Velbus integration - removing a device
Does anyone know how to remove a Velbus device in the Velbus integration?
I have replaced a Velbus device by another in my installation (a VMBGP1 by a VMBEL4).
When I reload the Velbus configuration in the Velbus integration, Home Assistant discovers the new device, fine. But the old device is not removed from the integration, and I get errors messages in the HA logs.
Thank you
I think this is something to do with cleaning the HA (Velbus) cache
But I’m not sure
@fontainechristophe
Is this along the same lines as you’re thinking?
Hello Stuart,
Yes, the other message is actually also from me.
This message is to know how to remove a Velbus device.
The other message concerns the clear_cache… but it seems the clear_cache is the solution to the problem.
Thank you
