room Assist can use an external temperature sensor to adjust the target sent to a climate entity. A calculated Heat Index sensor might technically be usable if Home Assistant exposes it as a valid numeric temperature sensor, although this is not a configuration specifically designed or tested by Velair. Care would also be needed if VTherm is already performing its own target correction, as having both systems adjust the target could create two overlapping control loops.
Velair’s Comfort feature can evaluate temperature and humidity together, but it is intentionally informational: it reports the current environmental condition and exposes events for Home Assistant automations. Windows and doors can also be used with the optional blueprint to pause a zone, but Velair does not currently learn their thermal effect or recommend when they should be opened or closed.
The complete system you describe would be technically possible, but it would be a considerable project. Each room would need enough observations for many combinations of season, outdoor temperature, humidity, wind, solar exposure, fan speed and opening state. It would also be difficult to determine which factor actually caused a temperature change. Recommendations involving humidity would need to consider values such as absolute humidity or dew point rather than relative humidity alone.
For that reason, I would be cautious about adding such a broad and difficult-to-validate model directly to Velair’s core.
A smaller and potentially useful direction could be an optional, local “ventilation opportunity” indicator. It could initially use clear and explainable rules based on indoor and outdoor temperature, comfort targets, humidity or dew point, window state, climate activity and perhaps the short-term forecast. It would only provide suggestions, without controlling doors, windows or climate devices automatically. Starting with deterministic recommendations would also let us evaluate whether learning is genuinely necessary later.
So the full proposal is not currently supported, but I do think the underlying idea is interesting. The narrower ventilation-assistance use case may be worth exploring, provided it can remain local, understandable and reliable without making the normal Velair experience more complex.
Thank you again for sharing your setup and the idea in such detail. It is very useful feedback.
