I just wanted to share the custom Venetian blinds icons I made
How can I setup a card similar to the one you show here?
Here is the lovelace yaml for that card. As you can see it uses the slider-entity-row custom card.
- type: entities
title: Coverings
entities:
- entity: cover.left_window_33
type: custom:slider-entity-row
- entity: cover.center_window_34
- entity: cover.right_window_35
- type: divider
- entity: cover.bedroom_window_40
- entity: cover.office_window_41
@jcrowegitHu8 how did you set up the slider-entity-row? I am trying to add it, but I just get the custom element doesnât exist error?
edit: nevermind, I got it working
Iâve been trying to get this working for 2 weeks.
It seems like my if statements in my customize_glob.yaml file arenât working.
I can put the file directory there and not have the if statements and it worksâŚbut it just has that picture and not a dynamic one.
âcover.tradfri_blind_*â:
templates:
entity_picture: >
if (state === âclosedâ) return â/local/blinds_00.pngâ;
if (attributes.current_position <= 10) return â/local/blinds_10.pngâ;
if (attributes.current_position <= 20) return â/local/blinds_20.pngâ;
if (attributes.current_position <= 30) return â/local/blinds_30.pngâ;
if (attributes.current_position <= 40) return â/local/blinds_40.pngâ;
if (attributes.current_position <= 50) return â/local/blinds_50.pngâ;
if (attributes.current_position <= 60) return â/local/blinds_60.pngâ;
if (attributes.current_position <= 70) return â/local/blinds_70.pngâ;
if (attributes.current_position <= 80) return â/local/blinds_80.pngâ;
if (attributes.current_position <= 90) return â/local/blinds_90.pngâ;
return â/local/blinds_99.pngâ;
So I copy the icons to /www/
create new file âcustomize_glob.yamlâ
add resources to ui edit page
Create card like the example
- type: entities
title: Coverings
entities:
Anfo not show the icon on the screen
Show only the old one mdi:blind
What I miss?
Using 102.3HA version
Did you actually install and setup the custom_ui per their github page?
Iâm back on version 94 HA, so I canât say if something has changed that may be breaking your version of 102.3HA.
What version of HA are you on? If you got this working could you post how so other may benefit.
These are great and also useful for roller blinds (in my opinion)
Well done and my thanks too.
Have you submitted these into materialdesignicons ?
That way they will eventually end up in every HA instance
I did not find a solution. I was able to use the cutom_ui and have a single .png file as the icon but as soon as I introduced if statements to the customize_glob.yaml / config.yaml file it goes blank with no icon being displayed. Which leads me to believe the issue is with the if statement. Running Home Assistant 0.101.2
Great suggestionâŚNo I have not, Itâs not really clear how I submit the 5 icons, or what formats they should be in. This information doesnât specify much https://materialdesignicons.com/contribute
Can you offer any guidance on how to submit them? Inputting the info and clicking become a contribute doesnât seem to do anything.
Sorry not done that myself, try just Googling it
@Tinkerer, sorry to tag you, but can you help ?
I think Blackbirdâs blind icons would be a very good addition AND
We could always appeal to his good nature if we need a particular icon for some use in future
We have a homeassistant icon on there so âweâ must have a path ?
I realise how cheeky Iâm being here but I think he/she has a really useful skill that I (for one) think, the output of which, should reach a wider audience.
Sure, I can say submit the icons to MDI, then wait for a release. Then submit a PR to have Home Assistant use that new version (as was done here)âŚ
The contribute page specifies 4 format options (Illustrator, Expression, Affinity, SVG) which they provide templates for, and that submissions are through their GitHub.
Thanks,
Blackbird, I assume that will give you enough to progress.
I really hope to see your work available in native HA
Hi Guys!
I need some help here.
Iâm trying to do this adaption to my blinds, but the icon is not working after I do this customization.
I will try to describe all the steps I made:
- I had installed the customizer (https://github.com/andrey-git/home-assistant-customizer/ )
" Putcustomizerdir in<ha_config_dir>/custom_components/" - Added to my configuration.yaml
homeassistant:
customize: !include customize.yaml
customize_glob: !include customize_glob.yaml
- in customize_glob.yaml I added the following code:
"cover.rollershutter_*":
templates:
entity_picture: >
if (state === 'closed') return '/local/ihcrollershutter/rollershuttersihc-0.png';
if (attributes.current_position <= 10) return '/local/ihcrollershutter/rollershuttersihc-10.png';
if (attributes.current_position <= 20) return '/local/ihcrollershutter/rollershuttersihc-20.png';
if (attributes.current_position <= 30) return '/local/ihcrollershutter/rollershuttersihc-30.png';
if (attributes.current_position <= 40) return '/local/ihcrollershutter/rollershuttersihc-40.png';
if (attributes.current_position <= 50) return '/local/ihcrollershutter/rollershuttersihc-50.png';
if (attributes.current_position <= 60) return '/local/ihcrollershutter/rollershuttersihc-60.png';
if (attributes.current_position <= 70) return '/local/ihcrollershutter/rollershuttersihc-70.png';
if (attributes.current_position <= 80) return '/local/ihcrollershutter/rollershuttersihc-80.png';
if (attributes.current_position <= 90) return '/local/ihcrollershutter/rollershuttersihc-90.png';
return '/local/ihcrollershutter/rollershuttersihc-100.png';
Added all the icons to the folder: www/ihcrollershutter/[all PNGâs].png
Added the following configuration to lovelace:
cards:
- entities:
- entity: cover.rollershutter_dining_room_window
- entity: cover.rollershutter_kitchen_door
- entity: cover.rollershutter_kitchen_window
- entity: cover.rollershutter_master_bedroom_window
- entity: cover.rollershutter_master_bathroom_window
- entity: cover.rollershutter_guest_room_window
- entity: cover.rollershutter_office_window
show_header_toggle: false
title: Rollershutters
type: entities
After restarting Homeassistant there is no icons in my blinds and they dont update when the blind moves. Anyone can guide me in order to solve this issue?
Thanks !!!
Can someone help me here? Thanks
Hi, I donât know anything about the âcustomizerâ, so sorry I canât help with this directly. However I can make some alternative recommendations:
I have used the Button Card to do this with cover shades:
Lovelace: Button card
This is a very popular custom card, but it is very complex and not for everybody. -
But you may want to look instead at the following:
đ 100% Templatable Lovelace Configurations
I have used this to display a cover (tilt blind) icon of my choosing based on state open or closed using a template, and I would think you could use the template based on current_position. -
Or even have a look at the following which I have also used for a cover (tilt blind) icons:
Lovelace card-templater card (Jinja2 card templating in Lovelace!)
Just add:
customizer:
custom_ui: hosted
to your
configuration.yaml
file. Than it should work
At least that did the trick for me.
For more info look at the âUsingâ section of the GitHubRep of home-assistant-customizer
