This topic was opened 5 years ago and except in very particular circumstances is not useful anymore so I wanted to close it but can’t find a way to do that on the forum.
On the subject of integrating Victron equipment with HA here is a short summary for those ending up here:
Use the VRM API as explained in this thread
When? If your Victron installation is remote and it’s only connection to the “world” is via VRM
Use MQTT as explained in many threads and specifically here
When? If you’re familiar with MQTT and envision the use of, for instance, Red-Node, for logic programming and automations
Use modbusTCP either using DYI config or using the excellent HACS integration from @sfstar you can find here
When? If you’re familiar with modbus and like to keep it simple
After having used all 3 methods I am now and for the foreseeable future using modbus because I have other modbus integrations in my HA such as for instance swimming pool filters/clorinator, Fronius inverter, etc. which reduces the number of integration and keeps it simple. But this is a purely personal choice, feel free to test and try and break and share your experiences.
If you want Victron’s opinion please read this post by Matthys Vader on the subject. you can find the complete thread here
I am using Modbus TCP and it works great. It’s just matter of downloading the Modbus TCP register list from Victron technical info, and then write sensor definitions for selected parameters, for example
If you can use modbus or MQTT this is of course a much better way, but if you use globalLink the VRM api is the only way to integrate.
I have a cabin with solar power only, and being in Norway and in a northfacing slope i have zero sun from Nov - Mar so having anything other than a globallink to watch my system is impossible without draining the batteries.
The globallink use 4g LTE-M to send data each 15 mins directly to the VRM. It use very little energy, but cannot be remotely accessed any other way than by the VRM api.
The globalLlink have a relay so i can turn on my 4g wifi-modem and webcams etc to make quick checkouts and then turn off everything except the globallink again.
BTW the api have a full web interface for testing out all the calls from a browser at
I didn’t see this in the thread. If its there i apologize.
Very easy to test out all calls, just remember that the tokens should be written without the surrounding “<>” signs (Took me a while to figure that one out…)
Hello, I have a problem and hope someone can help:
I connected via VRM API.
vrm is connected.
However, I don’t get any battery data.
I have the data set from here:
platform: template
sensors:
vrm_temp:
friendly_name: ‘VRM Battery temperature’
value_template: ‘{% for item in states.sensor.vrm_data.attributes.records if item[“code”] == “CT” and item[“instance”] == 521 %}{{ item[“formattedValue”][ :-2] | float() | round(1) }}{% endfor %}’
unit_of_measurement: ‘°C’
battery:
friendly_name: ‘VRM Battery’
value_template: ‘{% for item in states.sensor.vrm_data.attributes.records if item[“code”] == “SOC” and item[“instance”] == 288 %}{{ item[“formattedValue”][ :-2] | float() | round(1) }}{% endfor %}’
unit_of_measurement: ‘%’
Data from VRM:
sensor.vrm_data
success: true
records:
idSite: *******
accessLevel: 1
owner: true
is_admin: true
identifier: *********
idUser: *******
pvMax: 0
time zone: Europe/Berlin
phonenumber: zero
notes: zero
geofence: zero
geofenceEnabled: false
realtimeUpdates: true
hasMains: 0
hasGenerator: 0
noDataAlarmTimeout: null
alarm monitoring: 1
invalidVRMAuthTokenUsedInLogRequest: 0
syscreated: 170*****
isPaygo: 0
paygoCurrency: null
paygoTotalAmount: zero
idCurrency: 1
currencyCode: EUR
currencySign: €
currencyName: Euro
inverterChargerControl: 0
shared: false
device_icon: battery
friendly_name: vrm data
Hi. Difficult to say with the data you provide. Have you checked the vrm_data output for the instance carrying the SOC?
But before that, are you using the API because your HA instance is not on the same network/site as the Victron installation, or for another reason? Could you use MQTT or modbus?
I suspect that I inserted incorrect data by copying it. Do I get the sensor data via Postmann or are they standard values?
Yes, I’m not on the same network, otherwise it would be easier.
Yes, but overlooked the fact that you can’t have more than one "sensor: " in configuration.yaml.
Had to comment out the Nordpool one, now I have to figure out how to use both Nordpool and VRM sensor configured.
You can have as many sensors as you want, just declare them on separate lines. Or better, if they’re based on templates, put them in a separate template.yml file and include the file. Anyway, glad you found out what the issue was.
