That looks so good. I mean I didn’t play much with that yet but I can see two thermostats in my lovelace, I can play with them and it all reflects in vicare app on my phone. So I can tell you it passed the smoke tests perfectly. Thanks. Lots of appreciation.
Hello!
It isn’t working for me. I only get one device with 5 entities. It were 16 before.
It looks like your changes in “sensor.py” are only for heatpumps, not for gazburners …
There is an error in my logs:
Logger: homeassistant.components.sensor
Source: custom_components/vicare/sensor.py:292
Integration: Sensor ([documentation](https://www.home-assistant.io/integrations/sensor), [issues](https://github.com/home-assistant/home-assistant/issues?q=is%3Aissue+is%3Aopen+label%3A%22integration%3A+sensor%22))
First occurred: 3:58:59 PM (3 occurrences)
Last logged: 4:07:26 PM
Error while setting up vicare platform for sensor
Traceback (most recent call last): File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 249, in _async_setup_platform await asyncio.shield(task) File "/config/custom_components/vicare/sensor.py", line 292, in async_setup_entry if len(api.burner) > 1: AttributeError: 'GazBoiler' object has no attribute 'burner'
Thanks so much, RaKa
Hi @Rakaandro
this is weird. Can you check /config/custom_components/vicare/manifest.json if it contains:
"requirements": ["PyViCare==2.8.1"],
It seems that the custom integration uses an older version of pyVicare
@Rakaandro Ignore my previous post.
I obviously had a bug there. Couldn’t find it on my end cause my device doesn’t have that information.
I updated the branch with a bugfix
I installed the brand new version and I got a new entity: burner_modulation
Super!! No errors in the logs any more.
Only burner hours & burner starts still missing …
entities:
- binary_sensor.vicare_burner_active
- sensor.vicare_burner_modulation
- sensor.vicare_heating_gas_consumption_this_month
- sensor.vicare_heating_gas_consumption_this_week
- sensor.vicare_heating_gas_consumption_this_year
- sensor.vicare_heating_gas_consumption_today
- sensor.vicare_hot_water_gas_consumption_this_month
- sensor.vicare_hot_water_gas_consumption_this_week
- sensor.vicare_hot_water_gas_consumption_this_year
- sensor.vicare_hot_water_gas_consumption_today
- sensor.vicare_outside_temperature
- sensor.vicare_supply_temperature_0
- sensor.vicare_supply_temperature_1
- water_heater.vicare_water_0
- water_heater.vicare_water_1
thanks. thanks. how can I buy you a beer? RaKa
You should buy the guys maintaining https://github.com/somm15/PyViCare a beer. They’re incredibly active and the HA integration is just making use of their huge efforts recently.
Hello, I found a way the get the missing sensors in HA:
This works for a Vitodens 200-W “B2HF” gazburner to get “burner hours” and “burner starts” sensors in HA
https://github.com/oischinger/ha_vicare/pull/52
RaKa
Hi, I played with the new longtime statistics and Home Energy Management.
Here are my template sensors to get the gas consumption. It is still under testing …
Now you can see the sensors on the energy board!
Can we implement the sensors directly into the integration?
configuration.yaml:
## Test with longtime statistic and energy management, 20.09.2021 rkr
## convert kwh gas to m3 with "Zustandszahl" & "Brennwert"
##"Zustandszahl" & "Brennwert" is different in each region, check your gas bill
template:
- sensor:
- name: Heating Gas consumption
unit_of_measurement: "m³"
device_class: gas
state_class: total_increasing
state: >
{% set zustandszahl = 0.9558 | float %}
{% set brennwert = 10.303 | float %}
{{ ((states('sensor.vicare_heating_gas_consumption_this_year') | float ) / zustandszahl * brennwert ) | round(0) }}
- name: Hot Water Gas consumption
device_class: gas
state: >
{{ ((states('sensor.vicare_hot_water_gas_consumption_this_year') | float ) / zustandszahl * brennwert ) | round(0) }}
Hi @Rakaandro
it seems like the “Zustandszahl” and the “Brennwert” must be entered on the control panel of your viessmann device and is not available on the API.
This means that we need to enter the exact same values to calculate “back” from kWh to m³ on the Home Assistant side. That’s not really the most elegant option to be honest.
I would prefer if HA would allow kWh in the energy panel for gas consumption. I also asked for that on the HA devs discord channel but no response. I’d suggest that we file an issue on github as a feature request first and see if that is possible.
There is already a feature request for gas measurements supporting kWh instead of m³ here (I commented):
Hi oischinger, thank you for your great work. Is there a possibility add the circulation pump again? It was removed in one previous version of your integration.
Thank you once again
Hello together,
unfortunately nothing is displayed to me in integration.
I have done the following steps:
- existing vicare entries in configuration.yaml deleted
- reboot
- placed the vicare folder in /custom/custom_components/vicare
- reboot
- add vicare entries in configuration.yaml
- reboot
I can only see the entities that were previously visible without oischinger package.
And in the Log i can see that:
“We found a custom integration vicare which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant”
What have i done wrong?
Sorry if it is a simple user error.
Am just about to migrate from OpenHab to HA
thank you in advance
At least if you use the branch config_flow
, there must be no entry in configruatrion.yaml
Since this integration wasn’t dedected automatically for me, I added it manually via Configuration>Integration>Add Integration>Viessmann ViCare and then used the provided GUI for configuration.
I am currently using the latest branch config_flow
, but only see four entities. Any ideas?
My setup:
Home Assistant OS 6.4
core-2021.9.7
supervisor-2021.09.0
Viessmann heatpump Vitocal 300G
I get the following error message:
This error originated from a custom integration.
Logger: homeassistant.helpers.entity
Source: custom_components/vicare/climate.py:254
Integration: Viessmann ViCare
First occurred: 11:17:54 AM (5 occurrences)
Last logged: 11:21:54 AMUpdate for climate.vicare_heating fails
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 446, in async_update_ha_state
await self.async_device_update()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 641, in async_device_update
raise exc
File “/usr/local/lib/python3.9/concurrent/futures/thread.py”, line 52, in run
File “/config/custom_components/vicare/climate.py”, line 254, in update
self._current_action = self._circuit.getCompressorActive()
AttributeError: ‘HeatingCircuit’ object has no attribute ‘getCompressorActive’
hi Climb,
before i added again the vicare entries in configuration.yaml,
i checked in integration.
in both cases autmatic and manual vicare were not visible.
for easy auto-config, you need to download from the config-flow branch ( https://codeload.github.com/oischinger/ha_vicare/zip/refs/heads/config_flow )
Drop the vicare
folder from that download into config/custom_components/
Restart Home Assistant and go to Integrations, after a minute or 2 you will see a new integration asking to be configured.
When is the water_heater.set_temperature
fix planned for integration with HA core? Or should it work already?
water_heater.set_temperature is working for me in the latest config-flow branch.
Thanks for confirmation, that’s what I’ve understood so far as well. So the big question is when it is going to be official
