m-f-g
(M F G)
November 11, 2024, 9:45am
22
i want to update my supervisor but i cant …
there is the error log.
Hope somebody can help me.
HA installed on Raspberry Pi4.
Core2024.11.1
Supervisor2024.11.2
Operating System13.2
Frontend20241106.2
Logger: homeassistant.components.websocket_api.http.connection
Quelle: components/websocket_api/commands.py:245
Integration: Home Assistant WebSocket API (Dokumentation, Probleme)
Erstmals aufgetreten: 10:19:35 (5 Vorkommnisse)
Zuletzt protokolliert: 10:32:43
[547640878000] Unexpected exception
[547340286224] Unexpected exception
[547264460064] Unexpected exception
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 262, in async_install
await self.coordinator.supervisor_client.supervisor.update()
File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/supervisor.py", line 43, in update
await self._client.post(
File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 173, in post
return await self._request(
File "/usr/local/lib/python3.12/site-packages/aiohasupervisor/client.py", line 122, in _request
raise exc_type(result.message, result.job_id)
aiohasupervisor.exceptions.SupervisorBadRequestError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("toomanyrequests: retry-after: 599.324µs, allowed: 44000/minute")
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 245, in handle_call_service
response = await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 2802, in async_call
response_data = await coro
File "/usr/src/homeassistant/homeassistant/core.py", line 2845, in _execute_service
return await target(service_call)
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1007, in entity_service_call
single_response = await _handle_entity_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 1079, in _handle_entity_call
result = await task
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 157, in async_install
await entity.async_install_with_progress(version, backup)
File "/usr/src/homeassistant/homeassistant/components/update/__init__.py", line 502, in async_install_with_progress
await self.async_install(version, backup)
File "/usr/src/homeassistant/homeassistant/components/hassio/update.py", line 264, in async_install
raise HomeAssistantError(
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/aarch64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Faarch64-hassio-supervisor&platform=linux%2Farm64: Internal Server Error ("toomanyrequests: retry-after: 599.324µs, allowed: 44000/minute")
thanks and best. greetings.
mfg
thex
November 11, 2024, 9:47am
23
Interesting that it says 44000 downloads per minute are allowed which seems quite high… however some other components now force you to upgrade supervisore before you can update them so I guess this is triggering a tonn of extra downloads from people who had been refraining from updating supervisor before
LucBe
November 11, 2024, 9:51am
25
Also here the same problem.
tom_l
26
In case you all did not see it:
WallyR:
It is a GitHub issue.
opened 09:00AM - 11 Nov 24 UTC
bug
### Describe the issue you are experiencing
Installe… d version 2024.11.2
Latest version 2024.11.3
Source: components/websocket_api/commands.py:245
integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 9:49:21 AM (2 occurrences)
Last logged: 9:49:51 AM
[140507219199600] Unexpected exception
aiohasupervisor.exceptions.SupervisorBadRequestError: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 18µs, allowed: 44000/minute")
result = await task
homeassistant.exceptions.HomeAssistantError: Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 18µs, allowed: 44000/minute")
### What type of installation are you running?
Home Assistant OS
### Which operating system are you running on?
Home Assistant Operating System
### Steps to reproduce the issue
1. Updates says there is a Supervisor Update
2. Start installing the update
3. After a few seconds the error messages apairs
### Anything in the Supervisor logs that might be useful for us?
```txt
2024-11-11 06:37:37.504 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-11-11 06:37:37.509 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-11-11 06:37:37.510 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-11-11 06:40:50.358 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 07:10:50.911 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 07:17:55.523 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-11-11 07:17:56.644 INFO (MainThread) [supervisor.host.services] Updating service information
2024-11-11 07:17:56.668 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-11-11 07:17:57.312 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-11-11 07:17:57.331 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-11-11 07:37:01.454 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-11-11 07:37:37.514 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-11-11 07:37:37.516 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-11-11 07:37:37.520 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-11-11 07:37:37.529 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-11-11 07:37:37.531 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-11-11 07:37:37.533 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-11-11 07:37:37.542 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-11-11 07:37:37.580 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-11-11 07:37:37.582 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-11-11 07:37:37.583 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-11-11 07:37:37.584 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-11-11 07:37:37.588 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-11-11 07:37:37.589 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-11-11 07:37:37.590 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-11-11 07:37:38.022 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-11-11 07:37:38.023 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-11-11 07:37:38.023 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-11-11 07:38:27.814 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/thomasmauerer/hassio-addons repository
2024-11-11 07:38:27.829 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/music-assistant/home-assistant-addon repository
2024-11-11 07:38:27.837 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
2024-11-11 07:38:27.848 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
2024-11-11 07:38:27.862 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
2024-11-11 07:38:30.903 INFO (MainThread) [supervisor.store] Loading add-ons from store: 81 all - 0 new - 0 remove
