Victure camera not working
I have the same problem with the PC730 on the 3.15 firmware. After analysing packets/code/the standard, the problem appears to be the firmware puts a , where a ; should be in the rtsp setup string. VLC seems to be happy with this, ffmpeg not.
I was able to mod the ffmpeg code on my laptop and it appeared to work (connection wise - laptop out of space so couldn’t display the image). I need to see about building ffmpeg for the pi next to see if it displays ok.
I’ve emailed victure about it and firmware update, but suspect the only way to get this working will be via a custom built ffmpeg (assuming I get it going on the pi). I’ll post details etc if it works.
