all logs:
Szczegóły loga (BŁĘDY)
Logger: homeassistant.setup
Source: components/vicare/init.py:80
First occurred: 19:48:49 (1 occurrences)
Last logged: 19:48:49
Error during setup of component vicare
File “/usr/local/lib/python3.9/site-packages/urllib3/connection.py”, line 169, in _new_conn
conn = connection.create_connection(
File “/usr/local/lib/python3.9/site-packages/urllib3/util/connection.py”, line 73, in create_connection
for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
File “/usr/local/lib/python3.9/socket.py”, line 953, in getaddrinfo
for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 699, in urlopen
httplib_response = self._make_request(
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 382, in _make_request
self._validate_conn(conn)
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 1010, in _validate_conn
conn.connect()
File “/usr/local/lib/python3.9/site-packages/urllib3/connection.py”, line 353, in connect
conn = self._new_conn()
File “/usr/local/lib/python3.9/site-packages/urllib3/connection.py”, line 181, in _new_conn
raise NewConnectionError(
urllib3.exceptions.NewConnectionError: <urllib3.connection.HTTPSConnection object at 0xb207a538>: Failed to establish a new connection: [Errno -3] Try again
File “/usr/local/lib/python3.9/site-packages/requests/adapters.py”, line 439, in send
resp = conn.urlopen(
File “/usr/local/lib/python3.9/site-packages/urllib3/connectionpool.py”, line 755, in urlopen
retries = retries.increment(
File “/usr/local/lib/python3.9/site-packages/urllib3/util/retry.py”, line 574, in increment
raise MaxRetryError(_pool, url, error or ResponseError(cause))
urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host=‘api.viessmann.com’, port=443): Max retries exceeded with url: /iot/v1/equipment/installations?includeGateways=true (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0xb207a538>: Failed to establish a new connection: [Errno -3] Try again’))
File “/usr/src/homeassistant/homeassistant/setup.py”, line 249, in _async_setup_component
result = await task
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
File “/usr/src/homeassistant/homeassistant/components/vicare/init.py”, line 80, in setup
vicare_api = GazBoiler(conf[CONF_USERNAME], conf[CONF_PASSWORD], **params)
File “/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareDevice.py”, line 60, in init
self.service = ViCareCachedService(username, password, cacheDuration, client_id, token_file, circuit)
File “/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareCachedService.py”, line 8, in init
ViCareService.init(self, username, password, client_id, token_file, circuit)
File “/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareService.py”, line 77, in init
self._getInstallations()
File “/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareService.py”, line 269, in _getInstallations
self.installations = self.__get(apiURLBase+"/equipment/installations?includeGateways=true")
File “/usr/local/lib/python3.9/site-packages/PyViCare/PyViCareService.py”, line 201, in __get
r=self.oauth.get(url).json()
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 555, in get
return self.request(‘GET’, url, **kwargs)
File “/usr/local/lib/python3.9/site-packages/requests_oauthlib/oauth2_session.py”, line 515, in request
return super(OAuth2Session, self).request(
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 542, in request
resp = self.send(prep, **send_kwargs)
File “/usr/local/lib/python3.9/site-packages/requests/sessions.py”, line 655, in send
r = adapter.send(request, **kwargs)
File “/usr/local/lib/python3.9/site-packages/requests/adapters.py”, line 516, in send
raise ConnectionError(e, request=request)
requests.exceptions.ConnectionError: HTTPSConnectionPool(host=‘api.viessmann.com’, port=443): Max retries exceeded with url: /iot/v1/equipment/installations?includeGateways=true (Caused by NewConnectionError(’<urllib3.connection.HTTPSConnection object at 0xb207a538>: Failed to establish a new connection: [Errno -3] Try again’))
