Victron VRM Portal API data integration
Sorry but I don’t really understand your question.
Are you successfully connecting to the API? If so you should see all the topics and not only three of them. Maybe share your Config for this integration.
As I mentioned in other responses I assume you need to use the API integration because your Home Assistant instance is not local to the Victron installation? Is that correct or are both on the same site in which case better to use modbus.
I can connect to the API but i cannot see all the values shared in the app, that i think uses the same api to show data.
I’m interensted in the output load measurement of the mppt in wich there is power from the battery that i want to monitor over night. But i cannot find it in any endpoint that has the load output of the mppt. So the question about.
It is not local because too much power requirement against my long lasting objectives. So i wish to not use modbus. I could create a vpn and collect modbus but if it can be done throught api i would prefere it.
Are you using something like MQTT Explorer to view all the topics exposed? If you want help you need to provide more info.
No, I’m not using the mqtt explorer. I use curl call directly and see results by sight and chatgpt.
I will try mqtt explorer at that point. But it is a local lan option. I wish to contact the API on web and extract info from it.
Wich info do you need?
I had many more values from the API endpoint. The endpoint stats has some specification also like venus, live_feed ecc… i tried anyone but cannot find desired values. Here is the variable table builted with chatgpt but not verified by me. Anyway lots of values semmed not available and, the output load, value of my interest, is not present seems.
Variable Description Value API Requests
Pdc Series of values (DC power) Variable values (e.g., 1730205972000, 59.6) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
tsT Series of values (temperature) Variable values (e.g., 1730205972000, 37.5) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
solar_yield Series of values (solar yield) Variable values (e.g., 1730205972000, 59.6) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
total_solar_yield Single value (total solar yield) 380.7275717778273 GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
ac_loads Single value (AC loads state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
consumption Single value (consumption state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
consumption_input Single value (input consumption state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
consumption_output Single value (output consumption state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
hub_inverter Single value (hub inverter state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
from_to_grid Single value (grid transfer state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
ac_in Single value (AC input state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
ac_out Single value (AC output state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
ac_genset Single value (AC generator state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
bv Series of values (battery voltages) Variable values (e.g., 1730205972000, 13.2) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
bs Single value (battery state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
dc Single value (DC state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
evp Single value (EVP state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=venus
total_consumption Single value (total consumption) 0 GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
total_genset Single value (total generator state) 0 GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
grid_history_to Single value (grid transfer history) 0 GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
grid_history_from Single value (grid transfer history) 0 GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
iOI1 Single value (I/O 1 state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=live_feed
Pc Single value (power consumption) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=consumption
Bc Single value (Bc state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=consumption
gc Single value (gc state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=consumption
Gc Single value (Gc state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=consumption
Pb Series of values (solar power) Variable values (e.g., 1730206148000, 0.06) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=solar_yield
GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=kwh
kwh Series of values (consumption in kWh) Variable values (e.g., 1730206148000, 0.06) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=kwh
gb Single value (generator state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=generator
gc Single value (gc state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=generator
Tga Single value (generator runtime state) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=generator-runtime
solar_yield_forecast Series of values (solar yield forecast) Variable values (e.g., 1730206217000, 44.45) GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=forecast
vrm_consumption_fc Single value (VRM consumption forecast) false GET https://vrmapi.victronenergy.com/v2/installations/<installationID>/stats?type=forecast
I don’t understand/know what “ree by sight” is and how chatgpt would be useful here, but then, I don’t know much.
When I used the API I used Postman to get the full output of the call and sifted through the output to find what I needed.
But if you use MQTT to setup and debug it can go faster, I guess, and you have an MQTT broker on the Victron GX device itself (CCGX or Cerbo whichever you are using). You can then use MQTT Explorer, and once you connect it to your MQTT broker you will see what there is to see i.e. all the topics published. Just follow the instructions of section 3 here and let us know what you find out. Once you get is sorted out then you know which topics you need and where to find them.
If you want to share info maybe start with your config and the output of your API call. Hide the token.
Not sure if my video at https://youtu.be/dlvlhou70VA?si=oG_Kt0j17IlWsrhq&t=2654 will help - I was using Modbus to query the registers. But maybe the explanation will also help give some context to getting the values you need.
I apologize for any confusion; I’ve just edited the post to enhance its clarity.
I used ChatGPT to organize the API requests (curl prompts) and interpret the results in order to create sensor code for Home Assistant. Additionally, it helped me identify and sort the different variables provided in the API response.
I realize that I may need to improve my understanding of MQTT technology, I cant understand why could be faster to debug if i’m talking with the VRM cloud, so I plan to study it further.
