Virtual AirPlay for whole-house amplifier?
I have a 6 zone HTD whole-house audio amplifier (which I can control through Home Assistant), and previously have used with an Alexa-based music setup. Now, we are whole-hog into Apple services (we have an Apple One+ subscription which includes, among other things, Apple Music, which is way better than Amazon music for us) and everyone who is in our house uses iPhones, Apple Watches, etc…so we want to move to an AirPlay-based system.
I know I can setup a Raspberry Pi as an AirPlay receiver, and that there are ways to tie together multiple AirPlay speakers into a “whole house” setup. However, what I’m trying to figure out is how I can emulate AirPlay on top of this amp I already have, so my people don’t have to hop between apps (Apple Music and Home Assistant) just to turn on speakers or adjust a zone’s volume.
Kind of like how AirCast emulates AirPlay on top of Chromecast, but instead on these HTD zones (each of which is seen as a media player in Home Assistant).
I’m willing to dedicate a Raspberry Pi to this endeavor, but I’d rather not buy six of them (one for each zone). I also have a server (running Windows and Home Assistant in a Virtual Box container) if that helps anything. Is there any way to create “AirPlay interfaces” in Home Assistant that I can use with automations to control my multi-zone amp, to proxy power and volume control?
To be clear: I don’t need the actual audio to be streamed on these “virtual AirPlay” devices. The audio is already happening via an actual AirPlay receiver called “whole house”, which in turn is piped into the whole house audio controller. What I’m trying to achieve is for people to select which zones they want to turn on via the AirPlay panel on an iPhone, and control each zone’s volume, without having to switch apps.
What did you end up doing?
Your goal was so that when someone connects to Airplay A, it turns on certain speakers, but when someone else connects to Airplay B, it turns on speakers specific to them? Or what kind of automations were you envisioning?
For me, I created a shortcut in Apple shortcuts to connect to Airplay and open whatever app I wanted, and then put that button with the speakers in Home Assistant.
- type: custom:button-card
        tap_action:
          action: url
          url_path: shortcuts://run-shortcut?name=AirPlay to Speakers
        entity_picture: /local/applemusic.jpeg
        show_entity_picture: true
It looks like this (well, not usually, I’m re-doing the HTD Lync12 setup since I found a custom integration someone built).
Screen Shot 2022-08-05 at 7.16.01 PM
I’m looking for exactly the same thing. Did you ever have any luck finding a solution to this?
Within HA you can use the ShairPort sync addon to turn that machine into an AirPlay server. I bought a few Belkin Soundform Connect devices as well. The bummer about those is they don’t broadcast anything to HA when they are on or not, so you can’t do any automations with them (like turn off the speakers 2 min after play stops).
Unfortunately not an elegant one. I wound up cobbling together a solution using an RPi running ShairPort sync, a couple old AirPort Expresses, and existing receivers I have that support AirPlay. They’re all jacked into the whole house amp’s various zones. It’s a real grab-bag solution on the backend, but it works reasonably well and looks “normal” to a user on their iPhone.
Hi! Very interested in your topic. I was curious which zoned amp you were using?
I’m on a control4 amp and trying to see if I have any options to use it in HA but looking for backups. My whole reason for moving to HA is to make it easy for my wife to play music on the in ceiling speakers over airplay from her phone without the cumbersome control4 process.
Thanks for any thoughts!
I used HTD for my zoned amps.