2024-11-11 07:40:51.377 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 08:10:51.959 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 08:37:38.026 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-11-11 08:37:38.026 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-11-11 08:37:38.027 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-11-11 08:37:38.027 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-11-11 08:37:38.097 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-11-11 08:37:38.100 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-11-11 08:37:38.104 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-11-11 08:37:38.118 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-11-11 08:37:38.120 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-11-11 08:37:38.120 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-11-11 08:37:38.121 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-11-11 08:37:38.122 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-11-11 08:37:38.122 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-11-11 08:37:38.122 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-11-11 08:37:38.422 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-11-11 08:37:38.424 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-11-11 08:37:38.424 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-11-11 08:40:52.540 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 09:10:54.124 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 09:24:37.333 INFO (MainThread) [supervisor.host.info] Updating local host information
2024-11-11 09:24:38.415 INFO (MainThread) [supervisor.host.services] Updating service information
2024-11-11 09:24:38.431 INFO (MainThread) [supervisor.host.network] Updating local network information
2024-11-11 09:24:38.797 INFO (MainThread) [supervisor.host.sound] Updating PulseAudio information
2024-11-11 09:24:38.821 INFO (MainThread) [supervisor.host.manager] Host information reload completed
2024-11-11 09:37:01.628 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
2024-11-11 09:37:01.783 INFO (MainThread) [supervisor.misc.tasks] Found new Supervisor version 2024.11.3, updating
2024-11-11 09:37:01.784 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2024-11-11 09:37:01.838 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2024-11-11 09:37:02.173 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.11.3
2024-11-11 09:37:02.175 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2024.11.3.
2024-11-11 09:37:12.419 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
2024-11-11 09:37:12.420 INFO (MainThread) [supervisor.resolution.module] Create new issue update_failed - supervisor / None
2024-11-11 09:37:12.479 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
2024-11-11 09:37:38.426 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state running
2024-11-11 09:37:38.428 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/system
2024-11-11 09:37:38.429 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/system
2024-11-11 09:37:38.431 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_server
2024-11-11 09:37:38.432 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/system
2024-11-11 09:37:38.433 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_server
2024-11-11 09:37:38.435 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisor
2024-11-11 09:37:38.464 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addon
2024-11-11 09:37:38.468 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/system
2024-11-11 09:37:38.469 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/system
2024-11-11 09:37:38.471 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/core
2024-11-11 09:37:38.475 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/system
2024-11-11 09:37:38.478 INFO (MainThread) [supervisor.resolution.check] System checks complete
2024-11-11 09:37:38.481 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state running
2024-11-11 09:37:38.797 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
2024-11-11 09:37:38.798 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state running
2024-11-11 09:37:38.798 INFO (MainThread) [supervisor.resolution.fixup] System autofix complete
2024-11-11 09:40:54.771 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
2024-11-11 09:49:20.149 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2024-11-11 09:49:20.280 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2024-11-11 09:49:20.494 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.11.3
2024-11-11 09:49:20.495 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2024.11.3.
2024-11-11 09:49:21.428 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 18µs, allowed: 44000/minute")
2024-11-11 09:49:21.502 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 18µs, allowed: 44000/minute")
2024-11-11 09:49:38.610 INFO (MainThread) [supervisor.supervisor] Fetching AppArmor profile https://version.home-assistant.io/apparmor_stable.txt
2024-11-11 09:49:38.720 INFO (MainThread) [supervisor.host.apparmor] Adding/updating AppArmor profile: hassio-supervisor
2024-11-11 09:49:38.940 INFO (MainThread) [supervisor.supervisor] Update Supervisor to version 2024.11.3
2024-11-11 09:49:38.943 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/amd64-hassio-supervisor with tag 2024.11.3.
2024-11-11 09:49:51.084 ERROR (MainThread) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
2024-11-11 09:49:51.109 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
### System Health information
## System Information
version | core-2024.11.1
installation_type | Home Assistant OS
dev | false
hassio | true
docker | true
user | root
virtualenv | false
python_version | 3.12.4
os_name | Linux
os_version | 6.6.54-haos
arch | x86_64
timezone | Europe/Amsterdam
config_dir | /config
<details><summary>Home Assistant Community Store</summary>
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
GitHub API Calls Remaining | 5000
Installed Version | 2.0.1
Stage | running
Available Repositories | 1461
Downloaded Repositories | 8
</details>
<details><summary>Home Assistant Cloud</summary>
logged_in | false
can_reach_cert_server | ok
can_reach_cloud_auth | ok
can_reach_cloud | ok
</details>
<details><summary>Home Assistant Supervisor</summary>
host_os | Home Assistant OS 13.2
update_channel | stable
supervisor_version | supervisor-2024.11.2
agent_version | 1.6.0
docker_version | 27.2.0
disk_total | 56.0 GB
disk_used | 20.0 GB
healthy | true
supported | true
host_connectivity | true
supervisor_connectivity | true
ntp_synchronized | true
virtualization |
board | generic-x86-64
supervisor_api | ok
version_api | ok
installed_addons | File editor (5.8.0), Studio Code Server (5.17.3), MariaDB (2.7.1), Terminal & SSH (9.15.0), Duck DNS (1.18.0), NGINX Home Assistant SSL proxy (3.11.0), InfluxDB (5.0.1), Grafana (10.1.3), Tailscale (0.23.2), Samba Backup (5.2.0), Dnsmasq (1.8.1)
</details>
<details><summary>Dashboards</summary>
dashboards | 5
resources | 1
views | 11
mode | storage
</details>
<details><summary>Recorder</summary>
oldest_recorder_run | November 1, 2024 at 9:43 AM
current_recorder_run | November 9, 2024 at 1:08 PM
estimated_db_size | 1245.77 MiB
database_engine | mysql
database_version | 10.11.6
</details>
<details><summary>Spotify</summary>
api_endpoint_reachable | ok
</details>
### Supervisor diagnostics
Is HA OS. See first comment.