Currently, my setup includes VenusOS running on a Raspberry Pi Zero W installed in my van, which is connected to an MPPT charger. This allows me to log data and send it to the cloud. VenusOS is connected to the internet via a local Wi-Fi network provided by a USB LTE modem. I could potentially connect Venus to a VPN and utilize either Modbus or MQTT. I’ve experimented with Modbus locally for a short period.
here follow an example of API request and response
curl --request GET \
  --url 'https://vrmapi.victronenergy.com/v2/installations/XXXXXX/stats?type=venus' \
  --header 'Content-Type: application/json' \
  --header 'x-authorization: Token xxxxxxxxx'
  "success": true,
  "records": {
    "Pdc": [
        1730205972000,
        59.60095029448269
        1730209572000,
        36.343699740467486
        1730213172000,
        7.898400218510152
        1730216772000,
        0.17290158924804586
        1730220372000,
        -0.48191678569713836
        1730223972000,
        -0.39405010081529995
        1730227572000,
        -0.41556676441034146
        1730231172000,
        -0.30578339365919494
        1730234772000,
        -0.43650007394949325
        1730238372000,
        -0.4360333640307201
        1730241972000,
        -0.3267167019963283
        1730245572000,
        -0.28301665526529335
        1730249172000,
        -0.45676664649843324
        1730252772000,
        -0.5436333062072466
        1730256372000,
        -0.3259999796152
        1730259972000,
        -0.5649666290501633
        1730263572000,
        -0.390899970279145
        1730267172000,
        0.2349999788012672
        1730270772000,
        8.95040004338428
        1730274372000,
        24.769866814174236
        1730277972000,
        46.68718345928589
        1730281572000,
        59.96340027594672
        1730285172000,
        63.51836813388071
        1730288772000,
        77.94925160111977
    "tsT": [
        1730205972000,
        37.491666666666625,
        36.5,
        38.6
        1730209572000,
        37.80333333333329,
        37,
        38.6
        1730213172000,
        38.064999999999955,
        37,
        38.6
        1730216772000,
        37.311475409836056,
        36.5,
        38.1
        1730220372000,
        36.16500000000004,
        35.4,
        37.6
        1730223972000,
        34.81000000000001,
        34.3,
        35.9
        1730227572000,
        33.675000000000004,
        32.7,
        34.9
        1730231172000,
        32.61833333333337,
        32.2,
        33.8
        1730234772000,
        31.894999999999985,
        31.1,
        32.7
        1730238372000,
        31.256666666666636,
        30.6,
        32.2
        1730241972000,
        30.724999999999984,
        30,
        31.6
        1730245572000,
        30.336666666666662,
        29.5,
        31.1
        1730249172000,
        29.65333333333334,
        28.9,
        30.6
        1730252772000,
        29.388333333333343,
        28.9,
        30
        1730256372000,
        29.110000000000024,
        27.9,
        30
        1730259972000,
        28.956666666666692,
        27.9,
        30
        1730263572000,
        28.61833333333336,
        27.9,
        29.5
        1730267172000,
        28.490163934426256,
        27.9,
        28.9
        1730270772000,
        28.466666666666693,
        27.9,
        28.9
        1730274372000,
        29.285000000000007,
        28.9,
        30
        1730277972000,
        30.563333333333297,
        29.5,
        31.6
        1730281572000,
        32.37333333333336,
        31.1,
        33.8
        1730285172000,
        34.08833333333333,
        32.7,
        35.4
        1730288772000,
        35.99666666666667,
        34.9,
        37
    "ac_loads": false,
    "consumption": false,
    "consumption_input": false,
    "consumption_output": false,
    "solar_yield": [
        1730205972000,
        59.60095029448269
        1730209572000,
        36.343699740467486
        1730213172000,
        7.898400218510152
        1730216772000,
        0.17290158924804586
        1730220372000,
        1730223972000,
        1730227572000,
        1730231172000,
        1730234772000,
        1730238372000,
        -0.4360333640307201
        1730241972000,
        -0.3267167019963283
        1730245572000,
        1730249172000,
        1730252772000,
        -0.5436333062072466
        1730256372000,
        -0.3259999796152
        1730259972000,
        -0.5649666290501633
        1730263572000,
        -0.390899970279145
        1730267172000,
        0.2349999788012672
        1730270772000,
        8.95040004338428
        1730274372000,
        24.769866814174236
        1730277972000,
        46.68718345928589
        1730281572000,
        59.96340027594672
        1730285172000,
        63.51836813388071
        1730288772000,
        77.94925160111977
    "hub_inverter": false,
    "from_to_grid": false,
    "ac_in": false,
    "ac_out": false,
    "ac_genset": false,
    "total_solar_yield": [
        1730205972000,
        0.05999755859375
        1730209572000,
        0.029998779296875
        1730213172000,
        0.009979248046875
        1730270772000,
        0.010009765625
        1730274372000,
        0.029998779296875
        1730277972000,
        0.050018310546875
        1730281572000,
        0.069976806640625
        1730285172000,
        0.05999755859375
        1730288772000,
        0.05999755859375
    "bs": false,
    "dc": false,
    "evp": false
  "totals": {
    "Pdc": 380.7275717778273,
    "tsT": 777.1433060109289,
    "ac_loads": 0,
    "consumption": 0,
    "consumption_input": 0,
    "consumption_output": 0,
    "solar_yield": 380.7275717778273,
    "hub_inverter": 0,
    "from_to_grid": 0,
    "ac_in": 0,
    "ac_out": 0,
    "ac_genset": 0,
    "total_solar_yield": 0.379974365234375,
    "bs": false,
    "dc": false,
    "evp": false
