I’ve just installed the config flow version of the integration and it worked seamlessly! Many thanks for your great work on it! After restart it has imported settings from configuration.yaml (I forgot to delete it before restarting). I have also tried to remove the integration, it has nicely detected it in a minute or two but when trying to set it up with the config flow “Unknown error occurred”. And in the logs I can see:
2021-10-07 09:15:35 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
resp = await self._request_handler(request)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
resp = await handler(request)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
return await handler(request)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/ban.py", line 78, in ban_middleware
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/auth.py", line 144, in auth_middleware
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/view.py", line 136, in handle
result = await result
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/config/config_entries.py", line 157, in post
return await super().post(request, flow_id)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/components/http/data_validator.py", line 62, in wrapper
result = await method(view, request, *args, **kwargs)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/data_entry_flow.py", line 111, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/data_entry_flow.py", line 198, in async_configure
result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
File "/usr/local/share/homeassistant/lib/python3.8/site-packages/homeassistant/data_entry_flow.py", line 256, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/home/homeassistant/homeassistant/custom_components/vicare/config_flow.py", line 59, in async_step_user
await self.hass.async_add_executor_job(vicare_login, user_input)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
TypeError: vicare_login() missing 1 required positional argument: 'conf'
I have PyVicare version 2.10.0 installed - this was the requirement in the manifest. Should I try with a different version/branch?
