Unfortunately I’ve done all this, no difference between quotes or not. I cannot find Velux at all in the integrations part, not showing up to choose it
These are the errors showing up in the log when I just started the HA
Can not process <Telegram direction=“Incoming” source_address=“1.0.16” destination_address=“10/3/14” payload="<GroupValueResponse value="" />" /> for Licht Zimmer 1 - State: <CouldNotParseTelegram description=“Payload invalid” payload=""/>
21:53:58 – (WARNING) /usr/local/lib/python3.9/site-packages/xknx/remote_value/remote_value.py - message first occurred at 21:51:37 and shows up 5 times
Could not sync group address ‘12/0/1’ (Stromverbrauch Total - Value)
21:53:41 – (WARNING) /usr/local/lib/python3.9/site-packages/xknx/remote_value/remote_value.py - message first occurred at 21:51:37 and shows up 4 times
Error: KNX bus did not respond in time (2.0 secs) to GroupValueRead request for: 12/0/1
21:53:41 – (WARNING) /usr/local/lib/python3.9/site-packages/xknx/core/value_reader.py - message first occurred at 21:51:37 and shows up 4 times
custom-components/wienerlinien - Repository is archived.
21:51:54 – (ERROR) HACS (custom integration) - message first occurred at 21:51:54 and shows up 2 times
Setup failed for velux: Integration failed to initialize.
21:51:51 – (ERROR) setup.py
Can’t connect to velux interface:
21:51:51 – (ERROR) velux
Setup of velux is taking over 10 seconds.
21:51:43 – (WARNING) /usr/local/lib/python3.9/asyncio/events.py
Error doing job: application protocol failed to receive SSL data
21:51:41 – (ERROR) /usr/src/homeassistant/homeassistant/runner.py
Entity sensor.hacs (<class ‘custom_components.hacs.sensor.HACSSensor’>) implements device_state_attributes. Please report it to the custom component author.
21:51:37 – (WARNING) helpers/entity.py
Detected code that uses str for device registry entry_type. This is deprecated and will stop working in Home Assistant 2022.3, it should be updated to use DeviceEntryType instead. Please report this issue.
21:51:37 – (WARNING) helpers/frame.py
192.168.0.78 is not logged in to a HEOS account and will be unable to retrieve HEOS favorites: Use the ‘heos.sign_in’ service to sign-in to a HEOS account
21:51:35 – (WARNING) Denon HEOS
The ‘tunneling’ option near /config/configuration.yaml:31 is deprecated, please remove it from your configuration
21:51:34 – (WARNING) KNX
