I’ve just installed (yesterday) a Fibaro FGD212 dimmer 2 unit and i’ve managed to get the basics setup (not done any config of the dimmer unit yet so its all defaults) and i’m noticing this repeating in the “OZW_Log.txt” file:
2016-10-23 20:16:32.601 Info, mgr, Refreshing node 80: COMMAND_CLASS_SWITCH_MULTILEVEL index = 6 instance = 1 (to confirm a reported change)
2016-10-23 20:16:32.655 Info, mgr, Refreshing node 80: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 1 (to confirm a reported change)
2016-10-23 20:16:32.655 Detail, Node080, Queuing (Send) MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=80): 0x01, 0x0d, 0x00, 0x13, 0x50, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x 26, 0x02, 0x25, 0x61, 0xba
2016-10-23 20:16:32.655 Info, Node080, Sending (Send) message (Callback ID=0x61, Expected Reply=0x04) - MultiChannel Encapsulated (instance=1): SwitchMultilevelCmd_Get (Node=80): 0x01, 0x0d, 0x 00, 0x13, 0x50, 0x06, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x02, 0x25, 0x61, 0xba
2016-10-23 20:16:32.663 Detail, Node080, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-10-23 20:16:32.663 Detail, Node080, ZW_SEND_DATA delivered to Z-Wave stack
2016-10-23 20:16:32.675 Info, mgr, Refreshing node 80: COMMAND_CLASS_SWITCH_MULTILEVEL index = 6 instance = 2 (to confirm a reported change)
2016-10-23 20:16:32.678 Info, mgr, Refreshing node 80: COMMAND_CLASS_SWITCH_MULTILEVEL index = 0 instance = 2 (to confirm a reported change)
2016-10-23 20:16:32.678 Detail, Node080, Queuing (Send) MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=80): 0x01, 0x0d, 0x00, 0x13, 0x50, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x 26, 0x02, 0x25, 0x62, 0xba
2016-10-23 20:16:32.793 Detail, Node080, Received: 0x01, 0x07, 0x00, 0x13, 0x61, 0x00, 0x00, 0x0e, 0x84
2016-10-23 20:16:32.794 Detail, Node080, ZW_SEND_DATA Request with callback ID 0x61 received (expected 0x61)
2016-10-23 20:16:32.794 Info, Node080, Request RTT 138 Average Request RTT 149
2016-10-23 20:16:32.794 Detail, Expected callbackId was received
2016-10-23 20:16:32.912 Detail, Node080, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x50, 0x07, 0x60, 0x0d, 0x01, 0x01, 0x26, 0x03, 0x63, 0x8a
2016-10-23 20:16:32.913 Info, Node080, Response RTT 257 Average Response RTT 269
2016-10-23 20:16:32.913 Info, Node080, Received a MultiChannelEncap from node 80, endpoint 1 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2016-10-23 20:16:32.913 Info, Node080, Received SwitchMultiLevel report: level=99
2016-10-23 20:16:32.913 Detail, Node080, Refreshed Value: old value=99, new value=99, type=byte
2016-10-23 20:16:32.913 Detail, Node080, Changes to this value are not verified
2016-10-23 20:16:32.913 Detail, Node080, Expected reply and command class was received
2016-10-23 20:16:32.913 Detail, Node080, Message transaction complete
2016-10-23 20:16:32.913 Detail, Node080, Removing current message
2016-10-23 20:16:32.913 Detail, Node080, Notification: ValueChanged
2016-10-23 20:16:32.949 Detail,
2016-10-23 20:16:32.950 Info, Node080, Sending (Send) message (Callback ID=0x62, Expected Reply=0x04) - MultiChannel Encapsulated (instance=2): SwitchMultilevelCmd_Get (Node=80): 0x01, 0x0d, 0x 00, 0x13, 0x50, 0x06, 0x60, 0x0d, 0x01, 0x02, 0x26, 0x02, 0x25, 0x62, 0xba
2016-10-23 20:16:32.958 Detail, Node080, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-10-23 20:16:32.958 Detail, Node080, ZW_SEND_DATA delivered to Z-Wave stack
2016-10-23 20:16:33.151 Detail, Node080, Received: 0x01, 0x07, 0x00, 0x13, 0x62, 0x00, 0x00, 0x13, 0x9a
2016-10-23 20:16:33.151 Detail, Node080, ZW_SEND_DATA Request with callback ID 0x62 received (expected 0x62)
2016-10-23 20:16:33.151 Info, Node080, Request RTT 201 Average Request RTT 175
2016-10-23 20:16:33.151 Detail, Expected callbackId was received
2016-10-23 20:16:33.273 Detail, Node080, Received: 0x01, 0x0d, 0x00, 0x04, 0x00, 0x50, 0x07, 0x60, 0x0d, 0x02, 0x01, 0x26, 0x03, 0x00, 0xea
2016-10-23 20:16:33.273 Info, Node080, Response RTT 324 Average Response RTT 296
2016-10-23 20:16:33.274 Info, Node080, Received a MultiChannelEncap from node 80, endpoint 2 for Command Class COMMAND_CLASS_SWITCH_MULTILEVEL
2016-10-23 20:16:33.274 Info, Node080, Received SwitchMultiLevel report: level=0
2016-10-23 20:16:33.274 Detail, Node080, Refreshed Value: old value=0, new value=0, type=byte
2016-10-23 20:16:33.274 Detail, Node080, Changes to this value are not verified
2016-10-23 20:16:33.274 Detail, Node080, Expected reply and command class was received
2016-10-23 20:16:33.274 Detail, Node080, Message transaction complete
2016-10-23 20:16:33.274 Detail, Node080, Removing current message
2016-10-23 20:16:33.274 Detail, Node080, Notification: ValueChanged
Any ideas - Seems to be very chatty and just didnt want it swaping my zwave network.
Thanks!
