After you copied the template code to the left pane the result of the template interpretation should appear in the right pane. That is the part that you should publish here.
so {{ state_attr('climate.vicare_heating', 'current_temperature') }} = 0 , but Vicare app shows something other than 0 ???
I’m lost - this makes no sense, they are the same data.
I don’t understand either, but if it helps as I see it in Vicare. Maybe there is a bug in the app at Viessmann. I don’t know where to get that temperature, whether from circuit1 or from the boiler. The boiler has a temperature, but the circuit is not. The temperature for circuit 1 should be taken directly from the boiler.
Hello, directly from vitogiude website it looks like this. At the same time, I will ask whether it will be possible to incorporate red marked items into HA.
Have you tried reading {{ state_attr(‘climate.vicare_heating’, ‘current_temperature’) }}
while the boiler is On ?
Perhaps there’s some bug somewhere that doesn’t give the right value for boilertemp when burner is Off ?
I dunno…just thinking out loud.
I just installed HA a few hours ago. By trying to integrate my Viessmann system, I found this thread. Since the official integration is quite barebones, I downloaded all the files from the github repository.
I created the “custom_components/vicare” subfolder in the configuration folder an pasted all the filed there. After restarting HA, I find the following line in the log:
2020-04-07 19:32:30 ERROR (SyncWorker_3) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/vicare/manifest.json: Expecting value: line 7 column 1 (char 6)
What am I doing wrong?
Edit: As an additional question: Do I need to add code to the configuration file for this to work properly?
Edit 2: Do I need to remove the standard Viesmann integration somehow? Currently, I only have my Username and Password in the config file.
The result is always the same. I think that the 0 is taken from the circuit, where it is also 0 and it will be a mistake at Viessmann that for the heating system on my boiler does not take the boiler temperature into the circuit, because he does not have a sensor for circuit 1. It only has a sensor for circuit 2, which when connected, the boiler automatically programmed to have two circuits and the output temperature then I see circuit 2, but which physically does not exist.
2020-04-07 21:44:29 ERROR (SyncWorker_0) [homeassistant.loader] Error parsing manifest.json file at /config/custom_components/vicare/manifest.json: Expecting value: line 7 column 1 (char 6)
Edit: After I deleted the custom components folder, deleted everything I added to the configuration file and re-entered the standard Viessmann information, I am now not even getting the water temperature.
I would like to see in HASS
Warm water temperature (worked after new installation, not anymore)
Outside temperature from the Viessmann sensor
I am not able to set it up, since I always receive the mentioned error message in the log file if I copy the files from github.
Seems like the custom component is not working on your system for some reason. I would suggest to wait for the new home assistant version which should be out in the next weeks. Then you’ll have the current version of the integration officially.
Allright, then I will wait. Will my code above correctly read out water temp and outside temp or is there an error in the code as well?
how are you copying the files into the custom_components folder ?
I installed the official Samba share and I am seeing the Pi in the Windows Explorer and simply copy the files in the destination folder. I anything wrong with that?
Sometimes the error you get is related to a wrong/bad download of the files from Github.
Just Google "home assistant" "Expecting value: line 7 column 1 (char 6)"
Did you actually download the zip archive, then extract it, then copy the vicare folder into HA ?
Compare the contents of your vicare folder to this post (#199) in this thread : Viessmann Component
Your config looks OK, but I wouldn’t configure the integration until you have the integration installed.
