I took more than one month but now it’s working !!!- use onvif HA INTEGRATION
name : what you like
host: camera’s ip
port:8080
integration asks you username and password and finally discovers your camera and setup 2 entities that don’t work.
you have to go in the ONVIF integration properties option and set udp (no tcp) and than
go back to “entities” , you will find one disabled entity (FixedProfileA02). switch it on !!!.
that’s all falks !!! my victure’s cam works !
thank you very much, it works on Victure PC650
I tried the ONVIF and no dice on PC730 with 3.15. BUT I have got the PC730 working without recompiling ffmpeg. Using the RTS2P addon it proxies the rtsp stream, its forgiving of the error in the Victure stream and so ffmpeg->RTS2P->Victure camera works.
To make it work:
- Add on the RTS2P Proxy. See https://github.com/snowzach/rts2p
Set it up:
server:
port: '5554'
username: myusername
password: mypassword
streams:
- url: 'rtsp://admin:123456@ip of the camera:554/live/ch0'
verbosity: 0
- Add a ffmpeg camera:
ffmpeg:
camera:
- platform: ffmpeg
input: rtsp://myusername:mypassword@localhost:5554/acamera
You should then be able to see acamera and view the image from it using a picture glance card.
Note: I set mine up using the file editor plugin.
Hi all
I am waiting fot he following camera. Has anynone managed to add it to HA?
Victure 1080P Baby Monitor with Camera FHD WiFi IP Camera
It works on my Victure PC730!
Sorry, the HA integration does’nt work on my Victure PC530.
fantastic… this finally works! great job dude! thank you very much
For me, the solution to configure the Victure PC650 was:
Configuration -> Integrations -> add new -> Onvif
You have to know your camera IP
Port: 8080 (be sure no other camera or anything is using it, I had to change another’s camera port because of one IP conflict)
Username: admin
Password: by default is 123456, you should change it.
Finally in options, select UDP in RTSP.
You’ll get 3 entities, for me, they all work, but with different resolution.
I think that i have also a IP conflict.
What port number are you using?
Thanks!
Martin
This worked for me Many thanks
Hi, I have the same camera. Did you manage to get the camera to work?
I got this working with a PC730 using RTS2P.
GitHub - snowzach/hassio-addons: Hass.IO Repository for snowzach's add-ons. is the add on repo link required. Thanks kprida1.
I had to add in still to the config:
- url: rtsp://admin:[email protected]:554/live/ch0
still: stream
verbosity: 0
I’ve just got a PC420 cam and I can set up it up easily with Victure home app but nothing else I’ve tried works. I did IP scan and it has no ports open and nothing else in HA cannot find it.
Firmware version: 1.1.46
Is there anything I can do with it?
Should I first pair it with an app and then try to do something or the other way around?
I too have the same problem with the PC420 camera. firmware version: 1.1.37
