[VM] Home Assistant broken & new instance cannot be installed
Hi there,
it has been very frustrating morning for me… I woke up and my normally working Oracle VM Home Assistant was not responding. In console I always end up in Emergency CLI no matter what I do (login cmd)… I though OK again some update broke the thing and I download a new .vdi to recover my backups… but I cannot install a fresh HA anymore as well.
I am receiving following loop of errors:
[supervisor.docker.interface] Updating image ghcr.io/home-assistant/qemux86-64-homeassistant:landingpage to ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1
[supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/qemux86-64-homeassistant with tag 2024.11.1.
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.1&fromImage=ghcr.io%2Fhome-assistant%2Fqemux86-64-homeassistant&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 987.857µs, allowed: 44000/minute")
[supervisor.homeassistant.core] Error on Home Assistant installation. Retrying in 30sec
Looking backwards I thing that my running instance failed also because of some kind of internet access error.
I cant get head around what can I do. There was no updates (my host thin client is not configured for autoupdates, there were no restarts logged or power outtages), I killed every firewall I could… any idea please?
Tomas
Same Issue here…seems theres a GitHub Problem…
I’m having the same issue.
It seems the image cannot be found:
[supervisor.docker.interface] Can't install ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1/json: Not Found ("No such image: ghcr.io/home-assistant/qemux86-64-homeassistant:2024.11.1")
I guess you are having the same issue, but already had too many retries from what i gather from your logs.
See the other topic - this isn’t a problem in HA