### Additional information
_No response_
bug
Encountered a 500 Server Error when… attempting to update Home Assistant Supervisor. The error message indicates that the Docker rate limit has been exceeded:
Error updating Home Assistant Supervisor: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 500 Server Error for http+docker://localhost/v1.47/images/create?tag=2024.11.3&fromImage=ghcr.io%2Fhome-assistant%2Famd64-hassio-supervisor&platform=linux%2Famd64: Internal Server Error ("toomanyrequests: retry-after: 17.225µs, allowed: 44000/minute")
Home Assistant OS
Attempt to update the Home Assistant Supervisor via the UI or CLI.
Observe the 500 Server Error with a "toomanyrequests" message, indicating Docker Hub rate limits have been exceeded.
```txt
2024-11-11 18:47:13.954 ERROR (MainThread) [supervisor.supervisor] Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
dev | false
hassio | true
docker | true
user | root
virtualenv | false
os_name | Linux
arch | x86_64
timezone | Australia/Brisbane
GitHub API | ok
GitHub Content | ok
GitHub Web | ok
HACS Data | ok
Stage | running
Available Repositories | 1466
Downloaded Repositories | 40
</details>
logged_in | true
subscription_expiration | 4 July 2025 at 10:00
relayer_connected | true
relayer_region | ap-southeast-1
remote_enabled | true
remote_connected | true
alexa_enabled | false
google_enabled | false
cloud_ice_servers_enabled | true
remote_server | ap-southeast-1-0.ui.nabu.casa
certificate_status | ready
instance_id | d85a8f57298b4d29992f380cca82e572
</details>
disk_total | 40.6 GB
disk_used | 30.6 GB
healthy | true
supported | true
virtualization | kvm
board | ova
supervisor_api | ok
version_api | ok
installed_addons | Node-RED (18.1.1), Mosquitto broker (6.4.1), ESPHome (2024.10.3), Glances (0.21.1), Studio Code Server (5.17.3), Home Assistant Google Drive Backup (0.112.1)
</details>
dashboards | 7
resources | 17
views | 70
mode | storage
</details>
oldest_recorder_run | 10 November 2024 at 05:45
current_recorder_run | 11 November 2024 at 10:17
estimated_db_size | 2543.34 MiB
database_engine | postgresql
database_version | 17.0
</details>
</details>
[config_entry-hassio-01JB3ARC0RV3YGF069MFX584T4.json](https://github.com/user-attachments/files/17699804/config_entry-hassio-01JB3ARC0RV3YGF069MFX584T4.json)
_No response_
Please don’t post “me too” just thumb up the issue(s).
I’m in the same boat, but with an added problem: I rebooted and now it won’t boot because I have an outdated supervisor.
Any ideas on how to boot with the version without updating?
Although it apparently starts well, I cannot connect
nle
(nle)
November 11, 2024, 10:23am
33
Got the docker rate limit issue, but then I just logged in with my account docker login
to have “my own” rate limit, but now I get a 404.
Error: Update of Supervisor failed: Can't install ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3: 404 Client Error for http+docker://localhost/v1.47/images/ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3/json: Not Found ("No such image: ghcr.io/home-assistant/amd64-hassio-supervisor:2024.11.3")
Hmm, trying to install 2024.11.2 gives me the "toomanyrequests: retry-after: 691.115µs, allowed: 44000/minute"
error.
I’ll jump over to the github issue.
DrThomas
(Thomas Uttich)
November 11, 2024, 10:49am
37
I got the same error unfortunately “ha supervisor repair” didn’t help. I am running on a VM in Uraid
jayjay
(JJ)
November 11, 2024, 10:54am
39
Same error here, have to wait it says for 44000 minutes hope that is a joke!
GilZock
November 11, 2024, 10:57am
40
Hi same error here (hardware Green Nabu Casa) ; we’ll see tomorrow…
a33z
November 11, 2024, 11:09am
42
Same here - hope they fix is quick HA is down on my side ;(
