Hi!
Does anyone know if there is any way to integrate the motion detection sensor of the TMZON MZ-IP-V103W video doorbell https://www.tmezon.com/10-inch-ip-intercom-p0014.html
I think video is accesible for RTSP.
Thanks!
Hi!
Thanks!
Did you find anything? I’m also interested in this…
Did you get the stream of the RTSP?
I wrote to TMEZON and they confirm that don’t have any API, so I didn’t buy the device.
I will try to dissasemble ucarehome app to check if it’s possible to integrate tmezon monitor to hassio
I have this doorbell and I m very interested to integrate the tmezon in my jeedom. And in few month in my HASSIO when I change to HASSIO.
Juste if I can help you, maybe search in the web server of your tmezon. You can enter the ip adress and have access to IPDOOR. Maybe is to easy to have information…
I have also considered this. I see 2 ways to get integration:
Hello everybody. Any news about the integration of Tmezon doorbell into Home Assistant? I’m very very interested so would apreciate any contribution or tips. Thank you!
I have looked into web-ui’s “player.js” where rtsp-url is put together,
but I don’t know how to get further from here?
http://<tmezon_ip>/web/js/player.js
Line #202:
this.play = function(width, height) {
switch (GetPlayStream()) {
case '11':
playchn = 11;
break;
default:
case '12':
playchn = 12;
break;
PicWidth = width;
PicHeight = height;
try {
var vlc = this.getVLC("VLCPlayer");
itemId = vlc.playlist.add("rtsp://" + document.location.host + "/" + playchn);
so I’ve managed to work out the URL to get a still image.
The URL is http://IPAddress/cgi-bin/hi3510/param.cgi?cmd=snap&-getpic.
I also found this URL, which I think may be part of the stream but I can’t get it to work, maybe there needs to be some kind of login included in it: http://IPAddress/livestream/11?action=play&media=video_audio
Could one of you please help with how to embed the still image with a refresh rate for the time being?
hey, i managed to do it :
in vlc player, network flow :
rtsp://your_ip/11
and it works fine
How exactly did you do it? Are you sure it’s the same model? I am trying in all ways but I can’t get a video streaming
my model is the IPDoor-319BW
i edited the http://<tmezon_ip>/web/js/player.js file and found the url
And the RTSP url work on VLC or Hassio or ZoneMinder?
i have the same problem for stream RTSP. the stream doesn’t work Any idea ?
quidni qualcuno è riuscito a farlo funzionare?
Thanks me later:
Activate stream: http ://IP/cgi-bin/hi3510/doorConnect.cgi?&-door=0
Stream on : rtsp://IP/11
Unlock door… no security!!! http ://IP/web/cgi-bin/hi3510/doorUnlock.cgi
Check user: http ://IP/cgi-bin/hi3510/checkuser.cgi?&-name=USER&-passwd=PWD&-time=2021.03.25.15.08.02&-timezone=0
Reboot: http ://IP/web/cgi-bin/hi3510/reboot.cgi
I have very similar VideoDoorBell. Same interface.
The only way i can see stream is from activeX player. I can’t find any js file. What I need to do?
I see tmezon are now selling a new version compatible with Tuya https://www.amazon.co.uk/TMEZON-Wireless-Intercom-Doorbell-1x1200TVL/dp/B01N1MKRDV?th=1&psc=1.
I wonder if this will allow us to automate it using scenes and integrate it with home assistant.
Hi, do you find something?
I buy this one but doesnt work with Tuya on HA…
I also got a similar but newer device. The door unlocking does work. The video feed does not (at the moment).
But what I learned so far is the following:
My video feed URL is: rtsp://{{IP}}:80/livestream/11?action=play&media=video_audio_data
To actually get data there, I need to add an HTTP header: Authorization: ipcam w54723
But I still couldn’t figure out, how to do that with ffmpeg
